Forum » Pomoč in nasveti » Čudn email - Mail delivery failed
milosm ::
Mi lahko nekdo prosim razloži tole:
This message was created automatically by mail delivery software (Exim).
A message that you sent could not be delivered to one or more of its
recipients. This is a permanent error. The following address(es) failed:
nek@email.com
This message has been rejected because it has
a potentially executable attachment footer.scr
This form of attachment has been used by
recent viruses or other malware.
If you meant to send this file then please
package it up as a zip file and resend it.
------ This is a copy of the message, including all the headers. ------
------ The body of the message is 121823 characters long; only the first
------ 102400 or so are included here.
Return-path:
Received: from vo110-70.dial-up.volja.net ([217.72.70.110] helo=Sxekgbmck)
by moj.host.net with smtp (Exim 3.35 #1)
id 17OOxu-0000Px-00
for nek@email.com; Sat, 29 Jun 2002 22:37:06 +0200
To: nek@email.com
Subject: A IE 6.0 patch
MIME-Version: 1.0
Content-Type: multipart/alternative;
boundary=Tb473U007Uk9S31242Mt21SGF73
Message-Id:
Date: Sat, 29 Jun 2002 22:37:06 +0200
--Tb473U007Uk9S31242Mt21SGF73
Content-Type: text/html;
Content-Transfer-Encoding: quoted-printable
(HTML>(HEAD>(/HEAD>(BODY>
(FONT>Hi,This is a IE 6.0 patch
I wish you would enjoy it.(/FONT>(/BODY>(/HTML>
Content-Type: application/octet-stream;
name=footer.scr
Content-Transfer-Encoding: base64
Content-ID:
TVqQAAMAAAAEAAAA//8AALgAAAAAAAAAQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAA2AAAAA4fug4AtAnNIbgBTM0hVGhpcyBwcm9ncmFtIGNhbm5vdCBiZSBydW4gaW4g
RE9TIG1vZGUuDQ0KJAAAAAAAAAAYmX3gXPgTs1z4E7Nc.......
Če js prav razumem, dobiš tako sporočilo ko pošlješ nek email in ga ni bilo mogoče dostavit. Js tega email nisem poslal. To se mi zgodi večkrat in vedno je nek drug email prikazan. Uporabljam Norton antiviru, virus definitions updejtam vsak teden tako, da težko, da je virus.
Naj mi nekdo razloži tole vse skupaj.
Hvala.
p.s. Se opravičuje, ker je tabelo raztegnal.
nek@email.com
Return-path:
id 17OOxu-0000Px-00
To: nek@email.com
MIME-Version: 1.0
Message-Id:
name=footer.scr
Content-ID:
Hvala.
- spremenil: milosm ()
mh8759a ::
maš kakšen smtp server na katerem imaš nastavljeno pošiljanje NDR-ov(nondelivery reports) na tvoj email naslov? najverjetneje je nekaj v zvezi s tem, skratka nek smtp server te mora imeti notri, da se vsa NDR sporočila pošljejo tudi na tvoj naslov, čeprav originalnega emaila v bistvu nisi ti poslal..
lp,
Marko
lp,
Marko
ender ::
Gre za to, da je en virus poslal s tvojim naslovom kot naslovom izvora, nakar ga je MTA pri prejemniku zavrnil. Ker je virus naredil tako, da je izgledalo, kot da sporočilo prihaja od tebe, je pismo vrnil na tvoj naslov. To ni nič takega, jaz sem enkrat v 4 dneh dobil 190 takih sporočil.
Gandalfar ::
pomojem da nima virusa.. samo smolo.
ender ::
Quickfire: če uporabljaš volja.net, preveri svoj računalnik še s kakšnim drugim antivirusnim programom (prej nisem dovolj dobro pogledal glav sporočila, v njih se vidi, da je bilo sporočilo poslano iz volja.net)
Kaboom ::
ja fak ne, ima ender verjetno prav, meni se je teden dni dogajalo da sem dobival take undelivered majle, kot da sem jaz na čudne naslove pošiljal... potem pa so sami nehali, v tem času sem pa popizdoval ker sem mislil da mam virus ki ga očitno noben program ne najde...
Če se zatakne - pritisni močneje. Če se zlomi - bil je skrajni čas za nakup novega.
| » | Poslijanje majla preko SMTP (IIS); kako?Oddelek: Omrežja in internet | 2140 (2057) | Microsoft |
| » | Vsak dan virus (Beagle) iz istega naslovaOddelek: Programska oprema | 2185 (2020) | darkolord |
| » | Siol does it again (strani: 1 2 3 4 )Oddelek: Novice / Omrežja / internet | 20716 (20716) | Bakunin |
| » | e-mail z virusom...od kod?Oddelek: Omrežja in internet | 2273 (2018) | SubOrbit |
| » | e.mail spamerOddelek: Omrežja in internet | 3331 (2819) | Tr0n |
