AMD Bulldozer
AMD Bulldozer
IvoJan ::
dej link :D
|TUF X670E plus WIFI|7900X3D|arctic LF2 360mm|
boolsheat ::
Zakaj je AMD prekinil razvoj Bobcata? So zadovoljni z učinkovitostjo "low power" trinity procesorjev? A4-4355M in A6-4455M imata TDP 17W, zacarte E1-1200 in E2-1800 imata TDP 18W.
Torej bi morala Trinity modela biti hitrejša in varčnejša?
einstein :P ::
a ni svetovni rekord okoli 8.7GHz? just sayin...
STAY OUT OF MY TERRITORY!
boolsheat je izjavil:
Kdo je rekel, da so prekinili razvoj?
IvoJan je izjavil:
dej link :D
|HP EliteBook|R5 6650U|
  • spremenil: D3m ()
Isotropic ::
bobcat je bil na starih phenom corih. trinity je na piledriver. trinity 2.0 bo spet pile + gcn graficna (kaj je sedaj, ne vem. alpa bo gcn2, ce je ze sedanja gcn). naslednik trin bo pa kaveri na steamrollerju.
boolsheat ::
Enhanced-Bobcat (cancelled)
Krishna (28 nm) and Wichita (28 nm) (cancelled)
For the budget desktop and notebook markets (18 W TDP), Krishna was scheduled to replace the Zacate-based E-series. It was expected to be available in 2 to 4-core variants.[44]
For the low-power/netbook markets (9 W TDP), Wichita was scheduled to replace the Ontario based C-series. It was expected to be available with 1 to 2 core versions.[44]
The website SemiAccurate speculated that the reason for the cancelation was the short expected shelf life of the two chips.[45]
Torej bodo namesto teh uporabili kar "low powered" trinitije za low budget prenosnike?
Stara novica, namesto Bobcat bo zdaj Jaguar.
x45 ::
AMD x4 965 BE, 8 gb ddr3 1600, SSD Samsung, 960 GT
Xeon x3430, 8 GB DDR3, Matrox grafa
Isotropic ::
o zanimivo
http://www.dailytech.com/article.aspx?n...
http://www.ziilabs.com/
tale ziilabs so pa v bistvu ARM proci z dodanimi splosnonamenskimi FMA enotami. nisem zih, a se le-te uporabljajo tut za grafiko al ne sicer.
Vidim da tole postaja popularno... TI ima tudi neke arm+dsp izdelke, ki jih lahko z openCL uporabljaš. Obljubljajo 15Gflops/W. Wanna see :)
fireX88 ::
jst ne najdem teme za fusion procesorje kjer sem sodelovl, vendar sem kupil za fotra a4-3300 (low budget) in sem presenetljivo zadovoljen z njim! nizka poraba, ne greje se (okol 30° je blo skus) in za desktop userja super zadeva! morem še probat kako igro, nezahtevno :D
skratka priporočam!
Mislis tole temo?
AMD Trinity
Probaj UT2004, to bo dobro letelo :)
Ali katero malo novejšo igro.
Krigl ::
jaz sem nabavil FX-8320, pa me zanima ali je smiselno nanesti kaksno drugo termalno pasto kot original?
x45 ::
Krigl je izjavil:
če imaš boljšo pasto seveda. še boljše je drug večji hladilnik. kašno ploščo pa imaš ?
Krigl ::
Gigabyte 990XA-UD3. zakaj?
vprašanje je, kako vem kaj je 'boljša pasta'?
x45 ::
so neke res boljše paste na trgu ampak drage. Večji efekt je z boljšim hladilnikom oz vodnim.
