VB - kako iz Recordseta dobiti nov Recordset?
Joze_K ::
imam takole
ssql = "select * from Kontrolnik Order by Zap_st"
Set db1 = New Connection
db1.CursorLocation = adUseClient
db1.Open "PROVIDER=Microsoft.Jet.OLEDB.3.51;Data Source=Podatki\Podatki.mdb;Jet OLEDB;"
Set adoPrimaryRS1 = New Recordset
adoPrimaryRS1.Open ssql, db1, adOpenStatic, adLockOptimistic
DOBIM TABELO NA PODLAGI TEGA - ADOPRIMARYRS1
zdaj bi pa rad iz teh podatkov naredil nov query
Set NOV_SET = New Recordset
NovFilter = "Select * from Kontrolnik where [Predlagatelj] LIKE %kajo%"
KAKO DOBITI IZ PODATKOV ADOPRIMARYRS1 NA NOVO FILTRIRANE PODATKE S TEM DODATNIM PARAMETROM
npr.
NOV_SET.Open NovFilter, adoPrimaryRS1, adOpenStatic, adLockOptimistic
ALI NEKAKO TAKO, vendar kako?
ali pa sistem NESTED QUERY?
ssql = "select ("Select * from Kontrolnik where [Predlagatelj] LIKE %kajo%") from Kontrolnik Order by Zap_st"
SAMO TALE MI NE DELA, PA ZGORNJI TUDI NE... grrr
[sql]-stevilka vrstic
Oddelek: Programiranje
121512 (1375) bmandl
SQL INSERT INTO spremenljivka?
71616 (1555) jakec
ASP problemček (MDB)
Oddelek: Izdelava spletišč
61233 (1154) AndrejS
Datumski format ..?
81570 (1438) erik
Visual Basic Developer Site & Forum
262435 (2026) webblod
