Forum » Pomoč in nasveti » Težave pri namestitvi XP
brdavs ::
Zdravo, pravkar nameščam XP na nov prenosnik.
Preden se setup prične, mi javi tole:
Evo, celoten text:
A problem has been detected and windows has been shut down to prevent demage to your computer.
If this is the first time you`ve seen this stop error screen, restart your computer. If this screen appears again, follow these steps:
Check for viruses on your computer. Remove any newly installed hard drives or hard drive controllers. Check your hard drive to make
sure it is properly configured and terminated. Run CHKDSK /F to check for hard drive corruption, and then restart your computer.
Pomoč?
Evo, celoten text:
Pomoč?
brdavs ::
Evo, naštimano na ide... Mi je uspelo. Hvala.
Kaj sploh je to in kje je razlika med njima?
| » | Problem z diskom : 0x0000007B errorOddelek: Pomoč in nasveti | 2846 (1895) | crayz43 |
| » | problemOddelek: Pomoč in nasveti | 1388 (1099) | mariio |
| » | Problem z nalaganjem XP sp2Oddelek: Pomoč in nasveti | 1703 (1598) | bluefish |
| » | Instalacija windowsow - problemOddelek: Operacijski sistemi | 1991 (1595) | misek |
| ⊘ | Nov računalnik, pa noče Windowsov naložiti- izpisuje napakoOddelek: Operacijski sistemi | 2240 (2049) | Mavrik |
