Microsoft .NET Framework ???
Toddie ::
Zdravo!
Imam problem, in sicer: Vedno, ko prižgem računalnik. mi Microsoft .Net Framework javi težavo:
"An unhandled exception has occurred in a component in your application. Click continue and application will ignore this error and attempt to continue."
Spodaj imam tri možnosti: Deatils, Continue in Quit.
Če kliknem na Details, mi javi tole:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.IndexOutOfRangeException: Index was outside the bounds of the array.
at groupmanager.frmMain.PollServer()
at groupmanager.frmMain.frmMain_Load(Object sender, EventArgs e)
at System.EventHandler.Invoke(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ContainerControl.WndProc(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.42 (RTM.050727-4200)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
groupmanager
Assembly Version: 1.0.0.5
Win32 Version: 1.0.0.5
CodeBase: file:///C:/Program%20Files/Diskeeper%20Pro%20Premier%202009/groupmanager.exe
Microsoft.VisualBasic
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.42 (RTM.050727-4200)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Management
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Management/2.0.0.0__b03f5f7f11d50a3a/System.Management.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
< configuration>
< system.windows.forms jitDebugging="true" />
< /configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Kaj storiti??
Lp.
c00L3r ::
Ob zagonu se ti zažene ta program:
Sklepam iz tega, ker je edini executable. Tega diskeperja odstrani in ponovno namesti, pa poročaj kaj se zgodi.
Toddie ::
Problem rešen.
Hvala. (:
lojze8 ::
Toddie je izjavil:
Problem rešen.
Hvala. (:
Nisi pa napisal kako si rešil, meni namreč isto kaže.
Seštevanje, odštevanje za drugošolce
Oddelek: Šola
102171 (1827) norcuron
[c#] Vprašanje glede release verzije aplikacije
Oddelek: Programiranje
51990 (1814) Ericssony
Tezava pri instanciranju class-a
61800 (1671) KernelPanic
null reference exception na čudnem mestu C#
51761 (1698) krho
Mono, je že kdo delal z njim?
171933 (1463) Beezgetz
