Call of duty 2
Call of duty 2
Mafia cod 2 ::
Pozdravljeni!
Upam,da mi boste na moje vprašanje hitro odgovorili:
Najprej sem hotel igrati call of duty 2 in sem vse naredil,zdaj pa mi napiše,ko bi hotel igrati multiplayer napiše sledeče:
Fatal error:
Direct3Ddevice::present failed:driver internal error
Kaj naj naredim?
Upam,da mi boste hitro odgovorili na vprašanje.
Lama ::
Posodobi driverje ;)
Lp, Lama
Mafia cod 2 ::
Kako pa?
Mafia cod 2 ::
CoD2 MP 1.3 build win-x86 May 1 2006
----- FS_Startup -----
Current language: english
Current search path:
c:\program files\activision\call of duty 2\main\iw_15.iwd (85 files)
c:\program files\activision\call of duty 2\main\iw_14.iwd (4038 files)
c:\program files\activision\call of duty 2\main\iw_13.iwd (22624 files)
c:\program files\activision\call of duty 2\main\iw_12.iwd (1016 files)
c:\program files\activision\call of duty 2\main\iw_11.iwd (1462 files)
c:\program files\activision\call of duty 2\main\iw_10.iwd (1936 files)
c:\program files\activision\call of duty 2\main\iw_09.iwd (2142 files)
c:\program files\activision\call of duty 2\main\iw_08.iwd (2723 files)
c:\program files\activision\call of duty 2\main\iw_07.iwd (3384 files)
c:\program files\activision\call of duty 2\main\iw_06.iwd (990 files)
c:\program files\activision\call of duty 2\main\iw_05.iwd (928 files)
c:\program files\activision\call of duty 2\main\iw_04.iwd (698 files)
c:\program files\activision\call of duty 2\main\iw_03.iwd (26 files)
c:\program files\activision\call of duty 2\main\iw_02.iwd (40 files)
c:\program files\activision\call of duty 2\main\iw_01.iwd (16 files)
c:\program files\activision\call of duty 2\main\iw_00.iwd (102 files)
c:\program files\activision\call of duty 2/main
c:\program files\activision\call of duty 2/raw
c:\program files\activision\call of duty 2/raw_shared
c:\program files\activision\call of duty 2/devraw
c:\program files\activision\call of duty 2/devraw_shared
c:\program files\activision\call of duty 2\main\localized_english_iw11.iwd (1 files)
localized assets iwd file for english
c:\program files\activision\call of duty 2\main\localized_english_iw10.iwd (414 files)
c:\program files\activision\call of duty 2\main\localized_english_iw09.iwd (98 files)
c:\program files\activision\call of duty 2\main\localized_english_iw08.iwd (8 files)
c:\program files\activision\call of duty 2\main\localized_english_iw07.iwd (1014 files)
c:\program files\activision\call of duty 2\main\localized_english_iw06.iwd (3110 files)
c:\program files\activision\call of duty 2\main\localized_english_iw05.iwd (5310 files)
c:\program files\activision\call of duty 2\main\localized_english_iw04.iwd (6240 files)
c:\program files\activision\call of duty 2\main\localized_english_iw03.iwd (6580 files)
c:\program files\activision\call of duty 2\main\localized_english_iw02.iwd (6404 files)
c:\program files\activision\call of duty 2\main\localized_english_iw01.iwd (5510 files)
c:\program files\activision\call of duty 2\main\localized_english_iw00.iwd (4764 files)
File Handles:
81663 files in iwd files
execing default_mp.cfg
couldn't exec language.cfg
========= autoconfigure
configure_mp.csv: using CPU configuration 2 GHz 512 MB
execing configure_mp.cfg
configure_mp.csv: using GPU configuration "Radeon 9*"
Measured CPU speed is 2.80 GHz
System memory is 1022 MB (capped at 1 GB)
Video card is "MOBILITY RADEON 9000 "
Streaming SIMD Extensions (SSE) supported
Winsock Initialized
Opening IP socket: localhost:28960
Hostname: workhorse
IP: 192.168.1.65
WARNING: IPX_Socket: bind: WSAENETDOWN
----- Initializing Renderer ----
----- Client Initialization -----
----- Client Initialization Complete -----
----- R_Init -----
Getting Direct3D 9 interface...
Pixel shader version is 1.4
Vertex shader version is 1.1
Video card or driver doesn't support separate alpha blend, glow will be disabled.
Video card or driver doesn't support linear filtering when copying and shrinking the frame buffer.
Video card or driver doesn't support enough textures for the DirectX 9 code path.
DirectX 9 rendering path will not be available.
