AMD Bulldozer
AMD Bulldozer
kmxkmx ::
Ni še nobenih uradnih testov, tako da se lahko le špekulira o Bulldožerju.
Če ne drugo pa bo verjetno Intel tudi malo pocenil svoje cpu-je po izidu AMD-jevih Buldožerjev.
Tako da počakat se vsekakor splača.
  • spremenil: kmxkmx ()
globoko grlo ::
itak da počakaš, kot je kmx povedu, ane
BALAST ::
Leaked Buldi test
We start with Cinebench-10. And here we get a core 4074 issues. Approximately 1.5 times less than an Intel core so (both the 2600 and the i5 i7 2500 get about 5800 points. An 'old' i7 965 is around 4900 points)
But the bulldozer hits back hard in the multi-CPU test. Here we see 20615 points. A multiplication of 5.06. We had expected a bit more honest, more close to six times. Perhaps the faster memory to work out better. Yet five times faster is not bad: a hyperthreaded i7 gets just four times. In addition, a very nice score 20,615 points: it is 2000 points more than an i5 2500K and 2000 points less than the more expensive i7 2600K. 11.5-in Cinebench scores Bulldozer with 6.01 points and between the i5 and i7 2500K 2600K in: get the i5 and i7 5.37 6.73 gets points on our test platform. I7 965 sits on a 5.73 points.
Going to 3DMark Vantage, we see a CPU score of 19,119. A perfect score in the top segment. Again between the i5 and i7 in. I7 gets around 22,500 points on the CPU. The total score is an nice 21949 points. Less than an i7 with this card comes out around 25,500. However: every game is without problems on super high detail and resolution to play with this system.
In 3DMark 2011 scores 6616 points in total AMD. Again, neat and a good sign that the processor can feed data to the HD5970. For comparison also take an i7 965 with the HD5970: 7385 points, roughly equivalent to a 2600K i7 with that GPU. Tag is a still faster. With an i5 you're at about the same level as the FX-8150.
Gaming
AMD focuses FX platform especially for gamers. Gamers with separate graphics cards will work, sometimes in CrossFire. We turn therefore take the Dirt3 benchmark at 1920 by 1080 and every detail. The HD5970 has to work hard and certainly not limited by the CPU.
The FX-8150 gets 105 fps on average in this test with a minimum of 75 fps. An incredibly good score, considering the load this game can give both the cpu and gpu. If we look at our platform with the 965-i7 Nehalem CPU, then we - of course with the same settings - at 93 fps and a minimum of 71 fps. Definitely good to play, but lower than the FX-8150.
We turn then still Mafia II. A very CPU-intensive game. There we see that the new platform averaged 68.3 fps able to render. Nehalem setup squeezed out, 76 fps. Just over the Bulldozer. Perhaps some help here 6GB memory.
"You may fool all the people some of the time;
you can even fool some of the people all the time;
but you can't fool all of the people all the time."
eieieie1 ::
No shit sherlock!!
Ok, mislim kakšni "leak" testi so to, da grejo primerjat novi fx 8150 s starim i7 965 procesorjem??? Pol pa še dajo not eno šrot grafično kartico, ki itak limitira rezultate. Naj dajo not eno hd 6990 ali gtx 590 pa primerjajo i5 2500k z fx 8150 če si upajo.
AMD marketing je res čisti fail!
  • spremenil: eieieie1 ()
klinker ::
No no, 5970 pa ne mores rect da je srot, halo ;)
mr1two ::
Eh, eni mislijo, da če je številka na začetku že eno serijo nazaj, da je grafa kr šrot :))
Za eno malo pokušino
Iz teh testov se samo vidi, kako odlicna graficna je GTX580 :))
Malo draga res, ampak vseeno brez konkurence. Pa se svetlobna leta bolj zanesljivo deluje, kot multigpu. :(
eieieie1 ::
Ups, se posipam s pepelom :D
Sem mislil da 5970 deluje v rangu 6950 :P
klinker ::
V bistvu bi blo boljse. Malo kdo ima doma karto kot je 5970, ipd.
