Dell 2209WA - dober za gaming?
BuBBle.D ::
Pozdravljeni!
Zanima me kako se obnese tale monitor v igrah? Rabil bi en 22" monitor, ki bo primarno uporabljan za igra. Naj ima 0 ghostinga in čim manj input lag-a. Ta dva kriterija sta najpomembnejša. Prikaz barv mi niti ni tako pomemben.
Zapičil sem se v tega della, ker sem o njem slišal le dobre stvari. Torej potrebujem mnenje od oseb, ki so o LCD-jih bolj podkovani od mene, saj o njih praktično ne znam skorajda nič. Edino vem, da je tale e-IPS matrika boljša od TN matrik.
Prosim za strokovno mnenje.
Lahko mi priporočate tudi drug 22" monitor tja do 300€.
Hvala in lep pozdrav.
|MSI MPG Z690 EDGE|Intel Core I7-13700K|Asus RoG RTX5090 Astral|
|64GB Viper Steel 3600Mhz|2TB+3x1TB Kingston KC3000|ROG Falchion Ace HFX KB|
|ASUS TUF GT502|Gigabyte 1600W|LG OLED 32GS95UE-B 4K/240hz 2K/480hz|
kmetek ::
"As an overall monitor, I would recommend the Dell by a country mile. It uses a better panel technology (eIPS) compared to the TN in the Samsung. It has fantastic image quality and viewing angles compared to the samsung and comes with dell's lovely 3 year "next working day replacement" program and a "premium pixel guarantee".
However, for purely gaming, the Samsung is probably the better screen. This is mainly due to the 120Hz technlogy which makes gaming very similar to on a CRT and you are able to make use of Nvidia's (rather good actually) 3D vision technology.
Neither monitor has any noticeable ghosting or input lag.
Therefore, if you think the gaming benefits of the samsung beat the general use benefits on the dell, then definitely get the samsung. However, I would (and did) pick the dell and I am very happy I did."
Življenska doba monitorja (strani: 1 2 )
5110468 (8450) dela
nakup očesu prijaznega LCD monitorja
447095 (5560) adisitko69
LCD in 60hz v igrah -> :s
101481 (1481) Matev
Igre in širokozaslonski 16:9 ekrani
Oddelek: Igre
353174 (2297) Jaffa