Direct3D 7 code path is available.
Using Direct3D 7 code path because it is the best available path on this hardware.
Attempting 800 x 600 fullscreen with 32 bpp at 60 hz
Game window successfully created.
Creating Direct3D device...
Com_TouchMemory: 0 msec. Using sum: 0
Initializing render targets...
Requested frame buffer to be 24-bit color with 8-bit alpha
DirectX returned a frame buffer that is 24-bit color with 8-bit alpha
Initializing static model cache...
Initializing dynamic buffers...
Initializing particle cloud buffer...
Creating Direct3D queries...
Setting initial state...
DirectX reports 64 MB of video memory and 36 MB of available texture memory.
Texture detail is set automatically for DirectX 7.
Using picmip 1 on most textures, 1 on normal maps, and 1 on specular maps
ERROR: Couldn't open techniqueSet 'materials_dx7/techniquesets/shadowcookieoverlay.techset'
WARNING: Could not find material 'shadowcookieoverlay'
ERROR: Couldn't open techniqueSet 'materials_dx7/techniquesets/shadowcookieblur.techset'
WARNING: Could not find material 'shadowcookieblur'
ERROR: Couldn't open techniqueSet 'materials_dx7/techniquesets/passthru_vertalpha.techset'
WARNING: Could not find material 'feedbackblend'
ERROR: Couldn't open techniqueSet 'materials_dx7/techniquesets/passthru_alpha.techset'
WARNING: Could not find material 'feedbackreplace'
ERROR: Couldn't open techniqueSet 'materials_dx7/techniquesets/glow_setup.techset'
WARNING: Could not find material 'glow_setup'
ERROR: Couldn't open techniqueSet 'materials_dx7/techniquesets/glow_apply_bloom.techset'
WARNING: Could not find material 'glow_apply_bloom'
ERROR: Couldn't open techniqueSet 'materials_dx7/techniquesets/glow_apply_sky_bleed.techset'
WARNING: Could not find material 'glow_apply_sky_bleed'
ERROR: Couldn't open techniqueSet 'materials_dx7/techniquesets/filter_symmetric_1.techset'
WARNING: Could not find material 'filter_symmetric_1'
ERROR: Couldn't open techniqueSet 'materials_dx7/techniquesets/filter_symmetric_2.techset'
WARNING: Could not find material 'filter_symmetric_2'
ERROR: Couldn't open techniqueSet 'materials_dx7/techniquesets/filter_symmetric_3.techset'
WARNING: Could not find material 'filter_symmetric_3'
ERROR: Couldn't open techniqueSet 'materials_dx7/techniquesets/filter_symmetric_4.techset'
WARNING: Could not find material 'filter_symmetric_4'
ERROR: Couldn't open techniqueSet 'materials_dx7/techniquesets/filter_symmetric_5.techset'
WARNING: Could not find material 'filter_symmetric_5'
ERROR: Couldn't open techniqueSet 'materials_dx7/techniquesets/filter_symmetric_6.techset'
WARNING: Could not find material 'filter_symmetric_6'
ERROR: Couldn't open techniqueSet 'materials_dx7/techniquesets/filter_symmetric_7.techset'
WARNING: Could not find material 'filter_symmetric_7'
ERROR: Couldn't open techniqueSet 'materials_dx7/techniquesets/filter_symmetric_8.techset'
WARNING: Could not find material 'filter_symmetric_8'
------- sound system initialization -------
Attempting 44 kHz 16 bit stereo sound
available 3D providers:
Aureal A3D Interactive ™
Aureal A3D 2.0 ™
DirectSound3D Software Emulation
DirectSound3D Hardware Support
DirectSound3D 7+ Software - Pan and Volume
DirectSound3D 7+ Software - Light HRTF
DirectSound3D 7+ Software - Full HRTF
Creative Labs EAX 3 ™
Creative Labs EAX 2 ™
Creative Labs EAX ™
RAD Game Tools RSX 3D Audio
Dolby Surround
Miles Fast 2D Positional Audio
using 3D provider 'Miles Fast 2D Positional Audio'
32 max 3D channels
------- sound system successfully initialized -------
--- Common Initialization Complete ---
91.185.199.169:28968 resolved to 91.185.199.169:28968
Loading 'ui_mp/main.menu'...
ERROR: Couldn't find material 'ui/assets/gradientbar2.tga'
WARNING: Could not find material 'ui/assets/gradientbar2.tga'
Error: file ui_mp/main.menu, line 919: can't read token
Loading 'ui_mp/options.menu'...
Loading 'ui/options_look.menu'...
Loading 'ui/options_move.menu'...
Loading 'ui/options_shoot.menu'...
