koyotee ::
Multichemistry charger groupbuy: http://budgetlightforum.com/node/30515
Blackshadow Terminator T70 groupbuy http://budgetlightforum.com/node/31397
Rear DVD collector!
JTD power!
koyotee ::
17.41$ Convoy M1 40% off http://budgetlightforum.com/node/31471
Rear DVD collector!
JTD power!
koyotee ::
Rear DVD collector!
JTD power!
driver_x ::
Ker sem začetnik z litijevimi baterijami bi prosil nekoga, če mi lahko na hitro pove kaj pomenijo različne napetosti (3.2V, 3.6V in 3.8V) in tokovi (0.25A, 0.5A in 1.0A) polnjenja na VP2 polnilcu.
hunter01 ::
koyotee je izjavil:
GB: Ultrafire F13 http://budgetlightforum.com/node/31213 9.99$
A ni bilo rečeno, naj se karkoli "Fire" izogibamo na daleč?
koyotee ::
Ja baterij in polnilcev :)
Rear DVD collector!
JTD power!
Avenger ::
em... a kdo ve če kje znajo oživit li-ion baterije ki jim je napetost padla na 2,6V - kolikor sem bral, so te še dobre...
koyotee ::
Kaj maš zaen polnilec?
Rear DVD collector!
JTD power!
Avenger ::
Trustfire tr-06
koyotee ::
http://lygte-info.dk/review/Review%20Ch...
The charger passed a isolation test with 2500 volt, but failed a 5000 volt test, this makes the charger acceptable for 110VAC usage, but doubtful for 230VAC usage. Usage with 12 volt (in a car) is, of course, always possible and safe.
Reskiraj 39$ in kupi tole http://budgetlightforum.com/node/30515
Rear DVD collector!
JTD power!
koyotee ::
+ The actual charging works fine and terminates at the correct voltage, but the restart is placed at to high voltage, making the charger cycle on/off, instead of terminating.
This is not acceptable.
Rear DVD collector!
JTD power!
Bye ::
S čim mažete navoje svetilk?
matobeli ::
silikonska mast/olje, oringe tudi. Čeprav moram rečt da navojev ne mažem, tesnila pa z silikonsko mastjo. Ni pa treba pretiravat
simon2704 ::
končno sem tudi jaz dobil svojo Convoy C8 xml2/t6-4c/ak47 7135*8 iz banggooda. res dobra lučka,hvala za nasvet koyotee
naslednji nakup bi bil naglavna lučka, pa lučka za na bicikel v istem cenovnem/kvalitetnem rangu kot convoy c8 - ima kdo kakšno idejo?
nagledano imam sicer tudi Zebralight H600Fw MK II Floody Headlamp Neutral White, a je na nkon že več kot mesec dni out of stock, tako da bi zaenkrat mel kakšno kitajsko robo
koyotee ::
Čelke p/p za tak denar ne boš dobil. Sam imam tole http://www.ebay.com/itm/121283637409?re...
Najbolj praktično je v taki obliki, da ti ni treba nositi s seboj power packa.
Rear DVD collector!
JTD power!
Bye ::
Začetno (manično) navdušenje nad HID-om je splahnelo in - po ogledu na TiTubi - se moram strinjati s koyoteejem, da imajo tovrstne svetilke ogaben snop.
Tele mi zgledajo best p/p. In treba bo nabaviti še dodaten polnilec; v hiši bodo kmalu tri svetilke :)
1. Za "streljanje" divjadi:
TrustFire TR-J18 (8500 lm), $66
http://www.newegg.com/Product/Product.a...
odnosno
http://www.aliexpress.com/item/Sale-130...
2. Za sprehode, eleganca a la convoy S2+, samo močnejša(?):
UltraFire C6-T60 (900 lm), $17
http://www.dx.com/p/ultrafire-c6-t60-cr...
3. Polnilec Nitecore Digicharger D4
http://www.nitecore.com/productDetail.a...
