Kok je vreden prenosnik....
edey ::
Zanima me kok je še vreden prenosnik z naslednjo konfiguracijo:
Microprocessor 1.60 GHz Intel® Core™ Duo processor T2050 with Intel® Centrino® Duo Mobile Technology
Microprocessor Cache Level 2 cache 2 MB
Memory 1024 MB DDR2 533 MHz (2 x 512 MB)
Video Graphics Intel® Graphics Media Accelerator 950
Video Memory up to 128 MB (shared)
Hard Drive 120 GB 5400 rpm
Multimedia Drive Super Multi DVD Writer (+/-R +/-RW) with Double Layer support
Display 15.4” WXGA High Definition BrightView Widescreen (1280 x 800)
Fax/Modem High speed 56K modem
Network Card Ethernet 10/100BT integrated network interface
Wireless Connectivity Intel® PRO/Wireless 3945 802.11a/b/g Integrated Wireless LAN
Sound Altec Lansing® speakers
3D Sound Blaster Pro compatible sound 16 bit integrated
Keyboard 101 key compatible keyboard
Pointing Device Touch Pad with On/Off button and dedicated vertical and horizontal Scroll Up/Down pad, volume control, mute buttons, 1 Quick Launch Button
External Ports • 1 VGA port
• 2 USB 2.0 ports
• 1 RJ 11 modem connector
• 1 RJ 45 Ethernet connector
• S-video TV out
• 1 Headphone-out
Dimensions 25.90 cm (L) x 35.78 cm (W) x 3.5 cm - 4.4 cm (H)
Weight 2.98 kg (6.6 lbs)
Power • 65 W AC Power Adapter
• 6-cell Lithium-Ion (Li-Ion) battery
Je pa znamke HP, in je star 1 leto in pol...
Kok ga vi cenite?
Realman ::
LAhko bi še znamko zraven napisal.Jaz bi rekel ene 300 eur +- 50 eur,če je še baterija ok,drugače še manj.Lahko pa se poskusi tudi prodati za več,daš oglas,pa vidiš kolikšno je zanimanje.
HP nx9420 realna cena
52175 (2119) ElviS
Anni FL90 prenosnik (Novo)
134553 (3540) Miha76
še zadnjič
81637 (1411) klemennnn
Grafika v prenosniku???
214798 (4218) M@73Y
Kateri notebook kupiti???
122539 (2257) mich
