C++ keylogger
C++ keylogger
Hexx ::
Po Googlu sem malo brskal o keyloggerjih za linux, pa sem naletel na tole:
Keylogging is very simple. It's all there in the kernel. You need to use module evbug (or evdev). If you modprobe evbug and do a dmesg you'll see something like this
Code:
[4298922.635000] evbug.c: Event. Dev: isa0060/serio0/input0, Type: 1, Code: 103, Value: 0
[4298922.635000] evbug.c: Event. Dev: isa0060/serio0/input0, Type: 0, Code: 0, Value: 0
[4298923.302000] evbug.c: Event. Dev: isa0060/serio0/input0, Type: 4, Code: 4, Value: 200
[4298923.302000] evbug.c: Event. Dev: isa0060/serio0/input0, Type: 1, Code: 103, Value: 1
[4298923.302000] evbug.c: Event. Dev: isa0060/serio0/input0, Type: 0, Code: 0, Value: 0
To zgleda da je nek log file v /var/log pa nevem kateri. Če bi tole našel, bi lahko naredil program v C++u program ki pretvori to obliko zapisa v berljivo. Kaj je tale modul evbug/evdev? Kako bi našel tole?
Samo za izobraževalne namene seveda>:D
Hvala,
Hexx
Ubuntu vprašanja
Oddelek: Operacijski sistemi
483383 (2132) roksson
Čudno obnašanje miške
201956 (1542) a13misko
Internet dela ali ne dela (lnux)
272559 (2228) root
ATI linux gonilnliki in resolucija
122619 (2506) roli
Predolgo nalaganje kernela
141841 (1717) BigWhale
