Forum » Programiranje » [Java] Povezovanje do MySQL baze
Pawle ::
Program mi javi napako: "java.lang.ClassNotFoundException: com.mysql.jdbc.Driver"
Baza je lokalana, XAMPP 1.7.1, MySQL 5.1, NetBeans 6.8. Program je iz nekega tutoriala.
V Services se mi brez problema poveže do baze. Connector je shranjen tu:
"C:\Program Files\NetBeans 6.8\ide12\modules\ext\mysql-connector-java-5.1.6-bin.jar"
in Driver je v njem. V čemu je torej problem.
package baze;
import java.sql.*;
public class Main {
public static void main(String[] args) {
Connection conn = null;
try{
String userName = "pawle";
String password = "geslo";
String url = "jdbc:mysql://localhost/cms";
Class.forName ("com.mysql.jdbc.Driver");
conn = DriverManager.getConnection (url, userName, password);
System.out.println ("Database connection established");
catch (Exception e){
System.err.println ("Cannot connect to database server");
e.printStackTrace();
finally{
if (conn != null){
try{
conn.close ();
System.out.println ("Database connection terminated");
catch (Exception e) { /* ignore close errors */ }
} Vredno ogleda ...
| » | Android+mySql težavaOddelek: Programiranje | 1517 (1269) | abcd123 |
| » | Netbeans + AccessOddelek: Programiranje | 1037 (966) | Napoleon II |
| » | [java] uporaba baze .mdb z javoOddelek: Programiranje | 1962 (1877) | gtu |
| » | [JAVA] mysql-connector-java in povezava z MysqlOddelek: Programiranje | 2502 (2384) | Sergio |
| » | java in zapis v podatkovno bazoOddelek: Programiranje | 2398 (2266) | jogurtTM |