No sej se par dni in bomo ze na OC-labu sigurno kak res realen test dobili, ker ce sem dobro opazu si tam nekdo ze, oz. si bo te dni lastil Buldija ;)
Jst ::
Glede leaked testov: Ker sem imel notranje informacije in sem pod NDA, da mi glavo lahko odrežejo, poglejte, kaj sem napisal nekaj zadnjih postov... Leaked testi bodo kar držali.
Za BD2 pa ne vem nič. Ampak predvidevam, da bodo "ojačali" Fetch/Decode/Schedulerje/... in že s tem dosegli, da bodo "half core," kot jim eni tu pravijo, delovali bolje. V BD1 se pa dostikrat zgodi, da ker imata jedra skupno logiko, eden idla, ker je drug zaposlen, ker mu logika tako učinkovito dostavlja ukaze.
Se pravi, tole je bolj odskocna deska za nadaljne izboljsave?
Jst ::
Sama ideja modulov je super, samo zakalkulirali so se pri logiki ki skrbi , da so jedra na polno obremenjena.
Potencial za BD2 je sigurno 30%+ performance increase pri večjedrnih aplikacijah.
edit: ki bi bil lahko izdan v slabem letu. Potem pa če upoštevamo še druge izboljšave in ni vrag, da bo AMD imel učinkovito modularno arhitekturo, ki mu bo dala prednost pred Intelom za nekaj let. Ampak če pogledamo MO AMDja zadnja leta, sem skeptičen glede tega.
  • spremenil: Jst ()
Isotropic ::
BALAST je izjavil:
Leaked Buldi test
kateri od teh testov obremeni FPU, mogoce kdo ve? in multi-procesiranje?
tale?
jst, so pri teh vecnitnih appih misljene tudi fpu-intensive zadeve? numerika pac, s podporo smp.
globoko grlo ::
Res dobro skrbijo pri AMDju za nas, potrošnike. Nečejo nam dat že danes enga top CPUja, raje delajo "odskočno desko" za nadaljni razvoj. Res so super. In tako naprej do xyz, vedno bo future oriented, sam present jih mal jebe >:D
Gamez0r ::
Ne verjemte benchmarkom, keri ne prhajajo direkt od AMD-ja.
WTF!
jest10 ::
Gamez0r je izjavil:
Pa ravno tem od AMDja je potrebno najmanj verjeti;)
mr1two ::
No, nebi ravno reku, da so od AMDja lažni, so pa editirani(povzetki so narejeni tako, da izpade kot oh in sploh, ampak to je klasični marketing).
Najboljšo sliko dobiš, ko imaš za primerjavo recimo 2 do 3 enakovredne in legitimne znane strani na netu, kjer ima vsaka od njih svojo metodologijo testiranja. Od tam lahko hitro povzameš kaj je res in kaj ne.
Je pa treba brat recenzije, ne samo slikce gledat(primer: igra v kateri grafična x močno prehiti grafično y, ki sta sicer izenačeni, jo lahko prehiti zato, ker ima igra bug, na katerega se obesi vsync, ki se ga na grafični y ne da izklopit- torej, umetna meja je vzpostavljena, na grafu je to jasno vidno(fpsji vedno okrog 60 slik/sekundo, nikoli čez), tudi brez razlage pod sliko, nekateri osebki pa potem lahko zelo zelo hitro pridejo do napačnega zaključka)
Tarzan ::
globoko grlo je izjavil:
Ja, kaj pa? A naj bodo v preteklost zazrti in ne v prihodnost? Arhitekture procesorjev zorijo skupaj z vsako novo izdano serijo, ki jo uspejo skompletirat. Če rabiš nov računalnik, ga boš kupil, od Intela, AMDja ali koga tretjega, če ga še ne rabiš, pa čakaš do trenutka, ko ga boš mogoče rabil. Če ga rabiš samo zato, da imaš najnovejšega, pa toliko bolje, lahko vsako leto kupiš enega ali dva. ;)
Gibbs007 ::
Se splača počakat do BD ali i5 2500k? Ker komponentam cene skačejo malo gor malo dol.
knap ::
kdaj pa bodo novi procesorji prišli v lokalne trgovine, oz nemčijo, avstrijo
kakšne bodo cene, ali je že kaj znano?