Maxl ::
Mater mi gre na živce, ker ima večina svetilk stikala s 5 načini delovanja. Se da, kje dobiti stikalo oziroma, ali je možna predelava stikala, da ima samo en ali največ dva načina delovanja (HI-LOW)?
hunter01 ::
Če ima svetilka memmory mode, ti itak vedno istega vklopi nazaj. Samo ne smeš prehitro vklapljat in izklapljat, ker gre s tem na "next mode".
koyotee ::
Ni fora v stikalu, ampak v drajverju. Lahko ga sam sprogramiraš: http://budgetlightforum.com/node/5411
Tu maš primer popularnega drajverja: http://intl-outdoor.com/qlite-reva-7135... ozemljiš zvezdico po želji in to je to
Rear DVD collector!
JTD power!
  • spremenil: koyotee ()
koyotee ::
Drugače pa kupi ta polnilec za 39$ in maš mir za skos, brez kupona je cena 61$ :) http://budgetlightforum.com/node/30515
Rear DVD collector!
JTD power!
impre ::
Kja pravite pa na ta polnilec?
http://www.fasttech.com/products/1421/1...
koyotee ::
http://lygte-info.dk/review/Review%20Ch... meni osebno prepočasen in brez možnosti izbire tokov.
Najbrž najceneje tu: http://www.gearbest.com/chargers-batter...
Rear DVD collector!
JTD power!
impre ::
Verjetno za ta denar ne dobim boljšega ali pač...? Mogoče še kakšen predlog?
Tisti iz prejšnjega linka je že malce predober zame, saj toliko pa spet ne bo v uporabi.
koyotee ::
Ne, cenejšega boljšega ni. Je pa to najcenejša opcija samo za li-ion, lahko sam omejiš tok do 1A, s tem da zamenjaš upor. http://www.ebay.com/itm/1PC-New-TP4056-...
Rear DVD collector!
JTD power!
impre ::
Kaj ni bolje da se polni z manjšim tokom? Več ali manj se mi ravno ne mudi ker imam dovolj baterij na rezervi za moje potebe, tako da ima čas polniti preko noči.
koyotee ::
Za večino je priporočljivo 0,5C(C=kapaciteta). INR baterije lahko polniš z večjim tokom.
Rear DVD collector!
JTD power!
impre ::
Kaj to pomeni, da če ima baterija 2400mAh jo je treba polnit s cca. 1000-1200mA?
koyotee ::
To je max tok, minimalni ni važen, boš pač toliko več čakal.
Rear DVD collector!
JTD power!
impre ::
Ok hvala za pojasnilo, pa še nekaj novega vem in mogoče še kdo tu gor.:)
hunter01 ::
Na Gearbest še vpiši kodo:
GBFREEDOM
Za 8% popust in free poštnino
Potem pride polnilec malenkost pod 8€.
koyotee ::
Nitecore Intellicharger i4 http://www.aliexpress.com/item/-/697209... 10,51€ daleč najceneje
Rear DVD collector!
JTD power!
igor0203 ::
Kaj ni zdej še ena novejša verzija tega polnilca? Pred parimi meseci sem nekje zasledil, da pride nova verzija I2/I4.
P.S.: Na tem linku tudi nič ne piše ali je v1 ali v2
koyotee ::
To je v1, v2 je pa okoli 40€ http://www.aliexpress.com/item/Nitecore...
Rear DVD collector!
JTD power!
koyotee ::
Rear DVD collector!
JTD power!
koyotee ::
Prodam: http://m.banggood.com/Sunwayman-D40A-CR...
Nova, nerabljena, cena 45€
Rear DVD collector!
JTD power!
hunter01 ::
A so še vedno težave z dostavo Li-Ion baterij?
Sem naročil iz Banggood hkrati Convoy C8 in Sanyo 2 bateriji. C8 je pri meni že 2 tedna, baterij pa od nikoder. So mi celo že refund dali na baterije. Je kdo sedaj v kratkem uspešno prejel baterije?
koyotee ::
Js, 1 tedn nazaj. Drugače pa sm lih zasledil, da bi radi spet nekaj komplicirali glede baterij: https://www.ntsb.gov/news/2014/140522.h...
