Forum » Kaj kupiti » SSD za sistemski disk
AC_DC ::
Write padca na 28 in 47% sta čudna, drugače je ok za 120 gb.Jaz nebi kompliciral.
sammy 830
jest
google za "s9fm02.6" najde phison s9
sammy 830
jest
- spremenilo: AC_DC ()
Ker tale graf je sumljivo podoben SF kontrolerjem. Intenso TOP ima write hitrost linearno neglede na stisljivost podatkov.
Actually, phison kontrolerji imajo neko preprosto stiskanje podatkov, tko kot sandforce
- spremenil: iloveboobz ()
jest10 ::
iloveboobz je izjavil:
Do sedaj videni grafi tega ne kažejo.
Recimo moj 256 GB model:
Ker če ti kontrolerji nebi stiskal, recimo intenso nebi mogu oglaševat tega
Ni šans da stisneš 300MB/s+ iz 128GB flasha brez nekih trikov.
pozabi ta test, ker je dokaj čuden.
Benchaj z atto in as ssd pa primerjaj.
Writing Performance:up to 300 MB/s (128GB) |
Si gledam kar moj test
jest10 ::
Ker jih ne.
Fotr ima 128 GB verzijo in ima write hitrosti linearne od 0 do 100% stisljivosti. Okoli 160 MB/s
ATTO provides an interesting view on what is going on here. With highly compressible ATTO writes, the Phison controller can achieve over 500MB/s write and 540MB/s read speeds. With the M.2 PCIe SSDs we are going to see a bigger jump in performance, but for now this is very solid for a SATA III drive.
Z as ssd je pa malo čez 350MB/s
S10 (256 GB verzija) ne stiska
S10 stiska sigurno, ampak lahko da ne vklopi tega vsak proizvajalec.
The mixed workload random test shows all three TLC drives exhibiting higher performance than the MLC drives. All of the benchmarks discussed so far use 100% entropy (incompressible data). Phison's controller performs better with compressible data, as we've demonstrated.
http://www.tomshardware.com/reviews/tos...
jest10 ::
Ostalo imaš tukaj
Jebat ga. Moj Intenso 128 GB(nimam slik testov in jih tudi ne morem narediti) ter 256 GB ne stiskata.
at the end of the day write sekvnečna hitrost sploh ni tok bistvena. Važno da je dovolj hitra, da ti kak hitrejši kjuč/usb disk ne zafila :)
Bolj je imo važno, kako se stvar obnaša z nakjučnimi podatki. Da se potem ne obesi, ko hočeš skopirat 10000 drobnih fajlov.
NO23 ::
Se nisem sprobaval drugega kot benchmarke.. Bom nalozil Windowse
Hvala vsem za pomoc.
P.S.: Se da flashat kaksno novejso verzijo firmwara? Pri Samsungu vem da se da.
SuperVeloce ::
Jaz pri intensotu nisem nič našel za firmware upgrade. Če ima kdo izkušnje z nadgradnjo teh phisonov, se priporočam. Moj firmware je dokaj star pri S9.
Drugače pa ja, S9 stiska
yup..
https://www.nakupovanje.net/izdelki/rac...
oz tle, če maš kje blizu mimovrste prevzem https://www.mimovrste.com/diski/intenso...
Worf9 ::
Pozdravljeni vsi skupaj,
Ko je že glih govora o Intenso III Top 128GB disku me zanima vaše mnenje. In sicer:
kateri disk v tem cenovnem razredu (cca. 50€) je boljši/hitrejši : ?
Intenso III Top 128GB SSD SATA3
ali
Integral P Series 4 120GB SSD SATA3
ali
Ni važno, ker ne boš opazil razlike.
Worf9 ::
Hehe, true dat. Pa vseeno še nekaj specifikacij:
Intenso III Top 128GB SSD SATA3 : bere do 520 MB/s, zapisuje do 300 MB/s garancija 2 leti
ali
Integral P Series 4 120GB SSD SATA3: bere do 565 MB/s, zapisuje do 420 MB/s garancija 3 leta MTBF: 2.000.000
oba imata MLC nand flash
Morda je razlika v zanesljivosti/hitrosti v kontrolerjih ? Kdo ve kaj več ?
ali
- spremenilo: Worf9 ()
OvCa77 ::
ali
Imam integral in ni razlik, res pa je da je v enem starejšem kompu, nekje pa sem prebral da ima tlc
Laptop: Probook 440 G3 | i5-6200U | 12GB DDR3L | SSD Plus 240GB
Desktop: Ryzen 1600X | Gigabyte AX370 K3 | 8GB DDR4 | MX100 256GB
Worf9 ::
Lahko prilimaš kakšen benchmark ? Morda še kdo dug, ki ima Integral SSD (ni ravno veliko benchm. od Integral 120GB na tej stani)! Drugač pa INtegral je trenutno nekaj EUR cenejši in ima več garancije ! V spec. na njihovi strani piše, da ima MLC.