AMD sicer nima problemov z gretjem in obvezno menjavo kulerja kot intelov box ki je res premali.
zanimivo daj izpiši konfiguaracijo pa nastavitve ter programe pa naredi kak test v stilu fr@nc a :)
M-XXXX ::
Moderatorji prosim zbrišite tole traparijo, da ne bo še kakšnega naivneža prepričal, da dejansko ve kaj govori...
x45 ::
da boste vedeli vsi da je res:
intel 22nm gretje do 90 stopinj zanan tema tud na slo ju precej pisano o tem:
http://wccftech.com/intels-ivy-bridge-c...
box kuler zelo nizek - obvezna menjava:
http://www.agt.si/racunalniska-oprema/p...
zanimivo zraven je za ebnak denar v vcenovni tabeli amd jev FX 8120 ki ima beri in glej !! 6 jeder več od tega duala :)
PS : ne favoriziram AGT ja, ne amd ja ampak resnica je pač taka.
  • predlagal izbris: Isotropic ()
Krigl je izjavil:
Ni smiselno.
M-XXXX ::
Aha, takole to gre: če naviješ procesor na 4.5ghz NA STOCK hladilniku se zna pregrevat:D Zdaj pa mi pokaži na AMD-ju in stock hladilniku 4.5ghz...
PS: vem, da je bil slab IHS stik problem prvih batchov, so zadevo kaj popravili? Kolikor vem so delali nekaj na tem
  • spremenil: M-XXXX ()
Isotropic ::
zavajalni post x45
žalost.
Janac ::
A so vsi te rekordi v navijanju buldožerja z LN2 hlajenjem?
hojnikb ::
Janac je izjavil:
Ne, nekateri so z tekočim helijem ;)
#brezpodpisa
fireX88 ::
Dr_M je izjavil:
Mislis tole temo?
AMD Trinity
Ni bla ta tema, vem da sem nekaj spraševal za tole.
D3m je izjavil:
UT2004 pa še kaj novejšega bom našel pa probal in poročal!
sm ma pa smešno nizko porabo -> 53W.. Cel sistem pokri manj kot pa žarnica na hodniku :D
A to poraba v idle?
fireX88 ::
ne, med tem ko sem nalagal programe. to sem pa vidu z programom CPUZ ter HW monitor.. ko bo možnost bom printscreen naredu!aja to je bla poraba samo za procu + če sešteješ še ostale komponente brez monitorja nebi reku da pokuri 100W. seveda če je unih 53 realnih
Aja, sm mislu,da mas kaksno zadeva za vticnico.
fireX88 ::
žal tega pa nimam :(
to potem lih ni najbolj relano ne?
x45 ::
FPS amd v igrah ( pregleden test )
http://www.tweaktown.com/reviews/5063/a...
filip007 ::
Aja zastonj grafično dobiš pri Trinity drugače pa ni razlike, jah no ugodno za določen segment.
Prenosnik, konzola, TV, PC upokojen.
filip007 ::
Win8 naj bi prinesel neke čudeže, pa jih ni?
http://uk.hardware.info/reviews/3549/2/...
fr4nc ::
filip007 je izjavil:
Se niti ne čudim, če to drži... saj je tudi logično. Če nimaš konkurence se prilagajaš tistemu, ki ti več ponudi oz. da...
Optimizacija za AMD procesorje je tak že dolgo v kur**.
Drugače pa tudi hotfixa naj bi prinesla čudeže... pa jih tudi nista, v bistvu je šlo za nasprotno - zmanjšanje performanca... le zakaj? Zelo verjetno je to zato, ker je denar sveta vladar.
Drugače pa še me čudi, kako še ima lahko sploh AMD procesorje v vrhu na p/p lestvici...
Prodajajo pod ceno, to se vidi po veliki izgubi vsako cetrtletje.
Sej je prinesel napredek, hitrejše delovanje na HDD diskih.
D3m je izjavil:
In kako veš, da prodajajo pod ceno?
  • spremenil: D3m ()
Prvi namig mas ze v prejsnjem postu.