Hvala
Gamez0r ::
@Gibbs007 počaki na Bulldozer-ja, govori se nej bi pršu 12 Oktobra 2011
@knap Govori se 12 Oktobra 2011
Cene nej bi ble:
FX-6100 ~ 190-195$
FX-8120 ~ 235-245$
FX-8150 ~ 275-285$
WTF!
  • spremenil: Gamez0r ()
Mitja358 ::
Gamez0r je izjavil:
Cene nej bi ble:
FX-6100 ~ 190-195$
FX-8120 ~ 235-245$
FX-8150 ~ 275-285$
Cene naj bi bile še malenkost nižje. Okoli 245$ za FX-8150 ter 205$ za FX-8120.
  • spremenil: Mitja358 ()
Gamez0r ::
Ja no nevem tele so najnovejše do zdej.
WTF!
kmxkmx ::
Neki romuni se testirali buldožerja: ---> lab501
Če je to res ----> katastrofa :(
mr1two ::
Pa kje imajo te jajc serverje, da tko po polžje odpira:| ali je pa tak naval:))
kmxkmx ::
Ful je naval. Ta preview se samo širi po forumih.
BALAST ::
Dobre novice se hitro širijo, slaba pa še hitreje. Napovedujem 20% upad vrednosti delnice AMD.
mr1two ::
Ne kupim, kar prodajajo na tem testu. Vse bolj se mi zdi da je to bl en stress test za njihov strežnik in 5 minut slave, kot pa kej druzga :8)
WarpedGone ::
A še kdo pomni FiringSquadov preview originalnega Athlona?
Od takrat naprej na tele "leakane" teste ne dam počenega groša. Dokler stvar ni uradno zunaj, ne veš kaj vse v čipu dela in kaj ne.
Zbogom in hvala za vse ribe
BALAST ::
Se strinjam, ampak res videl že najmanj 3 leakane teste s podobnim rezultatom? 8-O
Jst ::
Lejte, multithreaded aplikacije bodo dokaj dobro delovale, single pa ne. Je pa že na takšni hitrosti (tudi i7 in i5), da tisti, ki ga [Bulldozerja] je čakal, naj ga kupi in pozabi nanj. Edino Benchmarkerji ne bodo zadovoljni.
Real world performance pa ne boš opazil razlike med BDjem, i7 ali i5. Mogoče pri kakšen konvertanju ali heavy usage, ampak takšni ponavadi že vemo, kaj hočemo... v bistvu rabimo in si to tudi kupimo in že imamo.
Razen ena anomalija je pri meni: Jaz si GPUje kupujem samo za parkrat na leto, ker samo parkrat na leto igram igre. Škoda denarja, ja, ampak si lahko privoščim 300EUR na dve leti za par tednov igranja.
Mene bulldozer zanima samo zato, ker naj bi delal na moji plati, sicer ga nebi tako pricakoval. Me zanima, ce bo asus res izdal final bios.
Rippy ::
Jst je izjavil:
Ampak če že kupuješ striktno AMD (zaradi nadgradnje ali drugih razlogov) a ni kakšen X4 višjega razreda, še vedno boljša izbira glede na trenutne rezultate in če potrebuješ večnitnost in najvišji X6 model le nekaj % za BD v tem. Sicer je vredu serija ampak če ga postaviš ob bok prejšni generaciji ni več impresiven in včasih korak nazaj.