Še kakšna mnenja...
Še kakšna mnenja...
OvCa77 ::
Še kakšna mnenja...
žal ti ga nemoram benchat ker ni bil v mojem kompu ampak sem ga samo stestiral in montiral, o tlc pa je napisano na forumu
jest10 ::
Še kakšna mnenja...
Integral je TLC.
Jaz bi(in tudi sem) raje vzel Intenso
- spremenilo: jest10 ()
Worf9 ::
Integral je TLC.
Čudo božje...
Na njihovi strani oglašujejo MLC: http://www.integralmemory.com/product/p...
Pa tudi na vseh spletnih trgovinah, da je MLC !
Ali ni hitrost za TLC nekam velika, sploh wright ?
Čudo božje...
Tehnično imajo prav, ker MLC je multi level cell, kar ne pomeni strikno samo 2 bita na celico.
SLC caching yo.
OvCa77 ::
Mah za en star laptop je že dober.
SuperVeloce ::
Dokler ne šopaš write nonstop ni panike, je ok za tako poceni SSD. Ampak kaj druga itak ne moreš pričakovati. Zakasnitve so dejansko super za TLC (dokler ga ne porineš čez mejo).
Takole zgleda 256gb verzija
zakaj bi za pest riža prodal zanesljivost, vdržljivost in podatkovno retencijo ?
SuperVeloce ::
Odvisno od cene, ko sem jaz poskusno nabavil tega, sem ga dobil ceneje od vseh ostalih ssdjev. Če pa je cena enaka, potem pa ja... Drugače pa, zanesljivost, vzdržljivost in retencija niso kaj slabši. Vsaj kakšne izgube podatkov na TLCjih še ni bilo. Dokler ni to v workstationu, itak nima veze. Razen bx200, ki ima resne hitrostne pomankjkljivosti in še med najcenejšimi ponavadi ni, zaradi nakupa TLC nihče ne bo las pulil, če ga že ima doma.
vse te tocke so vsaj x3 slabse.
padec retencije se vidi po parih tednih, endurance je ene 3-5x slabsi (down to par 100 prepisov) zanesljivost je pa tudi vprasljiva, ker rabis bolj kompleksne kontrolerje da delas error correction. zadnje case opazam da se recimo s10 ne obnese najbolje. ze videno ene par primerkov, ki so mrknal kr tako. nekateri celo v roku dneva.
in other words, stran od 2d tlcja, razn ce je smesno poceni in ti je vseeno.
SuperVeloce ::
Jaz sem tudi videl kar tako mrkniti m4, mx100, samsunge, itd... pa opevane sandisk ultra II. So what's your point. Če nekdo sprašuje za nakup, se mu priporoča po trenutnih cenah za trenutno najboljšo izbiro. Če pa jaz človeku povem, da se ne rabi sekirat, ker že ima zadevo doma in deluje vredu (za TLC), pa ne potrebuješ ponavljanja že povedanih stvari. Ne bo umru zaradi tega, ni nobene indikacije za višjo izgubo podatkov od poceni MLCjev.
- spremenil: SuperVeloce ()
tudi za 840/evo smo mislal da je kul zadeva, pa vsi vemo kaj je blo potem. sploh so ga nasankal uporabniki 840ke....
nwm no, premale cenovne razlike so, da bi lahko upravicu downside. sploh pri 120gb modelih.
itk pa, vsakemu svoje, jst osebno se ne dotaknem 2d tlcja za privat use.
cortez ::
l0g1t3ch ::
Kaj od tega spodaj ?
Crucial BX200 240 GB - 68€
Intenso TOP 256 GB - 76€
Rabim za en starejši PC, ki se uporablja za brskanje po netu (fb, gmail, yt) in predvajanje muske in videa. Načeloma bi bil že 128GB čez glavo ampak je cenovna razlika tako mala, da raje malo večjega vzamem.
4ever ::
Kaj od tega spodaj ?Intenso
I5 4460 | 8GB Corsair Vengeance | B85 Anniversary | BX200 240GB |
Gigabyte GTX 960 4GB | CM GM 450 | 1TB WD Blue
pdor ::
V soboto sem si tudi sam omislil Intenso top 128GB, premamila me je cena in to, da ima MLC nand. Na žalost je sledilo presenečenje, disk ima SAFM12.2 firmware, kar je razvidno iz hdparm ukaza v linuxu:
hdparm napiše tudi ostale lastnosti, če koga zanimajo:
Disk je priklopljen na SATA6 priklop s SATA3 kablom, i3 LGA1155 z 8GB spomina.
