Joomla session.save_path problem
robil ::
Pri instalaciji Joomla_1.5.4-Stable-Full_Package naletim takoj na začetku na sledeči problem:
Error
An error has occurred.:
Cookies do not appear to be enabled on your browser client. You will not be able to install the application with this feature disabled. Alternatively, there could also be a problem with the server's session.save_path. If this is the case, please consult your hosting provider if you don't know how to check or fix this yourself.
S tem da so cookiji v browseru omogočeni , v php.ini pravtako vse tako kot bi moralo bit
(; where MODE is the octal representation of the mode. Note that this
; does not overwrite the process's umask.
session.save_path = "C:\tmp"
; Whether to use cookies.
session.use_cookies = 1 )
, v glavnem ne najdem napake?
Uporabljam : XP,
joomla 1.5.4
apache 2.2
mysql 5.0
phpMyAdmin - 2.11.6
A se je mogoče že kdo srečal s takšnim problemom in kasneje našel rešitev?
Hvala za odgovor, Robi
Debina9 Apache2 | ./configure, make, make install
Oddelek: Operacijski sistemi
51066 (952) HotBurek
Prijavljeni uporabniki
Oddelek: Izdelava spletišč
61320 (1138) neoserv
php funkcija
212176 (1909) simon
IIS in PHP
82483 (2358) rocki_
Tracking v PHPju
Oddelek: Programiranje
62161 (2046) darh
