Forum » Programiranje » [C#] textbox to .txt file
DuleKrtola ::
Tale koda ob kliku na gumb shrani tekst iz RichTextBox v .rtf file. Mene zanima koda, ki shrani text iz navadnega textboxa (NE RICH TEXT) v .txt file
Mene zanima koda, ki shrani text iz navadnega textboxa (NE RICH TEXT) v .txt file, in koda za odpret file. Se pravi, kako bi zgledala ukaza
richTextBox1.LoadFile(OpenDialog.FileName);
richTextBox1.SaveFile(SaveDialog.FileName);
za TextBox1?
private void button2_Click(object sender, EventArgs e)
SaveFileDialog SaveDialog = new SaveFileDialog();
SaveDialog.Title = "Save";
try
if (SaveDialog.ShowDialog() == System.Windows.Forms.DialogResult.OK)
catch (Exception ex)
za TextBox1?
- spremenil: DuleKrtola ()
DuleKrtola ::
OPEN
SAVE
EDIT: includat je treba tele (kšn je mogoče odveč...:)
private void button1_Click(object sender, EventArgs e)
OpenFileDialog OpenDialog = new OpenFileDialog();
OpenDialog.Title = "Open";
OpenDialog.Filter = "All Files|*.*";
try
if (OpenDialog.ShowDialog() == System.Windows.Forms.DialogResult.OK)
System.IO.StreamReader objReader;
objReader = new System.IO.StreamReader(OpenDialog.FileName);
textBox.Text = objReader.ReadToEnd();
objReader.Close();
catch (ArgumentException ex)
MessageBox.Show("Invalid File Format");
SAVE
try
StreamWriter sw = new StreamWriter(SaveDialog.FileName);
String[] contents = textBox.Lines.ToArray();
for (int i = 0; i < contents.Length; i++)
sw.WriteLine(contents[i]);
sw.Close();
}EDIT: includat je treba tele (kšn je mogoče odveč...:)
using System; using System.Collections.Generic; using System.ComponentModel; using System.Data; using System.Drawing; using System.Linq; using System.Text; using System.Windows.Forms; using System.IO;
darkolord ::
Namesto tega
Lahko kar
sw.Close();
Lahko kar
StreamWriter sw = new StreamWriter(SaveDialog.FileName); sw.Write(textBox.Text); sw.Close();
| » | [c#] iz class v classOddelek: Programiranje | 1224 (1098) | darkolord |
| » | [c#] savefiledialog, en sfd a več datotekOddelek: Programiranje | 1073 (1001) | darkkk |
| » | [c#] shrani text, tabele, slikeOddelek: Programiranje | 2010 (1616) | Kemalito |
| » | C# text v .pdfOddelek: Programiranje | 1787 (1576) | japol |
| » | [VB] OpenOddelek: Programiranje | 1963 (1802) | Monster |
