DS 18S20 64bit rom branje
M@73Y ::
Pozdrav. ima kdo idejo kako prebrati naslov DS18S20 senzorja tako da bi jih lahko več naslavljav. naslov je shranjen v 64bit romu od česa je zadnjih 8 bitov (LSB) fiksno nastavljenih na &h10.
Uporabljam Bascom, atmel 89C4051, in multipleksirane 7 segmente.
Hvala. matej
..jump into psytrance tunnel..
drrogla ::
Citat iz datasheet-a (stran 10):
Read ROM [33h]
This command allows the bus master to read the
DS1820’s 8–bit family code, unique 48–bit serial number,
and 8–bit CRC. This command can only be used if
there is a single DS1820 on the bus. If more than one
slave is present on the bus, a data collision will occur
when all slaves try to transmit at the same time (open
drain will produce a wired AND result).
1-Wire protokol in DS1820
Oddelek: Programiranje
72610 (2421) ameba
nakup grafične kartice Ati vs. Geforce ;)
81600 (1339) snela
temp data logger
323739 (3159) maticm
pic ds1820 asm
132673 (2486) neoto
temperaturni senzorji
182221 (1844) DJroky