Še ta udarec.
x45 ::
fr4nc je izjavil:
ja kaj si PROČAKOVAL ? itak je intel v navezi win-tel "nardil" že SP1 tako da je drastično padel prefo buldozerju. brez SP1 je bil precej boljši pa ponekod v linuxu tud. so testi tu gor, tud tvoji.
ja pa fajn da ostaneš kar na win 7 ki so itaq boljši.
p/P pa pač amd rullz
  • predlagal izbris: M-XXXX ()
Isotropic ::
Dr_M je izjavil:
izgube so delno zaradi odpisa llanov, ker niso hoteli prodajati pod ceno.
x45 ::
še poraba:
http://www.tweaktown.com/reviews/5077/i...
32nm intel 2600k žre 25 % več ob 4 jedrih
kot AMD FX 32 nm ( vishera ) na 8 jedrih. oba 32 nm.
Load AMD malo več ( skoraj enako ). opomnim še naj da je tukaj test res pregleden in so vse komponente ki so lahko skupne.
fr4nc ::
@M-XXXX - predlagal izbris: (včeraj ob 23:30:56)
Sicer ne vem točno zakaj si post od x45 zasluži izbris, ampak OK...
Je pa res, da sta se dejansko dva giganta spravila na enega... in sta dejansko na dobri poti, saj je AMD vedno manj konkurenčen... upamo, da bo HD8xxx serija bombastična ter, da se zasluži kaj denarja ;).
Lep pozdrav
x45 ::
hitros rama v amd ju - OC:
Isotropic ::
to samo pomeni, da ima amd slab memory controller, nic novega.
54j0 ::
To res deluje rahlo slabo, i5 2500K ima boljši rezultat @4.4 Ghz + 1600Mhz DDR3 (9-9-9-24). In to na "zasvinjanem" sistemu.
M-XXXX ::
Okej, če je relevantno primerjat z DVE LETI STARIM procesorjem potem pa tudi prav. Oziroma bom kar uradno priznal:
Priznam, AMD je KONČNO dohitel DVE LETI star procesor.
PS: ravno v tem testu je jasno vidna RELEVANTNOST senzorjev v AMD-ju in kako goljufa že leta pri temperaturah:
idle temepratura: 7C
load temperatura: 30C
Najbolj patetično pa mi je bilo, da so kar nekaj časa to zagovarjali, da so PRAVILNE temperature, saj je hladilnik hladen na otip. Ahahhahha:D
Spravila na njega? Hočeš rečt, da sta popolnoma obična konkurenca tako kot v vsaki storitvi/izdelku na tem planetu? Če pa je AMD tako nesposoben, da se zna spacat konkurenčnega izdelka je pa čisto njegov problem. Kar se ravno pri procesorjih dobro vidi. Ravno dve leti zaostanka. Zdajšnja generacija je primeljiva z 2X00 serijo, naslednja bo pa z 3x70 (če bo šlo tako naprej).
PS: oziroma celo to ne: ravno v tem testu je AMD praktično povsod slabši od 2600k (par testov, da sta izenačena oziroma je minimalno odstopanje), drugače je 2600k podoben hitrejši. Tanovo generacijo je pa brezveze sploh gledat.
No mogoče pa AMD-ju čez ene 2 leti rata ujet 4 leta stare Intle. Mogoče.
x45 ::
fx 8320 8 JEDER STANE 165 eur pr nas, kaj se dobi za to pr intelu ??
54j0 ::
Do ene 180EUR AMD res nima konkurence, predvsem zaradi (zoprne) odločitve Intel-a, da odklene množilnik le svojim "top" modelom.
edit: Recimo raje do 220EUR. Dolgo nisem spremljal cen in sem nekako pričakoval, da bo cena kakšnega 2500K padla na 180EUR, pa vidim, da je v povprečju 10EUR dražji, kot lansko leto (???).
  • spremenil: 54j0 ()
Krigl ::
Naredil sem en test z mojim FX 8320:
  • spremenil: Krigl ()
Krigl ::
pa še:
x45 ::
gled ena ceno torej P/P je boljši od 3770k ( 164 vs 280 eur ), kaj tole je stock tj 3,5 ghz?
Daj izpiši konfiguracijo prosim in nastavitve ter os in popravke.
111 / 128
