Izvirne misli.
Izvirne misli.
Azz_Kikr ::
Pristavite svojo, če poznate kakšno...
Vedno je bolje obžalovati nekaj, kar si storil, kot pa nekaj, česar nisi.
You can't possibly hit the ball if you're thinking about all the possible ways you can miss.
Tudi kapljica izdolbe kamen, ne s silo, temveč z nenehnim padanjem.
Nekoga popolnoma imeti je najboljse; ce pa to ni mogoce, tedaj je najboljse da ga popolnoma izgubimo.
Kdor misli, da je kristjan, ker hodi v cerkev, se moti, saj tudi človek še ni avto, če stoji v garaži.
Nobena oseba ni vredna solz; tista, ki pa jih je, pa te do solz sploh ne bo pripravila.
Lp, Azz_Kikr
If sometimes you feel yourself little, useless, offended and depressed, always remember that you were once the fastest and most victorious sperm in your group!
Lucas ::
Shit happens!
I was here...
Tomi ::
Moj podpis:
However, things can only get better..
metrodusa.blogspot.com
Yohan del Sud ::
Moj življenepis:
Rodil sem se tega pa tega... Zeblo me je, bleščeče luči so svetile vame... Drl sem se na vse grlo... Počutil sem se ko eno govno...
No od takrat naprej gre vse samo še na slabše...
DavidJ ::
Moramo verjeti v svobodno voljo. Nimamo izbire!
"Do, or do not. There is no 'try'. "
- Yoda ('The Empire Strikes Back')
Thomas ::
Nobene druge izbire nimamo, kot da se odrečemo koncepta svobodne volje. :D
jamiroq ::
Wise man once say:
"Arguing on internet is like competing in special olympics: even if you win, you still retarded."
Thomas ::
Would you argue, that he was wise? :D
Zneska je edina nesreca, ki pride cez prag in most.
jest dost dobr?:\
Wolfram ::
Tomorrow never dies!
Never say never again!
www.igralec.com
DavidJ ::
"There are two places only where socialism will work, in heaven where it is not needed, and in hell where they already have it."
- Whinston Churchill
"People demand freedom of speech to make up for the freedom of thought which they avoid. "
- Soren Aabye Kierkegaard (1813-1855)
I was talking during sex and my girlfriend hung up
I'm not rude, I'm "attitudinally challenged".
If a person with multiple personalities threatens suicide should it be considered a hostage situation?
Our lips touched, then she crossed her legs and broke my glasses.
JurijTurnsek ::
The only constant is change.
http://www.slatnaskejta.com
||_^_|| ::
Vsi boste enkrat umrli.
Tero ::
10 ZAPOVEDI
(1) Delo je napor.
(2) Rodili smo se utrujeni in zivimo zato, da pocivamo.
(3) Pocivaj podnevi, da bos lahko ponoci spal.
(4) Ljubi svojo posteljo bolj, kakor samega sebe.
(5) Ce vidis koga, ki pociva, mu pomagaj.
(6) Od prevelikega pocivajna ni se nihce umrl.
(7) Ne delaj danes, kar lahko prelozis na jutri.
(8) Nikoli ne delaj tistega, kar delajo drugi.
(9) Delaj kolikor zmores in tisto kar zmores prepusti drugim.
(10) Ce te prime, da bi delal, sedi in pocakaj, da te mine
Thomas ::
Koliko tehta dim? (>:D )
Stehtajte drva in potem pepel. Razlika je teža dima. [8-) ]
Matek ::
My favourite:
Nije žvaka za seljaka.
:D
kuglvinkl ::
Ko smo že pri kmetih:
Može seljak iz sela, al' ne može selo iz seljaka.
Cange ::
Po več desetletjih modificiran naslov pesmi:
Pesem Krastač trnovk :)).
Ladjar ::
Rodil sem se bos kot ti,hoditi bos kaže da hodiš ti bos in puščaš na svetu svojo plat in svoj odtis na reliefu Zemljske zgodovine.
