[ubuntu 8.04] Audigy 2 ZS, 5.1 zvok
CrustyDOD ::
Ello,
Mi lahko kdo pove kako usposobiti 5.1 zvok v ubuntu? Poskusil sem �ťĚŞe veliko stvari (iz ubuntu forums) pa ni� ne dela!
Zvo�na: Audigy 2 ZS
Playback device is surround51
Stream parameters are 48000Hz, S16_LE, 6 channels
Using 16 octaves of pink noise
Rate set to 48000Hz (requested 48000Hz)
Buffer size range from 64 to 16384
Period size range from 16 to 16384
Using max buffer size 16384
Periods = 4
was set period_size = 4096
was set buffer_size = 16384
0 - Front Left DELA
4 - Center
1 - Front Right DELA
3 - Rear Right
2 - Rear Left DELA
5 - LFE
Trije zvo���niki delajo, 3je ne.
Let's see..
Samba hitrost
133348 (2708) e-marko
Servis in zamenjava komponente?
213938 (3169) krneki0001
Problem s prižiganjem računalnika.
121254 (1099) Pobanick
Apache vprašanje - virtual host
Oddelek: Programska oprema
161268 (1111) Goldee
Cod5 se ne zažene
51175 (1113) huek111
