Radeon 9250 Windows 7 driver
car100 ::
Naložil sem windows 7 in vse driver-je. Zataknilo pa se je pri driver-jih od Radeon 9250. (Probal sem že kar nekaj driverjev a do sedaj je bil celoten trud zaman). Zato bi prosil vse, ki imate podobno grafično, da poveste kako ste se vi spopadli s tem problem.
Hvala, LP! :):)
  • spremenil: car100 ()
jRk0 ::
Note: AMD's DirectX 9 ATI Radeon graphics accelerators are not officially supported under Windows 7. If the user chooses to, they can install the ATI Catalyst Windows Vista graphics driver under Windows 7. Please be aware that none of the new Windows 7 graphics driver (WDDM 1.1) features are supported (as the Windows Vista level graphics driver is limited to WDDM 1.0 level support). Using the ATI Catalyst Windows Vista driver under Windows 7 is not officially supported by AMD, and as such AMD will not provide any form of customer support for users running in this configuration
od Viste driverje poisci =)
AMD (ATI) Catalyst™ (strani: 1 2 3 4 … 15 16 17 18 )
Oddelek: Zvok in slika
850155093 (65572) ferdo
Nadgradnja zelo starega računalnika
433255 (1896) Riff
Problem z novim računalnikom
181564 (1395) BALAST
CATALYST 4.1 Has Arrived!
172449 (1854) tx-z
CATALYST 3.6
Oddelek: Programska oprema
169020 (8505) freejack
