Forum » Programska oprema » vmware - delayed write failed
pujs ::
konfiguracija:
host os - windows 7
guest os - windows xp
vmware workstation 7.0
problem je sledeci... v virtualno masino (win xp) hocem dodati ZIP drive (IOMEGA Zip 100mb ATAPI/IDE), ki deluje v win 7 brezhibno (tudi na prejsnih win xp je deloval).
Najprej sem zagnal vmware workstation kot administrator, dodal virtualni masini "Generic SCSI Drive" in izbral ZIP disk, ki ga zelim omogociti v tej vm. Potem sem instaliral se iomega ioware driverje na xpjih (guest os).
Tu pride do tezav. Ko odprem moj racunalnik in dvakrat kliknem na disk, da pogledam vsebino ZIPa se mi izpise napaka "Windows - delayed write failed".
Pogledal sem se v Event viewer, ki izpisuje naslednje opozorilo: "An error was detected on device \Device\Harddisk1\D during a paging operation."
Ocitno VMware slabo zloada napravo, ne vem... ma kdo kak predlog kaj bi lahko blo narobe? TNX!
host os - windows 7
They toook rrrrrrr jjjjjjbbssss!!!!!!!
pujs ::
aja... tu je se opis zakaj pride do tiste napake " ... during paging operation."
Details
Product: Windows Operating System
Source: Disk
Version: 5.2
Symbolic Name: IO_WARNING_PAGING_FAILURE
Message: An error was detected on device %1 during a paging operation.
Explanation
An input/output (I/O) request to a memory-mapped file failed and the operation was retried.
User Action
If these events are logged regularly on a primary system drive, replace the device. Otherwise, no user action is required.
Details
Source: Disk
Version: 5.2
Explanation
User Action
| » | Pogosto degradiranje RAID 1 poljaOddelek: Pomoč in nasveti | 861 (781) | heho |
| » | usposobitev NCQ-jaOddelek: Strojna oprema | 1885 (1717) | TheJack |
| » | Kako naj se prepričam, da je šel disk?Oddelek: Pomoč in nasveti | 1302 (1267) | Zvonko 123 |
| » | Kaj bi lahko bilo narobe?Oddelek: Pomoč in nasveti | 1588 (1488) | Tilen |
| » | master/slaveOddelek: Pomoč in nasveti | 7473 (7395) | TheJack |
