[C++]Kako narediti screenshot?
*ziga* ::
Zivjo zanima me kako v C++ narediti screenshot, ki ni extra velik? (torej v .jpg formatu).
Sem ze preiskal slo-tech in par drugih strani samo nisem mel se srece, da bi kaj delalo...
DubleG ::
MFC?
GA-P55M-UD2,i5,12GB RAM,Radeon HD 4850,Crucial SSD 64GB,
WD 320GB,WD 5000GB,RevoDrive X2 100GB
xyd1 ::
GDI+?
*ziga* ::
Lahko tudi z GDI samo, da dela in da exe ne bo prevec velik.
xyd1 ::
Vključiš knjižnico
#include <GdiPlus.h>
tukaj pa imaš funkcijo
ps: popravi pot kam ti naj shranjuje, če uporabljaš visto, 7, mislim da ne moreš shranjevat v c:, to funkcijo sem pobral pred časom z interneta...
void gdiscreen()
	SYSTEMTIME SysTime;
	GetLocalTime(&SysTime);
	wchar_t filename[200];
	memset(filename,0,sizeof(filename));
	wsprintfW(filename,L"C:\\screen%02d:%02d:%02d h.jpeg",SysTime.wHour,SysTime.wMinute,SysTime.wSecond);
	using namespace Gdiplus;
	GdiplusStartupInput gdiplusStartupInput;
	ULONG_PTR gdiplusToken;
	GdiplusStartup(&gdiplusToken, &gdiplusStartupInput, NULL);
		HDC scrdc, memdc;
		HBITMAP membit;
		scrdc = ::GetDC(0);
		int Height = GetSystemMetrics(SM_CYSCREEN);
		int Width = GetSystemMetrics(SM_CXSCREEN);
		memdc = CreateCompatibleDC(scrdc);
		membit = CreateCompatibleBitmap(scrdc, Width, Height);
		HBITMAP hOldBitmap =(HBITMAP) SelectObject(memdc, membit);
		BitBlt(memdc, 0, 0, Width, Height, scrdc, 0, 0, SRCCOPY);
		Gdiplus::Bitmap bitmap(membit, NULL);
		CLSID clsid;
		GetEncoderClsid(L"image/jpeg", &clsid);
		bitmap.Save(filename, &clsid);
		SelectObject(memdc, hOldBitmap);
		DeleteObject(memdc);
		DeleteObject(membit);
		::ReleaseDC(0,scrdc);
	GdiplusShutdown(gdiplusToken);
pps: več pomoči ti pa skoraj da ne morem ponudit, ker sem jo sam uporabljal in je funkcija delovala, tako da se nisem pretirano ubadal z njo.
  • spremenilo: xyd1 ()
snow ::
Z QT knjižico: http://qt.nokia.com/doc/4.0/widgets-scr...
Maš cel gui zraven za neke dodatne nastavitve.
Random mutation plus nonrandom cumulative natural selection - Richard Dawkins
*ziga* ::
@xyd1
Dobim sledec error in se mi niti ne sanja zakanj...
error C3861: 'GetEncoderClsid': identifier not found
Senitel ::
Imaš?
#include <gdiplus.h>
*ziga* ::
Ja imam ja...
xyd1 ::
Če se ne motim, moraš še v linker dodati eno komponento,... malo pobrskaj po netu.
edit našo: http://www.codeguru.com/forum/showthrea...
ammm to vključi
#pragma comment( lib, "gdiplus" )
al pa v linker (odvisno od programa - devcpp, ms c++),.. citiram:
To compile and link the code, you need to add the gdiplus.lib to Project Properties->Linker->Input->Additional Dependencies. Or you can put the below pragma in source code.
*ziga* ::
Sem probal vstavit oboje ampak error ostaja isto :(
Uporabljam Visual Studio 2008.
W3by ::
Tukaj imaš mankajočo funkcijo (ni problem v knjižnici):
http://msdn.microsoft.com/en-us/library...
  • spremenil: W3by ()
*ziga* ::
Zdaj dobim se vec errorjev...
(52) : error C2065: 'ImageCodecInfo' : undeclared identifier
(52) : error C2065: 'pImageCodecInfo' : undeclared identifier
(54) : error C3861: 'GetImageEncodersSize': identifier not found
(58) : error C2065: 'pImageCodecInfo' : undeclared identifier
(58) : error C2065: 'ImageCodecInfo' : undeclared identifier
(58) : error C2059: syntax error : ')'
(59) : error C2065: 'pImageCodecInfo' : undeclared identifier
(62) : error C2065: 'pImageCodecInfo' : undeclared identifier
(62) : error C3861: 'GetImageEncoders': identifier not found
(66) : error C2065: 'pImageCodecInfo' : undeclared identifier
(66) : error C2228: left of '.MimeType' must have class/struct/union
(68) : error C2065: 'pImageCodecInfo' : undeclared identifier
(68) : error C2228: left of '.Clsid' must have class/struct/union
(69) : error C2065: 'pImageCodecInfo' : undeclared identifier
(74) : error C2065: 'pImageCodecInfo' : undeclared identifier
  • spremenil: *ziga* ()
kje zaceti z c++ ?
Oddelek: Programiranje
324360 (2668) Monster
Visual C++ 6.0 - enostaven FTP client
61445 (1239) Monster
Kako uporabiti to funkcijo [c++]
51295 (1231) StratOS
DevC++ težava?
182036 (1904) Gundolf
Win32 Console Project
61227 (1175) Fury
