chrome-win7
chrome-win7
jveligov ::
Zakaj ne morem namestiti brskalnika chrome na windows 7 ?
Tr0n ::
Kaj ti pa napise?
Jaz laufam Chrome na W7 brez problema.
c00L3r ::
Javi, da ne gre namestit? Potem pa te Google napoti na stran, kjer piše, da moraš nekaj v registru spremenit?
Aston_11 ::
Airskull ::
1. Go to Start > Run.
2. In the window that appears, enter "regedit" and click OK.
3. Navigate to the following directory in your registry:
- For Windows 7: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\State
- For Vista: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\State
- For XP: HKEY_LOCAL_MACHINE\System\Setup
4. Once you've pasted the value into your response, right-click the registry key and select Modify...
5. Delete the value and click OK.
Every word of this is a lie, and my readers should put no trust in it at all.
Undo za ComboFix
182419 (2184) MrStein
Obnovitev sistema ne deluje
52491 (2425) mpucko6
Windows Security Warning - mi bo požru živce!
Oddelek: Operacijski sistemi
112350 (2043) veteran
Ikone w widows xp so izginile !!!
202519 (2237) K0K0
Trojanc
Oddelek: Omrežja in internet
131937 (1728) BigWhale
