Forum » Kaj kupiti » Kok je vreden prenosnik....
edey ::
Zanima me kok je še vreden prenosnik z naslednjo konfiguracijo:
Microprocessor 1.60 GHz Intel® Core™ Duo processor T2050 with Intel® Centrino® Duo Mobile Technology
Microprocessor Cache Level 2 cache 2 MB
Memory 1024 MB DDR2 533 MHz (2 x 512 MB)
Video Graphics Intel® Graphics Media Accelerator 950
Video Memory up to 128 MB (shared)
Hard Drive 120 GB 5400 rpm
Multimedia Drive Super Multi DVD Writer (+/-R +/-RW) with Double Layer support
Display 15.4” WXGA High Definition BrightView Widescreen (1280 x 800)
Fax/Modem High speed 56K modem
Network Card Ethernet 10/100BT integrated network interface
Wireless Connectivity Intel® PRO/Wireless 3945 802.11a/b/g Integrated Wireless LAN
Sound Altec Lansing® speakers
3D Sound Blaster Pro compatible sound 16 bit integrated
Keyboard 101 key compatible keyboard
Pointing Device Touch Pad with On/Off button and dedicated vertical and horizontal Scroll Up/Down pad, volume control, mute buttons, 1 Quick Launch Button
External Ports • 1 VGA port
• 2 USB 2.0 ports
• 1 RJ 11 modem connector
• 1 RJ 45 Ethernet connector
• S-video TV out
• 1 Headphone-out
Dimensions 25.90 cm (L) x 35.78 cm (W) x 3.5 cm - 4.4 cm (H)
Weight 2.98 kg (6.6 lbs)
Power • 65 W AC Power Adapter
• 6-cell Lithium-Ion (Li-Ion) battery
Je pa znamke HP, in je star 1 leto in pol...
Kok ga vi cenite?
• 2 USB 2.0 ports
• S-video TV out
• 1 Headphone-out
Kok ga vi cenite?
Realman ::
LAhko bi še znamko zraven napisal.Jaz bi rekel ene 300 eur +- 50 eur,če je še baterija ok,drugače še manj.Lahko pa se poskusi tudi prodati za več,daš oglas,pa vidiš kolikšno je zanimanje.
| » | HP nx9420 realna cenaOddelek: Kaj kupiti | 2175 (2119) | ElviS |
| » | Anni FL90 prenosnik (Novo)Oddelek: Kaj kupiti | 4553 (3540) | Miha76 |
| » | še zadnjičOddelek: Kaj kupiti | 1637 (1411) | klemennnn |
| » | Grafika v prenosniku???Oddelek: Kaj kupiti | 4798 (4218) | M@73Y |
| » | Kateri notebook kupiti???Oddelek: Kaj kupiti | 2539 (2257) | mich |
