Forum » Konzole » PSP Odklep OFW 6.10
PSP Odklep OFW 6.10
-THX- ::
Pozdravljeni.
Imam PSP slim 2004 z TA-088v1 mobo z system software version 6.10 (original).
(Tu sem pogledal katero matično ima in če se ga da odklent). http://forums.pspslimhacks.com/user-hel...
Ker sem laik na tem področju bi prosil za malo pomoči.
Uglavnem, nimam pandore in tistega memory sticka in bi ga rad odklenu z CFW. Mau sm že brau po različnih forumih (tudi tu), samo nikjer nisem dobil točnih navodil.
Zelo bi bil vesel, či bi mi dali par linkov, kaj je treba dol potegnit, mau razložil in da si končno odklenem ta PSP.
Najlepša hvala za pomoč
Lep pozdrav in Srečno
- premaknil iz Pomoč in nasveti: bluefish ()
No če maš ofw 6.10, prvo upgredaj na 6.20 in preko patapom 2 exploita naložiš gor gor 6.20TN firmware.
Zdej če si 100% da maš teto plato not, pol bi lahko z recovery flasherjem flešu gor cfw za stalno.
http://www.psp-hacks.com/2010/12/23/6-2...
-THX- ::
Pozdravljen.
Hvala za odgovor :)
Glede matične:
4- What's the unit's Identification letter (A letter on a label on the box that indicates what version it has)? (PSP 200x ONLY, Does NOT Apply on 100x or 300x)
Here's a picture of a label found on the PSP box that has the letter on it:
Note that this label is only present on an original style box (The small, normal box. Not like those large "Limited Edition" Boxes).
Anyway, See the G there?
PSP-2000 CW
100v
G
That G is the letter in question. Here's a list of all the letters that the 2000 series ship with and their Motherboards:
(No Letter) = TA-085v1
A = TA-088v1
C = TA-085v2
E = TA-085v2 or TA-088v1
F = TA-088v1 or TA-088v2
G = TA-088v1 or TA-088v2 or TA-088v3
J = TA-088v3
Some Labels have an extra code written on it, usually “ss259”. That doesn’t matter, just look for the Capital Letter next to it (to the right).
Note that the G PSP in the picture is my personal PSP. It came with a 3.95 Official Firmware (OFW) & I hacked it.
No, jst sm meu na tej nalepki od škatle napisan A, Torej po tabeli sodeč imam A = TA-088v1 kateri;
Glede OFW 6.20:
Trenutno je uzuni 6.35? Kje bi lahko dobil 6.20, sem malo pobrskal pa ne najdem (FAIL) :/
Glede stalnega CFW-ja:
Kaj pa je razlika poleg tega da ti ni treba PSP-ja dajat na Standby in da se ti zbriše če ga čist ugasneš/daš ven baterijo/ti crkne?
Hvala za vso pomoč
Lep pozdrav!
Hvala za odgovor :)
Glede matične:
PSP-2000 CW
100v
G
A = TA-088v1
C = TA-085v2
J = TA-088v3
Glede OFW 6.20:
Hvala za vso pomoč
Lep pozdrav!
- zavaroval slike: bluefish ()
Na zgornjem linku maš vse tud ofw.
No če maš teto plato, lahko v teoriji (v praksi nwm če je že kdo probal) poženeš recovery flasherja in flešaš tazadn m33 firmware -- potem ko si enkrat v 6.20tn.
Če gre kej narobe še lahko vedn kje dobiš pandoro pa unbrikaš..
Tak boš meu staln cfw in iz tega lahko tudi flešaš če hočeš novejši cfw -- pobrskaj malo za prometheus na psp-hacks.
Če maš tak cfw gor, potem tud ni možnosti da čist unićiš psp, ker pandora vedno laufa na tem + lahko šariš po flash0 ne da bi brikno psp (ker ti pspji nimajo pre-iplja)
z nekaterimi lahko tud softmoddaš batrijo na pandoro (sam mislim da more bit od fata batrija)
Hvala za vso pomoč
Lep pozdrav!
- spremenil: iloveboobz ()
-THX- ::
Pozdravljen.
Uf O_O Polovico nisem razumel ^^.
Se bom v to poglobil kasneje, ter te še malo izprašal :)
Hvala za odgovor in pomoč in use ;)
Lep pozdrav.
Lep pozdrav.
-THX- ::
Oj.
OK Torej, nekaj takega naj bi naredil:
- Potegnem dol OFW 6.20, patapom 2, 6.20TN HEN
- Prvo updejtam OFW na 6.20
- Naložim gor patapom 2 in 6.20TN HEN (Kako, kam, kaj pol kliknt nevem :s)
- Pol lahko naložim Flash Recovery (To mi ni jasno in dam na m33) Če gre kej narobe mi pač nekdo unbrika.
