[Java] Povezovanje do MySQL baze
Pawle ::
Program mi javi napako: "java.lang.ClassNotFoundException: com.mysql.jdbc.Driver"
Baza je lokalana, XAMPP 1.7.1, MySQL 5.1, NetBeans 6.8. Program je iz nekega tutoriala.
V Services se mi brez problema poveže do baze. Connector je shranjen tu:
"C:\Program Files\NetBeans 6.8\ide12\modules\ext\mysql-connector-java-5.1.6-bin.jar"
in Driver je v njem. V čemu je torej problem.
package baze;
import java.sql.*;
public class Main {
    public static void main(String[] args) {
        Connection conn = null;
        try{
            String userName = "pawle";
            String password = "geslo";
            String url = "jdbc:mysql://localhost/cms";
            Class.forName ("com.mysql.jdbc.Driver");
            conn = DriverManager.getConnection (url, userName, password);
            System.out.println ("Database connection established");
        catch (Exception e){
            System.err.println ("Cannot connect to database server");
            e.printStackTrace();
        finally{
            if (conn != null){
                try{
                    conn.close ();
                    System.out.println ("Database connection terminated");
                catch (Exception e) { /* ignore close errors */ }
Tr0n ::
Tega "mysql-connector-java-5.1.6-bin.jar" ti ne najde.
Pawle ::
Mene me zanima zakaj mi ga ne najde ko pa obstaja.
Tr0n ::
Ni na pravi lokaciji verjetno. Mora bit del -classpatha ko se zadeva kompajla.
Pawle ::
Mi lahko razlošiš kaj je classpath in kaj moram naredit.
Android+mySql težava
Oddelek: Programiranje
91517 (1269) abcd123
Netbeans + Access
51037 (966) Napoleon II
[java] uporaba baze .mdb z javo
51962 (1877) gtu
[JAVA] mysql-connector-java in povezava z Mysql
92502 (2384) Sergio
java in zapis v podatkovno bazo
72398 (2266) jogurtTM
