Forum » Programiranje » VB - kako iz Recordseta dobiti nov Recordset?
Joze_K ::
imam takole
ssql = "select * from Kontrolnik Order by Zap_st"
Set db1 = New Connection
db1.CursorLocation = adUseClient
db1.Open "PROVIDER=Microsoft.Jet.OLEDB.3.51;Data Source=Podatki\Podatki.mdb;Jet OLEDB;"
Set adoPrimaryRS1 = New Recordset
adoPrimaryRS1.Open ssql, db1, adOpenStatic, adLockOptimistic
DOBIM TABELO NA PODLAGI TEGA - ADOPRIMARYRS1
zdaj bi pa rad iz teh podatkov naredil nov query
Set NOV_SET = New Recordset
NovFilter = "Select * from Kontrolnik where [Predlagatelj] LIKE %kajo%"
KAKO DOBITI IZ PODATKOV ADOPRIMARYRS1 NA NOVO FILTRIRANE PODATKE S TEM DODATNIM PARAMETROM
npr.
NOV_SET.Open NovFilter, adoPrimaryRS1, adOpenStatic, adLockOptimistic
ALI NEKAKO TAKO, vendar kako?
ali pa sistem NESTED QUERY?
ssql = "select ("Select * from Kontrolnik where [Predlagatelj] LIKE %kajo%") from Kontrolnik Order by Zap_st"
SAMO TALE MI NE DELA, PA ZGORNJI TUDI NE... grrr
npr.
| » | [sql]-stevilka vrsticOddelek: Programiranje | 1512 (1375) | bmandl |
| » | SQL INSERT INTO spremenljivka?Oddelek: Programiranje | 1616 (1555) | jakec |
| » | ASP problemček (MDB)Oddelek: Izdelava spletišč | 1233 (1154) | AndrejS |
| » | Datumski format ..?Oddelek: Programiranje | 1570 (1438) | erik |
| » | Visual Basic Developer Site & ForumOddelek: Programiranje | 2435 (2026) | webblod |