- Če bom meu m33, bom lahko updejtu na novejši m33? Npr 5.03 m33 - 5.50 m33?
Kaj si mislil da lahko šarim po Flesh0, da pandora vedno laufa na temu in da teli pspji nimajo pre-iplja, stem bi lahko svojo baterijo z softmodom lahko naredil v Pandoro, če je Fata Baterija?
Kako pa z Iso pa Cso loaderjom?
Hvala še enkrat
Lep pozdrav
Hvala še enkrat
Lep pozdrav
- spremenil: -THX- ()
-THX- ::
There are two kind of PSP 2000:with motherboard TA-88v1 or 2(5.50 Prometheus-3 v4 will install on those models)and with motherboard TA-88v3 like yours and mine,a motherboard which needs ChickHEN in order to install LCFW
http://pspslimhacks.com/custom-firmware...
On kle pravi, da za TA-88v1 ne rabiš TN ampak Prometheus-3 v4?
Ali se motim ker mam 6.10(6.20) OFW -.-
Jao kok komplikacij glede tega..
Kaj pa je razlika med 6.20TN-A in 6.20TN-B?
Ne, še vedno rabiš 6.20tn, ker nimaš pandore, da bi zagnal installer.
TN-B je novejša verzija.
Oj.
Hvala še enkrat
Lep pozdrav
flash0 je interni pomilnik psp, gor lahko flešaš recimo teme, plugine...
preipl je zaščita na teh v3 platah (tega ti nimaš), ko zaščiti ta flash0 pomilnik, da ne morš cfw gor dat.Softmod ne morš ti nardit..
ISO/CSO loader je vgrajen v cfw, razn pr 6.20tn, tu ni ker je to v bistvu sam homebrew enabler...
Najbolš da nardiš, tak ko si zgori napisi, pa pustiš 6.20tn gor (če že res hočeš si naložiš tist iso loader za backupe), pač vedno spet loadaš patapom pa 6.20tn ko se ti sprazne batrija.Sej maš tak standby, tak da ni tak problem.
Jes na tvojem mestu se nebi preveč igral z recovery flasherjem, razn če maš pandorino batrijo pr roki.
Mal poglej po psp-hack,youtube,itd, maš navodila kak to nardit.
-THX- ::
Ok Bom neki ščaru pa bomo vidl kaj bo :)
Hmm ok.. Zdej mam:
6.20TN -B HEN
HBL patapon2
Patapon 2 Demo
Patapon HBL save game
OFW 6.20 update
A mi kej manka? Če mi ne, kam potem vse extractam?
Update v X:/Removable Disk/PSP/GAME/UPDATE
Kam pa ostalo? Igrco v GAME? save game v SAVEGAME, kam pa HBL in pa 6.20 TN-B
Hmm ok.. Zdej mam:
6.20TN -B HEN
HBL patapon2
Patapon 2 Demo
OFW 6.20 update
-THX- ::
Updejtnu OFW 6.20
dau gor savegame v PSP/SAVEGAME
dau gor demo patapon 2 v GAME
V root sm dau HBL
6.20TN-B sem dal v GAME
EDIT: OK zdej use delal samo se ne reboota? ali se... Po tistem memory leaku naredi crn ekran pol pa gre v XMB
Potem v igri naložim save od wolola za patapon 2 HEN
Pritisnem R
Me da v meni od HENa, izberem HEN, mi da black screen, neki napiše, takoj zgine, pol spet crn ekran, napise Memory Leak.. Crashne iz igrce na XMB.
Grem pod System, mi piše da mam 6.20TN-B
Samo tm v navodilih pise da bi se mogu rebootat? men se ne.
# In the XMB go to PSP/GAME And start the Patapon 2 demo (DL save game Below) and run Half Byte Loader.
# In the menu of HEN, select HEN
# Wait a few seconds your PSP will reboot!
# You will be automatically returned to the XMB.
# Congratulations, now enjoy your homebrew.
V root sm dau HBL
Pritisnem R
-THX- ::
Dela vse lepo in prav. Če bom kdaj hotel to narest za zmeraj, te kontaktiram :)
Najlepša Hvala in Srečno novo leto :)
Lep pozdrav
Lep pozdrav
| » | Psp odklep (strani: 1 2 3 4 5 6 )Oddelek: Konzole | 53112 (25476) | Peter6 |
| » | PSP "napaka"Oddelek: Pomoč in nasveti | 5011 (4750) | iloveboobz |
| ⊘ | PSP!Oddelek: Konzole | 1249 (1188) | bluefish |
| » | PSP GO - že obstaja kakšen CFW(Custom FirmWare)?Oddelek: Konzole | 1139 (902) | tian cor |
| » | Psp firmware PspOddelek: Konzole | 3185 (2364) | BananaBoy |
