7zip - izginil disk
7zip - izginil disk
twom ::
Imel sem 5GB free diska (prenosnik 75 GB).
Zipam ogromen folder (6GB) na mrežo. Prekinem nekje na polovici. Ponovim vajo še enkrat na lokalni disk.
Po prekinitvi mi ostane še 1.5 GB diska free! Po restartu stanje nespremenjeno.
Na račun "cluster size" izgubim nekje 700 MB (v najslabšem primeru 1.4 GB) ...
Xp in Total Commander iskalnik ne najde ničesar spornega (iskal sem datoteke večje od 100 MB)
Tudi chkdsk c: /f ne pomaga.
C:\WINDOWS\system32>chkdsk c:
The type of the file system is NTFS.
WARNING! F parameter not specified.
Running CHKDSK in read-only mode.
CHKDSK is verifying files (stage 1 of 3)...
File verification completed.
CHKDSK is verifying indexes (stage 2 of 3)...
Index verification completed.
CHKDSK is recovering lost files.
CHKDSK is verifying security descriptors (stage 3 of 3)...
Security descriptor verification completed.
CHKDSK is verifying Usn Journal...
Usn Journal verification completed.
CHKDSK discovered free space marked as allocated in the
master file table (MFT) bitmap.
Correcting errors in the Volume Bitmap.
Windows found problems with the file system.
Run CHKDSK with the /F (fix) option to correct these.
78051802 KB total disk space.
69394832 KB in 361917 files.
125436 KB in 48653 indexes.
0 KB in bad sectors.
563090 KB in use by the system.
65536 KB occupied by the log file.
7968444 KB available on disk.
4096 bytes in each allocation unit.
19512950 total allocation units on disk.
1992111 allocation units available on disk.
C:\WINDOWS\system32
Program TreeSize: manjka cca 6.7 GB hardiska (74.4 - 7.59 free - 60.15 treesize = 6.66 manjkajočega) !?
Kako najdem/sprostim zaseden disk?
Lep pozdrav,
Peter
  • spremenil: twom ()
dfajt ::
Za iskanje porabljenega diska uporabljam spaceMonger, ki grafično prikaže zapolnjenost:
http://www.sixty-five.cc/sm/v1x.php
kixs ::
Tole bi pomenilo, da imas dobrih 7GB fraj.
twom ::
Pardon, pozabil sem povedati, da sem po backup-u tisti 6GB folder izbrisal.
Lp,
Peter
Problem z ramom ali diskom? Prosim za nasvet.
111578 (1480) Duhec
težava z računalnikom (počasno delovanje, brenči...)
162383 (2037) legendary
Problem z diskom 1TB
83209 (2299) bibip
Težave z diskom - consistency
71557 (1454) ender
Par problemov z XPji
Oddelek: Operacijski sistemi
343099 (2345) Mercier
