Apache .. dostop do file-ov na drugi particiji preko HTTP protokola
mpasha ::
mene pa zanima kako konfigurirat Apache server da lahko dodstopas do druge particije serverja preko http protokola...
recimo strežnik teče na c:/blabla
neke datoteke pa so na d:/hoho
kako lahko zdaj dostopam do teh datotek v obliki: http://mypage/hoho/test.txt
kaj morem narediti
DC- ::
Poglej si mod_proxy, ki ti omogoča tole
mpasha ::
ProxyPass Directive
Description: Maps remote servers into the local server URL-space
This directive allows remote servers to be mapped into the space of the local server; the local server does not act as a proxy in the conventional sense, but appears to be a mirror of the remote server. path is the name of a local virtual path; url is a partial URL for the remote server and cannot include a query string.
Suppose the local server has address http://example.com/; then
ProxyPass /mirror/foo/ http://backend.example.com/
will cause a local request for http://example.com/mirror/foo/bar to be internally converted into a proxy request to http://backend.example.com/bar.
Verjetno je to to ??
jaz bi potem moral dat recimo /mirror/mydata d:/hoho
OmegaBlue ::
Joj ne ga srat s mod_proxy, naredi alias in se prepričaj da ima strežnik ustrezne privilegije za branje.
V konfiguracijsko datoteko za to domeno (sites-enabled) dodaj "alias /hoho d:/hoho".
mpasha ::
<Host name="localhost"  appBase="webapps"
    unpackWARs="true" autoDeploy="true"
    xmlValidation="false" xmlNamespaceAware="false">
    <Context path="/files"
             docBase="d:\hoho"
             reloadable="true"
             crossContext="true" />
</Host>
DELA!
naredil sem tako v server.xml datoteki
in ko grem na
http://localhost/files/test.txt
dela
  • spremenil: mpasha ()
OmegaBlue ::
Em.. imaš to čisti apache al kak paket nameščen da imaš xml konfiguracijo?
krho ::
Tole je pomoje Tomcat, ker neki WARi noter strašijo...
mpasha ::
OmegaBlue je izjavil:
ne ne .. samo tomcat je...
OmegaBlue ::
To se splača drugič omenit, me je skoraj pobralo.
IP kamera MJPEG stream embedded na spletno stran
Oddelek: Programiranje
122305 (1792) abazuu
Apache in Node.JS
Oddelek: Izdelava spletišč
92632 (2318) dunda
Za strokovnjake; forwardiranje portov za routerjem
Oddelek: Omrežja in internet
152204 (1757) Rok Woot
Moji strežniki
324115 (3031) Hexx
Apache - localhost JA, IP naslov NE
187286 (7145) ManDriver
