Forum » Kaj kupiti » SSD za sistemski disk
Ta trenutek 3d nand pomeni 2x visjo ceno. To je vse.
Kaj bo pa v prihodnosti, nas pa ta trenutek ne zanima, ker obljub je vedno veliko, veliko prevec.
2x večja cena je izkjučno zato, ker imajo ostali pogoni takega ranga ravnotakšno ceno. Samsung pač nebo šel prodajat 10% boljšega pogona za 50% manj od konkurence, ker je to enostavno slaba poslovna praksa.
Ko pa pridejo mainstream pogoni ven z to tehnologijo, se bo pa cena hitro odražala.
Gre se za novo, nepreizkuseno zadevo, tko da prodajajo beta izdelek v majhnih kolicinah za testiranje.
PrimozR ::
Evo hojnikb, ti lepo povejo, da maksimalna velikost celice ni tistih nm, kolikor jih oglašujejo ;)
PrimozR ::
V labu imajo očitno 256 GB pogon z 8 PB zapisi... Ki še vedno deluje. Untested?
iloveboobz je izjavil:
Pri micronu je :)
Dej preberi Anand članek, ker ti izrecno napišejo, da ni.
- spremenil: PrimozR ()
http://anandtech.com/show/7896/plextor-...
Se bo treba naučit _natačno_ brat
Tako da je čisto odvisno kako meriš. Če meriš samo celico, potem node size predstavlja velikost stranice celie. Če pa upoštevaš še ta "prazn" plac med celicami, je pa jasno velikost večja.
Traditionally cells are symmetrical. The process node refers to the size of one cell, so in the case of 20nm NAND, the cell size would be 20nm x 20nm. However, there is no rule against making an asymmetrical cell and that is in fact what Toshiba/SanDisk did with their first generation 19nm NAND. Instead of being a symmetrical 19nm x 19nm design, the cell size was 19nm x 26nm. Compared to IMFT's symmetrical 20nm design, the actual cell size is quite a bit larger (494 nm2 vs 400 nm2 ), yet in terms of marketing Toshiba's/SanDisk's "19nm" NAND was smaller and more advanced.
Oftentimes when cell size is discussed, it is only the actual size of the cell that is taken into account, which leaves the distance between cells out of the conclusion. However, the so called empty parts (they are not really empty as you saw in the X-ray a couple of pages back) take a part of the die area similar to the cells, meaning that they cannot be excluded. The appropriate way to measure cell size is from the inner corner of a cell to the outer corners of neighbouring cells in both X and Y axes. This is demonstrated by the black square on the above graph.
- spremenil: iloveboobz ()
Pri micronu je :)
Ajde, kje ste zdaj tisti paranoiki :)
32k p/e je tole :)
Ko jih bodo imeli 100.000 takih, bom rekel, da je dobro potestiran.
To pravim zgolj za to, ker imajo premium ceno.
Premium cena je z razlogom. In tudi potestiran je očitno zelo, če lahko dajo 10 let garancije.
Itk pa je za večino tak pogon overkill in če tako pogledaš ne pretirano smiseln (razn za kako nišo). Je pa dober showcase 3D nanda.
ST-777 ::
Gre se za novo, nepreizkuseno zadevo, tko da prodajajo beta izdelek v majhnih kolicinah za testiranje.V večjih količinah bo naprodaj že ta mesec.
"Novinca 850 PRO, ki prinaša popolnoma nove dimenzije zmogljivosti, so predstavili na Samsungovem globalnem srečanju za pomnilnike SSD v južnokorejskem Seulu, naprodaj pa bo že ta mesec v 53 državah po vsem svetu." http://www.racunalniske-novice.com/novi...
radmannsdorf ::
danes bom frendu fliknu notr MX100, in to v komp ki je star 5-6let. notr ma eno hudo plato za tiste čase, pa me zanima, glede na to da seveda ima sata priklope, to tudi avtomatsko pomeni da ima v biosu AHCI možnost ane?
Verjetno. Vseeno pa prečekiraj. Se najdejo 5-6 let stare plate, ki sploh _ne_ podpirajo AHCI (kjub sata). Nekatere asuske naprimer.
FlyingBee ::
predvsm to, ja, pa mišice morajo tudi razkazovat, če pa bo to tudi edina pot, 3d nand namreč ,potem pa itak še toliko bolje, da so prvi z njim ... cena je visoka, vendar relativno ni presenečenja
Jap, 3D je the way to go. ~1X nand je najmanj, kar se še da skalirat, zato zna bit pr vseh nov nod že na 3Dju in ne več dieshrink obstoječega.
FlyingBee ::
a ve kdo, kaj bi bil vzrok za vsa 1 sekundno zamujanje pri zapiranju zavihkov v firefox, recimo 3 odprti v enem oknu pa potem zadnjega želim zapret, traja 1 do 2 sekunde, da se zapre ... ne vedno in tega nisem opazil pred SSD-jem, čeprav se je tudi verzija firefoxa in windowsa iz 7 na 8.1 spremenila, drugih sprememb ni
Je pa kr noro, da je stvar zdržala 8PB !!!! prepisov. To pomeni da je TLC na 3Dju tudi zelo dober.
kater ssd ?
kater ssd ?
FlyingBee ::
prihaja tudi 3d grafični RAM, pa HDD-ji imajo 3d, ... očitno niso samo zasloni 3d v modi
Ampak pri teh zadevah gre dejansko za nekaj uporabnega, ne pa gimmick kot je 3D tv :)
FlyingBee ::
kater ssd ?
m500 120gb, med 2 in 15gb prostega mesta se to dogaja, mogoče se je tudi prej ne vem točno, trenutno imam 2gb prosto
- spremenil: FlyingBee ()
Sprazni plac, 2GB fraj ni pretirano dobro za ssd. Nebo za to nič prej umru, sam dela pa tut ne optimalno.