Brane2 ::
Zato pa se splača počakat na Piledriverja.
Dobi nov modul pa vsak core bo hitrejši kot prej. P a vverjetno boš dobil čipe z malo višjo frekvenco ob nižji porabi.
Točno tako kot pri Phenomu. Enka je bila čisto spodobna ampak dvojka je pokazala vse, kar znajo.
In ker jih Intel stiska, bodo morali z dvojko ven precej kmalu.
Kam se vsem tako mudi ?
Jst ::
ATI je spremenil strategijo in radikalno spremenil tudi arhitekturo, začenši z 4000 serijo. Sistem Lego kock. In očitno je, da mu je 4., 5. in 6. serija uspela.
AMD probava podobno z Bulldozerjem. Koliko bo CPU marketinško uspešen, bomo videli. Jaz upam da bo hit, for Intel's sake. :)
x45 ::
jas bolj temu verjamem - bomo pa vidli še dva dni. Najbolj zanimivo bi bilo dobit en fer test na Linux u, kjer monpolist pač ne goljuga z manj zmogljivo kodo za izvajanje.
http://lenzfire.com/2011/09/amd-bulldoz...
eieieie1 ::
Ja ta tvoj je zelo kredibilen, kjer ga primerjajo z starimi intelovimi procesorji, kot da je tako zelo težko pri vsakem testu dodat score od i5 2500k in i7 2600k.
klinker ::
x45 je izjavil:
Kaj ce bi ti dolocene besede v svojem izrazanju malo "polepsal"? ;) pa tudi pisat bi se ze lahko naucil :)
Jst pravim da naj se pocaka do izida. Vsi tej testi so do izida itak samo ugibanja in nic vec. Brezveze delat "vojno" z necem kar se niti "ne obstaja", pa tudi kasneje nima smisla...so samo cpuji in dva podjetja, ne vem zakaj je treba tako osebno in resno delat fanovske vojne tu gor. Raje drzite debate na nivoju foruma, kar pomeni na malo bolj profesionalnem nivoju ne pa kod da smo v vrtcu in se "kregamo" za avtke ;((
  • spremenilo: klinker ()
M-XXXX ::
http://www.xtremesystems.org/forums/sho...
Why does Lab501 get to break NDA?!
In order to break an NDA you have to sign one first...
I suppose there is also a small chance that all the final BIOS updates for the BD won't be released until the day of the launch
Actually no, there is no chance, because you need reviewers to have time to test this stuff before publishing a review. Nobody makes reviews in one day...
I know!!! Trust me, we retested many times, because we found this hard to believe even if the results unveiled under our eyes. We checked everything countless of times, and still get the same results. Unfortunately, this really is how Bulldozer is performing, and that makes me as sad as any other enthusiast in this industry!
Monstru on AMD's "damage control":
Now the saddest thing is not only the performance, but also the way in which AMD tries to manage this. I heard from a little birdie that some folks at AMD will start calling press tomorrow morning to ask them how reviews are going and try to do some damage control (this reminds me of Nvidia calling press before GTX480 launch). Actually many of the press guys I talked to are a little bit puzzled and don't really know how to approach this situation. From my point of view it is pretty clear, the truth (no matter how much it hurts) is the only way.
Škoda... Tresla se je gora... Rodilo se ni nič :/ Upam, da hitro izdajo 2 ali kaj podobnega in popravijo kar so zdaj zajebal...
filip007 ::
Zero games, zero talk.
Problem je, da Serious Sam 3 še sploh ni izšel ...
69charger ::
V bistvu je beta testing v teku že kakšen mesec,tako da je lahko kakšen srečni izvoljenec bench spustil skozi.
Jst ::
Počakajte še na MS update.
edit: Pri kateremu seveda ne bo pisalo "Updates Kernel - BD Perf. resolved," ampak verjetno optimizacije za paket programov.
