HP nx9420 realna cena
ElviS ::
Zanima me koliko bi bil vreden ta prenosnik... star je nekje 2 leti in mislim da je še v gar.
Ker je teh modelov cel kup mi je malo problem postaviti realno ceno...
Specifikacije:
Processor: Intel Core 2 Duo Processor T5600 (1.83-GHz, 667 FSB, 2MB-L2 cache)
Chipset: Mobile Intel 945PM Express Chipset
Memory: 2 GB DDR2 SDRAM 667-MHz (2 x 1GB)
Hard drive(s) 120-GB 5400 rpm
Optical drive: SuperMulti Double Layer2 DVD+/-RW, Double Layer2 DVD+/-RW with LightScribe3, 24X DVD/CD-RW Combo, 8x DVD
Display: 17.0-inch WSXGA+ Brightview wide-viewing angle (1680 x 1050 resolution and 16M colors)
Graphics: ATI Mobility Radeon x1600 with 256MB of dedicated video memory
Audio: PremierSound High Definition Audio support w/24-bit audio DAC, Digital EQ, Advanced audio power management,line out/headphone jack, microphone jack, integrated microphone
Wireless support: Intel Pro/Wireless 3945ABG Network Connection, Broadcom 4311BG 802.11b/g WiFi Adapter, Broadcom 4311AG 802.11a/b/g WiFi Adapter, dual display mounted antennas, optional integrated Bluetooth
Communications: Broadcom Gigabit PCI Express Ethernet Controller6 (10/100/1000 NIC), 56K modem, HP power down NIC technology
Expansion slots: 1 Type I/II PC Card slot supports 32-bit CardBus and 16-bit cards
7-in-1 Media Reader: Secure Digital, MultiMediaCard, Memory Stick, Memory Stick Pro, Memory Stick Duo, Smart Media and xD memory cards
Ports and connectors: 4 USB 2.0, VGA, audio in/out, power, RJ-11, RJ-45, S-video TV out, IEEE 1394a, docking, HP Travel Battery
Input device: Full-sized keyboard; Touchpad with scroll zone
Dimensions (h x w x d): 1.3 in (at front) x 15.5 in x 10.8 in /33 mm (at front) x 393 mm x 275 mm
Weight: Starting at 7.4 lb/3.35 kg
Power: 8-cell Lithium-Ion battery, secondary 8-cell HP Travel Battery7, external 90W AC adapter
i'm still in the building...
Shark-357 ::
250-300EUR bi moral bp dobit zanj.
BALAST ::
Glede na to da je HP, bi zanj dobil okoli 250EUR.
Po dveh letih je baterija že totalno iztrošena, nova pa stane 80EUR, medtem ko je procesor in grafična že zelo v letih in sedajšna tehnologija omogoča manjšo porabo, je skorajda nevredno omembe da je ta prenosnik počasen ko polž.
amigo_no1 ::
Procesor ni tako slab, grafična je bolj problem.
Koliko časa drži baterija ?
ElviS ::
amigo_no1 je izjavil:
Bi moral stestirat, ker se je večinoma uporabljal na el. omrežju; bi pa po moje mogel zdržat 2+ uri.
Vrednost laptopa (HP)
183080 (2293) MI5Ek-
17" Acer TravelMate ali 15.4" Simens Amilo Pro
212118 (1591) Mih@@
še zadnjič
81637 (1411) klemennnn
Prenosnik do 160k(vaše mnenje)
213059 (2712) Zheegec
Težava z nakupom prenosnika!
182845 (2299) samo112