Preden sem naložil linux, sem disk pognal skozi vaše priljubljene benchmarke.
compression-benchmark
copy benchmark
AS-SSD benchmark
AS-SSD benchmark 3GB test
Crystaldiskmark:
CrystalDiskMark 5.1.2 x64 (C) 2007-2016 hiyohiyo
Crystal Dew World : http://crystalmark.info/
* MB/s = 1,000,000 bytes/s [SATA/600 = 600,000,000 bytes/s]
* KB = 1000 bytes, KiB = 1024 bytes
Sequential Read (Q= 32,T= 1) : 565.267 MB/s
Sequential Write (Q= 32,T= 1) : 516.462 MB/s
Random Read 4KiB (Q= 32,T= 1) : 329.026 MB/s [ 80328.6 IOPS]
Random Write 4KiB (Q= 32,T= 1) : 349.764 MB/s [ 85391.6 IOPS]
Sequential Read (T= 1) : 530.227 MB/s
Sequential Write (T= 1) : 499.377 MB/s
Random Read 4KiB (Q= 1,T= 1) : 33.066 MB/s [ 8072.8 IOPS]
Random Write 4KiB (Q= 1,T= 1) : 82.123 MB/s [ 20049.6 IOPS]
Test : 1024 MiB [G: 0.1% (0.1/119.2 GiB)] (x5) [Interval=5 sec]
CrystalDisksMark 2GiB test:
Sequential Read (Q= 32,T= 1) : 565.493 MB/s
Sequential Write (Q= 32,T= 1) : 98.301 MB/s
Random Read 4KiB (Q= 32,T= 1) : 331.273 MB/s [ 80877.2 IOPS]
Random Write 4KiB (Q= 32,T= 1) : 98.450 MB/s [ 24035.6 IOPS]
Sequential Read (T= 1) : 534.422 MB/s
Sequential Write (T= 1) : 98.152 MB/s
Random Read 4KiB (Q= 1,T= 1) : 30.759 MB/s [ 7509.5 IOPS]
Random Write 4KiB (Q= 1,T= 1) : 82.120 MB/s [ 20048.8 IOPS]
Test : 2048 MiB [G: 0.1% (0.1/119.2 GiB)] (x5) [Interval=5 sec]
Še rezultati pisanja v linuxu:
1073741824 bytes (1,1 GB) copied, 2,35681 s, 456 MB/s
4294967296 bytes (4,3 GB) copied, 33,6168 s, 128 MB/s
Še branje testne 4.3GB datoteke, po brisanju cache-a:
4294967296 bytes (4,3 GB) copied, 7,99597 s, 537 MB/s
Na šktli piše NAND Flash: High-Speed MLC, Cache 256MB, hitrost pisanja 300MB/s, hitrost branja 520MB/s, nobene indikacije, da bi šlo za TLC.
To pišem zgolj v vednost, če bi si kdo srčno želel MLC NAND, da pri Intensu lahko dobi TLC. Disk uporabljam za sistemski, kar sem moral skopirati nanj, sem skopiral, večjih težav s pisanjem ne pričakujem. Zna pa biti precej nadležno, če bi kdo na disk kopiral večje količine podatkov, bi mu hitrost padla na cca. 100MB/s, ravno to je omejitev hitrosti oz. prava hitrost pisanja na disk. Navidezna hitrost 400MB/s je pisanje v cache. Vsak naj pri sebi razčisti kaj potrebuje, kaj želi, kaj je smiselno in kaj ni. 128MB modeli imajo 1.5GB cache-a (200GB modeli 3, 400GB 6, itn), dokler zapisujte na disk take količine podatkov, bodo hitrosti visoke (tu velja omeniti še to, če boste skopirali 1GB, čez 5s še 1GB, vam bo drugi GB kopiralo počasneje, ker bo iz cache-a na disk še vedno prenašalo prvi, pa čeprav bo OS javil, da je prvi GB že skopiran).
Moteče je to, da Intenso oglašuje nekaj, česar kupec v škatli ne dobi, za moje potrebe je disk več kot dober (navajen sem bil na 5400rpm hitachija v laptopu), tudi sam sem imel ogledane MLC, hojnikb je trdil, da je Intenso top MLC, njihova stran temu pritrjuje, tudi škatla.
128GB za slabih 40€ ni slabo, pa čeprav je TLC, bi pa morda rajši kupil BX200 240GB, če bi imel to informacijo že prej.