  • spremenil: Jst ()
Rippy ::
Jst je izjavil:
Lahko to malo bolj obširno razložiš (kaj je težava in kako se to pozna), mogoče bo najbolj zanimiv post v tej temi - talk to me nerdy :).
  • spremenil: Rippy ()
Brane2 ::
Nisem poštekal vsega, ampak gre za to, da zaradi omejitev tehnologije CPU interno čekira vsak naslov v dveh korakih- v prvem prečeikira ujemanj naslovnih linij A0-A11, v drugem pa vse ostalo.
Fora je povezana s tem in pa s tem, da ima BD deljen instrukcijski L1, ki pa je samo 2-way asociativen.
Folk je mislu tle potegnit bližnjico, ob kateri pa Linus ni najbolj navdušen.
Jst ::
Rippy: Najbolj zanimivi posti so že zdavnaj mimo. Pisal sem jih, poleti, preden sem šel v tujino za projekt.
Kar sem pa z Update-i mislil, je pa re-compile. Tle bi se znalo kaj poznati.
Kaj ima AMD takšen fetiš na 2-way? Pomoje bi znala biti omejitev to, da se potem lego kocke (moduli) ne bi z takšno lahkoto zlagale skupaj.
edit2: Čeprav tako globoko pa nisem delal projekta, da bi to vedel. Mogoče sem celo izjavil najbolj butastko izjavo leta... :)
  • spremenil: Jst ()
x45 ::
Men se zdi neumno da razvijajo dva postopka - imajo namreč že delujoč 28 nm za grafe, pa še 32 nm soi High metal K ni izpiljen.... laghko bi šlo na 28 nm direkt in prehiteli Intel.
Glede samega jedra BD:
Po vseh teh letih izkušenj v cpu jih pa mi je tole čudno kaj pišete zgoraj.... po takem bi bil update na PH III ( 32 nm, clock višji, avx, xop , SSSE 4x ipd, večji cache) boljši od BD .
Bomo pa vidli več testov kmalu.
Tale zaključek iz linka zgoraj pa tud nekaj pove:
Conclusion
After comparing all the benchmarks we just like to conclude that AMD Bulldozer can easily take Core i5 2500K from its $230 segment. Also Bulldozer performs almost equal to Intel Core i7 2600K in most benchmarks and 56x performance in applications using complex calculations are really amazing.
Where Bulldozer takes lead? Will Bulldozer suit me?
For $12 more than i5 2500K Bulldozer certainly gives 12 to 40% more performance in all applications and games
With 8 cores, Bulldozer has 4 real cores than Intel i7 2600K and i5 2500K processors
If you are use your computer mostly for productivity applications, video encoding, transcoding processes, which supports multi-cores then without any second thought take AMD Bulldozer. If you want to outperform i7 2600K processors too then you may wait for FX-8170
All Cores Turbo Mode is an excellent feature, because it's almost like safe overclocking, which can be done by anyone
Do you play games at super resolution or do you play with multi-monitor setup using Eyefinity, then Bulldozer can be your first choice
Then finally, do you need a cheaper solution with more cores, having performance almost equal to Core i7 2600K, take Bulldozer
  • spremenilo: x45 ()
Mitja358 ::
x45 je izjavil:
To bi lahko pojasnilo tale pojav: klik.
mr1two ::
Saj se tudi 2500k draži. Odkar sem gledal, da bi upgrejdal PC, se mi je celotna sestava(cpu+mb+ram) podražila za 30 evrov. Bom pač počakal, trentni čas ni ugoden za nakup.
PrimozR ::
x45 je izjavil:
Res neumno to ja, sploh ko vzameš v zakup, da CPU-je in GPU-je izdelujeta dve popolnoma različni firmi na POPOLNOMA različnih proizvodnih postopkih (SOI vs. bulk silicon). Oh wait, to sploh NI neumno!
40 / 128