Če pa hodiš v športnih copatih pa ne puščaš sledi svoje ampak sledi morda Nike športnih copat. Tebe pa na tistem pohodnem kraju ni bilo bil je namreč športni copat.
Če invalidski voziček ima 4 koleščka in en sedež in na njem sedi človek brez nog ali pa jih ne zmore uporabljati, kakšna je razlika potem med avtom,ki ima 4 kolesa in več sedežev, pa v njem sedi oseba ki ima noge ampak jih ne uporablja? A ni oseba v obeh primerih invalid?
Bi zamenjali svoje noge za najnovejši Lamborgini invalidski voziček?
It's ok to be white.
Slopek ::
Zdaj je svoboda, moramo biti tiho! :)
Ladjar ::
V tišini je NEMIR
Nihče ni neuporaben, saj tudi najslabšega človeka lahko uporabim za zgled, da pokažem otroku, kakšen ne sme biti v življenju.
dronyx ::
Tule cela moja Zb(i)rka misli, če se ti ljubi prebrat. Ali so izvirne pa težko sodim.
Ladjar ::
dronyx je izjavil:
Lepa zbirka,ki kaže na aktiven in ne mračen um.
showsover ::
Assumption is mother of all f*ckups.
Previdnost je mati modrost.
Ampak, če bi previdnost bila tako previdna ne bi postala mati :))
Hec: otroci so pravi zaklad!
dronyx: super zbirka. Bom prebral vse. Tista o pregrešnih mislih je zelo dobra. Bom pa prebral vse.
avom23 ::
Misel z zadnjega AIDEA podkasta:
"Ne se boriti proti zlu. Bolj kot se z zlom ukvarjamo, več kot mu namenjamo pozornosti, bolj narašča..."
Misel Boruta S. Pogačnika, ko povzema eno od iztočnic avtorja Martina Kojca
18:15 (m.youtube.com/watch?v=f7xM2NYr3BA
kuall ::
Zakaj so vsi psi tako veseli?
Zato ker smo ljudje na njih naredili umetno selekcijo, depresivne pobili, vesele obdržali.
Nekaj podobnega delajo ljudje z ljudmi. Veseli ljudje so popularni, depresivnih noben ne mara.
veteran ::
"Vsi umremo. In če moram umreti, bom umrl pokončno kot človek in ne kot izoliran garjav pes, zaprt v pesjaku, z nagobčnikom na obrazu, čipiran kot govedo, gensko spremenjen kot koruza ter v strahu pred sočlovekom." - Anton Komat
Gagatronix ::
"Da je Jugoslavija bila sto puta gora nego što je bila, još uvijek bi bila sto puta bolja nego sve šta je nakon nje nastalo."
--Avdo Sidran
Šimpanz ::
Kot je rekel Albert Einstein. Ne verjamite vsega kar piše na internetu.
Vesolje in človeška neumnost sta brezmejna. Za vesolje sicer nisem čisto prepričan. Albert Einstein.
Vsako osebo boš enkrat zadnjič videl nasmejano in polnega zdravja.
urbybaby ::
Vsi enaki, vsi enakopravni. Eni bolj, drugi manj.
Kamena doba se ni končala, ker bi zmanjkalo kamenja...
janezvalva ::
Kdor drugemu z lopato jamo koplje, je bolj nizka.
A. Smith ::
Starodavni Kitajski pregovor:
Pes, ki laja,
JE PREMALO KUHAN.
________________________________
Življenje je podobno vožnji s kolesom; da bi ohranili ravnovesje, se moramo nenehno gibati. (A. Einstein)
"Be professional, be polite,
- General James Mattis
Citati, ki vam kaj pomenijo (strani: 1 2 3 4 5 )
Oddelek: Sedem umetnosti
22659498 (10068) yansek
Najmehkejši tekaški copati (strani: 1 2 )
Oddelek: Šport
8324890 (22841) GenZNPC
Vse je energija
418050 (6504) Truga
Iskanje ideje.
Oddelek: Programiranje
448330 (6333) boolsheat
Zogobrc pa ne football ampak vseeno zogobrc :| (strani: 1 2 )
534453 (3725) urkoman
