joomla@windows 7
joomla@windows 7
DuleKrtola ::
Lotil sem se instalacije joomle po tem tutorialu, ki je sicer za win xp. V glavnem, instaliral sem apache, php in mysql.
Po končanem postopku lahko v browserju odprem instalacijo joomle
http://localhost/joomla/installation/index.php
Ko probam v 1. koraku izbrati jezik in kliknem next, mi javi tole
An error has occurred.:
Cookies do not appear to be enabled on your browser client. You will not be able to install the application with this feature disabled. Alternatively, there could also be a problem with the server's session.save_path. If this is the case, please consult your hosting provider if you don't know how to check or fix this yourself.
Se pravi, da je vzrok session.save_path. (korak 40 v linkanem tutorialu).
Ima kdo kako idejo kako odpravit napako? Kak drug tutorial?
bluefish ::
pa imaš to mapo, ki je določena pri session.save_path, ustvarjeno?
DuleKrtola ::
LOL, lihkar ugotovil da ne
omg :)
Prijavljeni uporabniki
Oddelek: Izdelava spletišč
61332 (1150) neoserv
težave z joomlo!
Oddelek: Omrežja in internet
91169 (1007) AndrejS
Težave z MySQL povezavo
293387 (2992) la_mer
php funkcija
212184 (1917) simon
IIS in PHP
82497 (2372) rocki_
