Forum » Pomoč in nasveti » 32 bitni Autocad 2008 na 64 visto?
pluto1457 ::
imam težavo, imam 32 bitni autocad 2008, ki ga želim namestiti na 64 bitno visto, pa me ne spusti preko instalacije.
ima kdo idejo, da bi ga lahko instaliral?
nujno rabim...
lp rajko
nujno rabim...
lp rajko
bastadu ::
Poleg 32bitnega bi moral dobiti tudi DVD s 64 bitnim Autocadom, tako da ne vidim problema ...
nejcek74 ::
ok recimo, da imaš legalno kupljeno verzijo 2008, ki še ni imela inštalacije za x64:
1. Download and install Orca from Microsoft.
2. Copy the installation files to your hard drive or a network folder.
3. Backup the files ACA.msi and Setup.ini
4. Edit the ACA.msi with Orca and delete the action found in the table
"InstallExecuteSequence" that is called "CheckFor64BitOS" Delete the same
line under table "CustomAction"
5. Save and close the ACA.msi
6. Edit the Setup.ini with Notepad. Delete the line under
"#==================== Platform Requirement" that is labeled
"PLATFORM=NO_WOW_64_PROCESS"
7. Double-click the Setup.exe and you should be able to install without any
problems.
8. Some support paths under the "Files" tab of the configuration dialog box
have incorrect paths. The installer adds and extra "\AppData\AppData" to
some support paths located in the user profile. For example the Main
Customization File's path is listed as
"C:\Users\%username%\AppData\AppData\AppData\Roaming\Autodesk\ACD-A
2008\enu\Support\ADT" when it should be
"C:\Users\%username%\AppData\Roaming\Autodesk\ACD-A 2008\enu\Support\ADT"
Fix the incorrect paths, hit apply, and you are good to go.
problems.
pluto1457 ::
hvala za info...mi lahko kdo napiše bolj po domače...ne štekam dobro..
rabil bi pa nujno ker nujno rabim autocad...delo mi pa stoji...
thx
thx
amigo_no1 ::
googlaj za "Orca msi"
odpri ACA.msi v orca in zbriši pogoj za 64bitnost ("CheckFor64BitOS")
dalje po spisku
Tole podjetje je ziher sp.In acad z travnika.Pa programje nameščate med delovnim časom in nimate pojma kaj delate.Res super.
Drugače resne firme uporabljajo tehnično podporo strankam in nameščajo softver **ne med delovnim časom** -> btw basic.si in podobni jo izvajajo..
dalje po spisku
- spremenilo: amigo_no1 ()
markovsky90 ::
Ja, mim setupa s temi navodili že prideš, samo pa med inštalacijo samega autocada javi error: CheckFor64OS. A ve kdo, kaj storiti?
| » | Thunderbird - arhiv, backup?Oddelek: Pomoč in nasveti | 3107 (2423) | gddr85 |
| » | Težave z odpiranjem programaOddelek: Pomoč in nasveti | 5305 (4741) | konspirator |
| » | Zgodovina iskanja (internet)-WindowsOddelek: Pomoč in nasveti | 1546 (1401) | Sara100 |
| » | Undo za ComboFixOddelek: Pomoč in nasveti | 2428 (2193) | MrStein |
| » | Kam se shranijo zaznamki v Mozilla FirefoxOddelek: Programska oprema | 2597 (2205) | PARTyZAN |
