Forum » Programiranje » c++ fibonacci
c++ fibonacci
bigbada ::
#include <iostream>
#include <stdlib.h>
using namespace std;
int main()
int n;
int z;
int f=0,f1=1,f2=1;
cout<<"Vpisi z-zacetni element zaporedja: ";
cin>>z;
cout<<"Vpisi n-zadnji element Fibonacci-jevega zaporedja: ";
cin>>n;
for(int i=z; i<=n; i++) //for zanka ki teče od vnešenega začetnega elementa do n-zadnjega
f=f1+f;
f1=f2;
f2=f;
cout<< "f ( " <<i<<" ) = "<<f<<endl;
system("Pause");
return 0;
Zanima me, kako naj naredim, da mi bo delovalo za vnesen interval?
ker sedaj mi ne deluje.. rad bi da recimo vnesem zacetek z=3, konec n=6
pa da izpise 3,4,5,6 clen zaporedja..
torej 2,3,5,8
ne rabim kode, samo kaki namig kaj naj naredim?
- spremenilo: bigbada ()
snow ::
Namig: Računaj vse člene od 1 do n, izpisuj pa samo tiste, ki so večji ali enaki z.
Random mutation plus nonrandom cumulative natural selection - Richard Dawkins
DavidJ ::
Za optimalen izračun priporočam tole.
"Do, or do not. There is no 'try'. "
- Yoda ('The Empire Strikes Back')
boogie_xlr ::
Programiranje 2 prva naloga.
Očitno so nekateri res spali pr Žumeru.
- spremenil: boogie_xlr ()
c0dehunter ::
Baje je pri Žumerju res težko ne-spat.
I do not agree with what you have to say,
but I'll defend to the death your right to say it.
boogie_xlr ::
Upam, da ste vsaj pr prog2 bili budni, ker objektnega programiranja pa res ne smete zamudit
je pa hecno ko nam predava iz amerike heh
krneki0001 ::
Tole je za eno cifro.
#include <iostream>
long fib_num ( long );
int main()
long num = 0;
long sequence = 0;
cout << " Enter a positive number and I will compute the <strong class="highlight">Fibonacci</strong> sequence for that number: ";
cin >> num;
if ( num < 0)
{ cout << " Number must be greater than zero " << endl;
return 1;
cout << endl << endl;
sequence = fib_num(num);
cout << " The " << num << "th number of the <strong class="highlight">Fibonacci</strong> sequence is " << sequence << endl;
return 0;
long fib_num ( long n)
if ( n == 0)
return 0;
else if ( n == 1 )
return 1;
else
return fib_num( n -1) + fib_num(n-2);
} Zgodovina sprememb…
- spremenilo: krneki0001 ()
| » | [C] Sinhronizacija procesovOddelek: Programiranje | 1538 (1411) | Cvenemir |
| » | [C] ProcesiOddelek: Programiranje | 1298 (1207) | Cvenemir |
| » | [NALOGA][C] - Sortiranje učencevOddelek: Programiranje | 1691 (1544) | m4r3 |
| » | Dev-C++ in napaka pri prevajanju funkcijOddelek: Programiranje | 1428 (1277) | MartnKrp |
| » | srand in program v Cju???Oddelek: Programiranje | 1901 (1771) | nuclear |