FlyingBee ::
ja, v bistvu 3d tv sploh ni več v modi, zdaj samo še 4k
mislim, da mi je to delal tudi ko sem imel 15gb prosto
Naredi tole...
Backup sistema, secure erase, updejt firmware-a (če ni zadnji) in nazaj restori sistem. Pusti vsaj ene ~10GB praznega... Poročaj.
Ali pa začni uporabljat spodoben build firefoxa -- palemoon
FlyingBee ::
mah, fuknu bom SSD nekam, s HDD ji kaj takega še nisem imel ... new technology, my ass
l0g1t3ch ::
Uporabljite stable build firefoxa -- palemoon je še vedno na V24 osnovi in dela zelo dobro.
Ne krivit ssdjov za nekaj, kar ni problem v njih.
Jest sumim, da pri temu "nalozenemu" nandu uporabljajo vecje kapacitete, kot uradno so, da imajo tako velik endurance. Ok, neki dobijo na racun vecjega proizvodnjega procesa, ampak mocno dvomim, da je to dovolj. Kar tako na lepe oci, samo zato, ker je "3D" pac ne gre.
FlyingBee ::
Meni isto dela FF na HDD-ju v domačem laptopu in sicer zapiranje traja skorajda dlje kot zagon. Kje je fora nevem, se je pa pojavljo v zadnjih verzijah. Krivim OS al pa kak plugin za FF.
mah nikoli prej na HDD-ju kaj takega, saj lahko je marsikaj, ampak SSD zna bit še pain in the ass, kaj je bilo šele s prvo generacija sandforce shita
40nm proces to dela...
In kapaciteta ni nič povečana, RAW nanda je malo več, kot običajno (zarad obskurne velikosti die-a)
Raw NAND Capacity 129GiB 258GiB 516GiB 1032GiB
Prva generacija je bila čist ok (odmislimo zdaj težave z QA).
Heck, še vedno mi laufa Vertex2 v enem prenosniku. Dela kot sneta raketa :)
To je težava firefoxa. Stestiraj z Palemoon ali google free Chromom
Dvomim, da so samo s procesom toliko pridobili. To je 3x vec, kot je bil MLC pred leti podobne proizvodnje, kar nekako ni logicno. Pomoje vec kot 15-20k niso samo s tem dobili.
takrat še 40nm ni bil zrel, zdaj pa je.
Z zrelostjo se ogromno pridobi.
Recimo... 19nm TLC...
v nezreli fazi dober za 200-300 p/e
Zrela faza pa čez 1000 p/e
Pa tudi signaling je važen. Če ti agresivno brišeš bloke, endurance zelo pade. Zato ima recimo MLC-HE 10x boljši endurance, čeprav ni kej pretirano drugačen kot navadn MLC. Samo bolj prebran je, da lahko dela pri nižji napetosti (hence većji endurance).
SuperVeloce ::
od takrat, ko smo imeli 40nm ssd-je pa do sedanjih 1xnm so morali proizvajalci uporabiti tudi polno drugih pogruntavscin, katere se lahko sedaj uporabijo...
po pravici povedano se meni zdi cudez, da se lahko flash programira na tako visokih napetosti s tistimi parimi elektroni na celico in zdrzijo... in da lahko to kupimo za drobiz...
- spremenil: SuperVeloce ()
l0g1t3ch ::
Oh LOL kak odpor do SSD-jev.
Če iščeš dlako v jajcu jo boš tudi našel zgleda :)
SuperVeloce je izjavil:
Jap, v TLCju pridejo bojda na celico samo 3je !!! elektroni. Imagine that.
Sj teh 8PB ni official rejting, ampak tolk jim je zdržal en pogon. Offical rejting zna pomoje bit tam okol 10k p/e..
FlyingBee ::
mah, super je drugače SSD, precej hitreje vse, ne pa spet tako gromozansko, če se ti res ne mudi kot da gori ... HDD-ji pa še niso razočaral in upam, da me tudi SSD-ji ne bodo, garancija in endurance gor ali dol
Treba se je zavedat omejitev teh tehnologij in met neka realna pričakovanja :)
Pa seveda backup backup backup. Pa naj bo hdd, ssd al pa 5.25" disketa..
Za tale nov nand bo treba itak na neki hitrejsega, kot sata6gbit.
Vsaj neki okol 16gbit ali vec.
Drugace pa ce malo racionaliziras zapise na ssd, komot prides na 1TB/leto, kjer je pa vprasanje vzdrzljivosti povsem odvec, celo za TLC.
l0g1t3ch ::
Vsaka stvar crkne in si sam kriv, če nimaš urejenega backupa.
Crknila sta mi dva HDD-ja v razmaku parih dni iz neslavne serije IBM deskstar in pa eden 320GB Maxtor pa se za nobenega nisem pretirano sekiral.
To so 3je HDD-ji v 15ih letih, pač stvari večinoma delajo včasih pa crkne tudi brez kakih vnaprešnjih znakov. Se zgodi pač in to pokrivaš z backupom...
Absolutno, sej zato pa je sata-express
Kar se pa tiče druge točke; sploh ni treba racionalizirat. Tudi na TLCju lahko delaš 100TB na leto, pa boš prej stran vrgu stvar, predn bo odletela