Rear DVD collector!
JTD power!
Aar2rk ::
Jaz sem tudi dobil li-ion baterije od banggooda ta mesec.
Sem pa dobil tudi pošto s carine, ker so bile ene svetilke (tudi banggood) poslane iz švice, čeprav so kot ostalo prišle s švedske.
Kako so to sčarali ne vem, sem pa zraven dobil pismo, v katerem piše, da je pošiljanje li-ion baterije prepovedano, mislil da je bilo od 1.6. naprej, razen iz sosednjih držav in Nemčije. So nevarne za letala, nenako v slogu koyotee-vega linka.
hunter01 ::
Jaz sem dobil že refund za 2 bateriji, pa bi raje videl bateriji kot pa teh 8€.
Upam, da vseeno pride paket. Naročeno je bilo 5. aprila.
c0ck4m0u53 ::
Saga z baterijami se nadaljuje:( Tole sem dobil na mail od wallbuys, kjer sem imel naročen (8. 5. 2014) in odposlan en par Panasonicovih 3.7V 3400mAh NCR18650B Protected baterij.
Dear Customer,
Thanks for your support on wallbuys and we have checked your order xxxxxxx.
Tracking number is xxxxxxxx .
Due to the restriction of China customs, we have to stop selling battery and liquid products temporarily.
The package was returned to our office today.
We will arrange refund to your Paypal account .
Please check it timely within 48 hours.
Apologize for any inconvenience this may cause and feel free to reach us if you have any problem.
Best Regards,
Eleven
Poleg omenjenega, pa imam naročenih še 7 kosov enakih baterij iz Bangooda, za katere pa še upam, da prispejo.
Zakaj Kinezi ne začnejo tega pošiljati z ladjami?
O.
koyotee ::
Bohve kje bi se zgubilo. Sej če naročiš ceu kontejner, pol ti prpelejo :)
Rear DVD collector!
JTD power!
Malo bi se organizirali, zbrali naročila in enkrat na teden poslali z ladjo v Evropo. Ne bi smel biti noben problem. Po mojem bo samo malo treba počakati, pa bodo tudi to pogruntali.
O.
koyotee ::
Fora je, da ni takega povpraševanja po tem. Kar je za industrijo pa itak pride z ladjo.
Rear DVD collector!
JTD power!
impre ::
In iz kje sedaj sploh še pošiljajo 18650 baterije, pa da ne pridejo celo premoženje?
koyotee ::
Battery Restriction Again? - shipping for DX [?], BG [?], HKE [?], TM[?], FT [X], WB [X]
Kjer je ? naj bi pošiljal
Rear DVD collector!
JTD power!
Furbo ::
Pošiljajo jih že, samo menda jih naši brihtni birokrati zavračajo, verjetno zato, da so potem še 1x nevarni letalom, ko se vračajo.
i5-13600K, Noctua NH-D15, STRIX Z790-F, 64GB DDR5, 2TB Samsung 990PRO,
koyotee ::
Nkon.nl/akkuteile.de
Treba bi blo en groupbuy nardit.
Rear DVD collector!
JTD power!
mailer ::
Pred časom sem naročil baterijo za prenosnik. Poslali so mi jo cca 14 dni pred novo uredbo o letalskih pošiljkah in je obstala na letališču. Vrnili so jim baterijo prodajalec pa meni kupnino. Pošta je bila poslana preko Swedish Post.
Hi,
We're sorry, Recently the Swedish Post announced that all items shipping by air are now subject to x-ray, screening for regulated materials.
Postal system to strengthen control of parts of the battery, resulting in longer accept batteries shipping, your parcel is returned.
jest10 ::
koyotee je izjavil:
btw, kako pa kaj tvoja bodoča štacuna? Bo ali ne?
18 / 349
