menjava procesorja (xp2000+ -> xp2800+)
TICKO ::
Imam matično ASUS A7S333, in pa athlon xp2000+ procesor. in ker sem dobil en procesor athlon xp2800+ me zanima če gre zadeva na mojo matično.
Podnožje je isto tk da paše, sam me zanima če bi zadeva laufala. Vem pa da morem nastavit še prej pravilno frekvenco z jumperji pa to..
hvala lp
www.tickobox.com
www.scooter-on.net
A7S333 V tabeli najdete podporo za procesorje in matične plošče.
CPU
Od PCB
Od BIOS
Zapišite
Athlon 1000 (200 MHz FSB) ALL ALL
Athlon 1000 (266 MHz FSB) ALL ALL
Athlon 1100 (200 MHz FSB) ALL ALL
Athlon 1133 (266 MHz FSB) ALL ALL
Athlon 1200 (200 MHz FSB) ALL ALL
Athlon 1200 (266 MHz FSB) ALL ALL
Athlon 1300 (200 MHz FSB) ALL ALL
Athlon 1333 (266 MHz FSB) ALL ALL
Athlon 1400 (200 MHz FSB) ALL ALL
Athlon 1400 (266 MHz FSB) ALL ALL
Athlon 700 ALL ALL
Athlon 750 ALL ALL
Athlon 800 ALL ALL
Athlon 850 ALL ALL
Athlon 900 ALL ALL
Athlon 950 ALL ALL
Athlon XP 1500+(Model 6)(Palomino) ALL 1002
Athlon XP 1600+(Model 6)(Palomino) ALL 1002
Athlon XP 1700+(Model 6)(Palomino) ALL 1002
Athlon XP 1700+(Model 8)(Thoroughbred) ALL 1002
Athlon XP 1800+(Model 6)(Palomino) ALL 1002
Athlon XP 1800+(Model 8)(Thoroughbred) ALL 1002
Athlon XP 1900+(Model 6)(Palomino) ALL 1002
Athlon XP 1900+(Model 8)(Thoroughbred) ALL 1002
Athlon XP 2000+(Model 10)(Thorton) 1.03 1005
Athlon XP 2000+(Model 6)(Palomino) ALL 1002
Athlon XP 2000+(Model 8)(Thoroughbred) ALL 1002
Athlon XP 2100+(Model 6)(Palomino) ALL 1002
Athlon XP 2100+(Model 8)(Thoroughbred) ALL 1002
Athlon XP 2200+(Model 10)(Thorton) 1.03 1005
Athlon XP 2200+(Model 8)(Thoroughbred) ALL 1002
Athlon XP 2400+(Model 10)(Thorton) 1.03 1005
Athlon XP 2400+(Model 8)(Thoroughbred) ALL 1004
Athlon XP 2600+(266FSB)(Model 8)(Thoroughbred) ALL 1004
Duron 1000 (Model 7)(Morgan) ALL 1002
Duron 1100 (Model 7)(Morgan) ALL 1002
Duron 1200 (Model 7)(Morgan) ALL 1002
Duron 1300 (Model 7)(Morgan) ALL 1002
Duron 1400 (Model 8)(Applebred) ALL 1006
Duron 1600 (Model 8)(Applebred) ALL 1006
Duron 1800 (Model 8)(Applebred) ALL 1006
Duron 600 (Model 3) ALL ALL
Duron 650 (Model 3) ALL ALL
Duron 700 (Model 3) ALL ALL
Duron 750 (Model 3) ALL ALL
Duron 800 (Model 3) ALL ALL
Duron 850 (Model 3) ALL ALL
Duron 900 (Model 3) ALL ALL
Duron 900 (Model 7)(Morgan) ALL 1002
Duron 950 (Model 3) ALL ALL
Duron 950 (Model 7)(Morgan) ALL 1002
TICKO ::
se pravi 2800 ne bo delal? ali je možno da dela pač kot 2600?
www.tickobox.com
www.scooter-on.net
TechStreme ::
Če ima procesor FSB 133×2 oz. 266 potem bo delal brez težav. Če pa je barton jedro pa imaš FSB 333. Potem lahko znižaš frekvenco rama na DDR 266 in naviješ FSB na 333 in bo po vsej verjetnosti delal kot nenavit 2800+... Če pa to nebo delovalo pa lahko da imaš srečo in ima odklenjen množilnik. Potem lahko enostavno pustiš FSB 266 in nastaviš višji množilnik.
Ph2 940BE 3.6GHz; MSI K9A2 Platinum; 2×2Gb DDR800 4-4-4-12 CR1; 2×4850 CF
matična plošča za P4
292452 (2269) flashek
kaj gre na ASUS A7V133-M
71654 (1572) SodVina
a7v266-e kateri cpu in ram?
51570 (1523) Eru
KT7A + Athlon XP
222542 (2076) Jure2k
Abit KT7A + TB 1,4........
Oddelek: Navijanje
292014 (1660) kuglvinkl
