Linux ter JDBC driver
boss-tech ::
Sem bolj nov na linux os in bi rad vzpostavil povezavo z mysql bazo... uporabljam javo, mysql sem že inštaliral, sedaj rabim samo še ta jdbc, vendar ne vem kako naj ga inštaliram oz nastavim:
Connection con = null;
try {
Class.forName("com.mysql.jdbc.Driver").newInstance();
con = DriverManager.getConnection("jdbc:mysql:///test",
"root", "secret");
if(!con.isClosed())
System.out.println("Successfully connected to " +
"MySQL server using TCP/IP...");
} catch(Exception e) {
System.err.println("Exception: " + e.getMessage());
} finally {
try {
if(con != null)
con.close();
} catch(SQLException e) {}
Dobim pa:
Exception: com.mysql.jdbc.Driver not found in gnu.gcj.runtime.SystemClassLoader...
KaRkY ::
Mislim da ti manka jdbc driver za mysql. Najdeš ga na tem linku
Android+mySql težava
Oddelek: Programiranje
91516 (1268) abcd123
Netbeans + Access
51037 (966) Napoleon II
Java - uvoz XML in izvoz v MySQL pomoč
373712 (3049) igor0203
[JAVA] mysql-connector-java in povezava z Mysql
92502 (2384) Sergio
java in zapis v podatkovno bazo
72398 (2266) jogurtTM
