Forum » Programska oprema » Nero-Burning Rom in Win2000?
kuntek ::
Kaj naj nastavim, da bodo lahko vsi userji v Win2000 lahko pekli CDje z Nerotom? Zdaj lahko peče samo Admin, ker Nero drugim userjem teži, da ne morejo uporabljat CD-RWja.
Nisi edini , ki imaš s tem težave.
sem iskal po forumu , pa so neke imaginarne local policy razlagali ..... itd , če kdo ve se tudi jaz priporočam.
Lime ::
Jaz se tudi priporočam za rešitev. Sicer po Win XP, ampak mislim da je isti šmorn.
V Nerotu pod help je razlaga:
The way Nero solves this problem is to allow system administrators to assign during installation a group of users the rights to record CDs on the system. If an administrator wants to allow or disallow CD recording for certain users, it is enough to make the user member of this group or to remove the group membership of that user. If everybody should get the right to record CDs, the recording rights should be assigned to the group "Users".
In some situations, it might be convenient for the administrator to change the group assigned CD recording permissions. Nero has a new property page with title "Security". This page can be opened by using the menu command "File"->"Preferences". Administrators may edit and normal users may only view the group name of the users, that have the permission to burn CDs. Any changes of these settings become effictive after the next system restart. Uninstalling Nero will cause the recording CD rights to be removed again.
Imel sem verzijo 5.5.6.x ,sedaj imam verzijo 5.5.7.4 , pa žal vem za ta help , ampa tega tam ni ?
kuntek ::
Jaz nočem pečt v mreži ampak na enem računalniku (sasox - saj veš). Verjetno imamo vsi isti problem. Če user nima Administratorskih pravic potem ne more pečt CDjev. Malo nerodno se je odjavit in prijavit kot Admin, če hočeš pečt. In ostalim, ki uporabljajo moj računalnik ne bom dal Admin pravic.
McHregec ::
Jst sm mel iste probleme v WinXp potem sem pa namestil Nero 5.5.8.0 in dela brez problemov.
Destroyer Of The Worlds.
kuntek ::
Tudi meni niti z novo verzijo ne dela. Nikjer pa ne najdem kje bi lahko to kot Admin nastavil. ANDREJ, NA POMOČ!!!
Tiger ::
Jaz sicer nisem andrej ampak...
Poskusi tole:
Control Panel -> Administrative Tools -> Local Security Policy -> Local Policies -> Security Options -> Restrict CD-ROM access to locally logged-on users only --> ENABLED
To naj bi menda delovalo, so pa potem drugi problemi, recimo s to opcijo potem ne moreš inštalirati nič od MS Office produktov.
Poskusi tole:
McHusch ::
kaj pa Run As Different User možnost, pa pol naštimaš da Nero laufa pod administratorjevem accountu.
MadMax ::
TUKAJ najbrz ni se nihce firbcal?
Nero 5.5 released!
Check out the new features introduced here!
Known issues:
Under Windows 2000, Administrator privileges are required to burn CD's
Release date: April 30th, 2001
Saj vse pise.... Pa brez Googla.
Nero 5.5 released!
Known issues:
| » | win srv 2003 - file sharingOddelek: Operacijski sistemi | 2569 (1734) | Eureka |
| » | Zaščita DVD diskaOddelek: Programska oprema | 2791 (2201) | bosmla |
| » | Kako varen je Microsoftov požarni zid? (strani: 1 2 )Oddelek: Novice / Varnost | 7243 (7243) | gumby |
| » | Nero + teacW516EBOddelek: Pomoč in nasveti | 1278 (1191) | PupaSuchen |
| » | WIN 2000 BOOT ?Oddelek: Programska oprema | 1844 (1709) | rookie |