Loading 'ui/options_misc.menu'...
Loading 'ui/options_graphics.menu'...
Loading 'ui/options_game.menu'...
Loading 'ui/options_sound.menu'...
Loading 'ui/options_view.menu'...
Loading 'ui_mp/options_voice.menu'...
Loading 'ui/options_defaults.menu'...
Loading 'ui/options_credits.menu'...
Loading 'ui/options_control_defaults.menu'...
Loading 'ui/options_graphics_defaults.menu'...
Loading 'ui_mp/options_multi.menu'...
Loading 'ui/playerprofile.menu'...
Loading 'ui_mp/vid_restart.menu'...
Loading 'ui/language_restart.menu'...
Loading 'ui/snd_restart.menu'...
Loading 'ui/rec_restart.menu'...
Loading 'ui/quit.menu'...
Loading 'ui/error.menu'...
Loading 'ui_mp/multi.menu'...
ERROR: Couldn't find material 'ui/assets/fadebox.tga'
WARNING: Could not find material 'ui/assets/fadebox.tga'
Loading 'ui_mp/joinserver.menu'...
Loading 'ui_mp/createserver.menu'...
Loading 'ui_mp/pb_popmenus.menu'...
Loading 'ui_mp/cdkey.menu'...
Loading 'ui_mp/mods.menu'...
Loading 'ui_mp/connect.menu'...
WARNING: Could not find material '$levelbriefing'
Loading 'ui_mp/password.menu'...
Loading 'ui_mp/single_player.menu'...
Loading 'ui_mp/serverinfo.menu'...
Loading 'ui_mp/createfavorite.menu'...
Loading 'ui_mp/filter.menu'...
Loading 'ui_mp/in_rec_restart.menu'...
Loading 'ui_mp/auto_update.menu'...
Loading 'ui_mp/settings_dm.menu'...
Menu load error: ui_mp/settings_dm.menu, line 83: Attempting to change type from 0 to 9.
Move the type definition higher up in the itemDef.
Menu load error: ui_mp/settings_dm.menu, line 84: Attempting to change type from 0 to 9.
Menu load error: ui_mp/settings_dm.menu, line 105: Attempting to change type from 0 to 9.
Menu load error: ui_mp/settings_dm.menu, line 106: Attempting to change type from 0 to 9.
Loading 'ui_mp/settings_tdm.menu'...
Menu load error: ui_mp/settings_tdm.menu, line 79: Attempting to change type from 0 to 9.
Menu load error: ui_mp/settings_tdm.menu, line 80: Attempting to change type from 0 to 9.
Menu load error: ui_mp/settings_tdm.menu, line 101: Attempting to change type from 0 to 9.
Menu load error: ui_mp/settings_tdm.menu, line 102: Attempting to change type from 0 to 9.
Loading 'ui_mp/settings_ctf.menu'...
Menu load error: ui_mp/settings_ctf.menu, line 79: Attempting to change type from 0 to 9.
Menu load error: ui_mp/settings_ctf.menu, line 80: Attempting to change type from 0 to 9.
Menu load error: ui_mp/settings_ctf.menu, line 101: Attempting to change type from 0 to 9.
Menu load error: ui_mp/settings_ctf.menu, line 102: Attempting to change type from 0 to 9.
Loading 'ui_mp/settings_hq.menu'...
Menu load error: ui_mp/settings_hq.menu, line 79: Attempting to change type from 0 to 9.
Menu load error: ui_mp/settings_hq.menu, line 80: Attempting to change type from 0 to 9.
Menu load error: ui_mp/settings_hq.menu, line 101: Attempting to change type from 0 to 9.
Menu load error: ui_mp/settings_hq.menu, line 102: Attempting to change type from 0 to 9.
Loading 'ui_mp/settings_sd.menu'...
Loading 'ui_mp/settings_sw.menu'...
Loading 'ui_mp/background.menu'...
Working directory: c:\program files\activision\call of duty 2
Resolving cod2master.activision.com
cod2master.activision.com resolved to 63.146.124.40:20700
Direct3DDevice9::Present failed: Driver internal error
to napiše
Kako narediti svoj server v Call of Duty 2 ?
Oddelek: Igre
229618 (3278) deadzone
Call of duty 2!ne dela server!problems!
Oddelek: Igre
276086 (4088) ViperR
cod2 server problemi[pomoč please]- modem???
Oddelek: Igre
53021 (2947) Mavrik
COD2- velik ping (multiplayer)
Oddelek: Igre
175603 (3278) crazy kure
COD2 set dedicated 2
Oddelek: Igre
63950 (3805) Mr.B
