Forum » Programska oprema » chrome-win7
chrome-win7
c00L3r ::
Javi, da ne gre namestit? Potem pa te Google napoti na stran, kjer piše, da moraš nekaj v registru spremenit?
Airskull ::
1. Go to Start > Run.
2. In the window that appears, enter "regedit" and click OK.
3. Navigate to the following directory in your registry:
- For Windows 7: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\State
- For Vista: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\State
- For XP: HKEY_LOCAL_MACHINE\System\Setup
4. Once you've pasted the value into your response, right-click the registry key and select Modify...
5. Delete the value and click OK.
Every word of this is a lie, and my readers should put no trust in it at all.
| » | Undo za ComboFixOddelek: Pomoč in nasveti | 2419 (2184) | MrStein |
| » | Obnovitev sistema ne delujeOddelek: Pomoč in nasveti | 2491 (2425) | mpucko6 |
| » | Windows Security Warning - mi bo požru živce!Oddelek: Operacijski sistemi | 2350 (2043) | veteran |
| » | Ikone w widows xp so izginile !!!Oddelek: Pomoč in nasveti | 2519 (2237) | K0K0 |
| » | TrojancOddelek: Omrežja in internet | 1937 (1728) | BigWhale |