PS Jest10, v tvojem benchmarku kompresije je pri firmware oznaki razvidno SAFM, si prepričan, da je tvoj 200GB model res MLC? Na tvojem mestu bi pognal crystaldisksmark in pod testno velikot izbral vsaj 3, še rajši 4GB, če hitrost ne bo enako visoka kot pri običajnem testu, imaš tudi ti TLC NAND. 128GB ima 1.5GB cache-a, 200GB model ima 3GB, itn. Dokler disk zapisuje nekaj v velikosti cache-a, ne boš opazil padca hitrosti, ko bo pa dobil ukaz za zapis podatkov velikosti, ki presega cache, pa boš občutil upad hitrosti.
ATA device, with non-removable media Model Number: INTENSO Serial Number: [izbrisal] Firmware Revision: SAFM12.2 Transport: Serial, ATA8-AST, SATA 1.0a, SATA II Extensions, SATA Rev 2.5, SATA Rev 2.6, SATA Rev 3.0
Capabilities:
	LBA, IORDY(can be disabled)
	Queue depth: 32
	Standby timer values: spec'd by Standard, no device specific minimum
	R/W multiple sector transfer: Max = 16	Current = 16
	Advanced power management level: 254
	DMA: mdma0 mdma1 mdma2 udma0 udma1 udma2 udma3 udma4 udma5 *udma6
	     Cycle time: min=120ns recommended=120ns
	PIO: pio0 pio1 pio2 pio3 pio4
	     Cycle time: no flow control=120ns  IORDY flow control=120ns
Commands/features:
	Enabled	Supported:
	   *	SMART feature set
	    	Security Mode feature set
	   *	Power Management feature set
	   *	Write cache
	   *	Look-ahead
	   *	Host Protected Area feature set
	   *	WRITE_BUFFER command
	   *	READ_BUFFER command
	   *	NOP cmd
	   *	DOWNLOAD_MICROCODE
	   *	Advanced Power Management feature set
	    	SET_MAX security extension
	   *	48-bit Address feature set
	   *	Device Configuration Overlay feature set
	   *	Mandatory FLUSH_CACHE
	   *	FLUSH_CACHE_EXT
	   *	SMART error logging
	   *	SMART self-test
	   *	General Purpose Logging feature set
	   *	WRITE_{DMA|MULTIPLE}_FUA_EXT
	   *	Disable Data Transfer After Error Detection
	   *	{READ,WRITE}_DMA_EXT_GPL commands
	   *	Segmented DOWNLOAD_MICROCODE
	   *	Gen1 signaling speed (1.5Gb/s)
	   *	Gen2 signaling speed (3.0Gb/s)
	   *	Gen3 signaling speed (6.0Gb/s)
	   *	Native Command Queueing (NCQ)
	   *	Host-initiated interface power management
	   *	Phy event counters
	   *	Host automatic Partial to Slumber transitions
	   *	Device automatic Partial to Slumber transitions
	   *	READ_LOG_DMA_EXT equivalent to READ_LOG_EXT
	   *	DMA Setup Auto-Activate optimization
	    	Device-initiated interface power management
	   *	Software settings preservation
	   *	DOWNLOAD MICROCODE DMA command
	   *	SET MAX SETPASSWORD/UNLOCK DMA commands
	   *	WRITE BUFFER DMA command
	   *	READ BUFFER DMA command
	   *	DEVICE CONFIGURATION SET/IDENTIFY DMA commands
	   *	Data Set Management TRIM supported (limit 8 blocks)
	   *	Deterministic read ZEROs after TRIM
copy benchmark
AS-SSD benchmark
Crystaldiskmark:
heh, ocitno je tudi intenso baitswitchal na tlc...
well, off to blacklist you go.
mlc -- multi level cell ne dual level cell
dukedl ::
dej prosm no :))
da ne bo kdo tole vrjel...SATA3 kabl ne obstaja(vse je marketing) :D
http://www.gamersnexus.net/guides/1882-...
You could buy a SATA cable for $0.53 and it would perform effectively identically to an expensive “SATA III cable.”
edit: typo
lp dukedl
- spremenil: dukedl ()
pdor ::
Hojnikb, ve se kaj so oni želeli povedati s tem
dukedl, moram napisati to, kar imam, če na kablu piše sata3, to piše, imaš ogromno ljudi, ki verjamejo, da mroa biti kabel z napisom sata6, ojačan, zaščiten, če ni retail 20€, ni dober, v resnici pa je tako: https://www.pugetsystems.com/labs/artic...
Je pa zanimivo videt kaj vse vas zmoti, na preži ste, da bi ljudem očitali nekaj kar niso napisali, še manj pa mislili.
srečno
srečno
