Doom 4
Doom 4
13 / 14
@Izi:
Doom nikoli ni imel zgodbe. Oziroma, največ zgodbe je imel še tretji del, ki pa več ni "dumačina" v pravem pomenu besede.
Na osnovi tretjega dela je tudi nastal solidni istoimenski film Doom s Karlom Urbanom in Dwayne - The Rock- Johnsonom v glavnih vlogah.
Ajde, tu imaš zgodbe prvih delov (Doom I, II in Final Doom serija in Doom 64):
http://www.classicdoom.com/doomtext.htm
Tako so zgodbo podajali na slikah:
http://doom.wikia.com/wiki/Text_screen
Story
Doom has a simple plot; its background is given in the instruction manual, and the in-game story advances mainly through short messages displayed between the game's episodes.
The player takes the role of a marine (unnamed to further represent the person playing), "one of Earth's toughest, hardened in combat and trained for action", who has been incarcerated on Mars after assaulting a senior officer when ordered to fire upon civilians. There, he works alongside the Union Aerospace Corporation (UAC), a multi-planetary conglomerate and military contractor performing secret experiments on interdimensional travel. Recently, the teleportation has shown signs of anomalies and instability, but the research continues nonetheless.
Suddenly, something goes wrong and creatures from hell swarm out of the teleportation gates on Deimos and Phobos. A defensive response from base security fails to halt the invasion, and the bases are quickly overrun by monsters; all personnel are killed or turned into zombies
A military detachment from Mars travels to Phobos to investigate the incident. The player is tasked with securing the perimeter, as the assault team and their heavy weapons are brought inside. Radio contact soon ceases and the player realizes that he is the only survivor. Being unable to pilot the shuttle off of Phobos by himself, the only way to escape is to go inside and fight through the complexes of the moon base.
Dodatni info:
http://doom.wikia.com/wiki/Doom
Bistvo pa je tole, kjer je vse prikazano (ne rabiš zgodbe):
  • spremenil: opeter ()
Izi je izjavil:
Machete je izjavil:
Mogoče sem malo pogrešal morbidnost, temačnost in element groze.
Ja, točno to je imel Doom 3, sedaj je pa grozljivka popolnoma izginila in ostala je čista streljačina.
Doom 3 na primer mi je bil zelo všeč, je pa res, da je od takrat minilo že 12 let :D Če se prav spomnim je imel bolj malo sovražnikov, ampak so bili pa mnogo bolj zapomljivi in grozljivi.
Doom 3 bolj kot ne srhljivka/pustolovščina z akcijskimi elementi. Bolje bi ga bilo primerjat s kakšnim Outlast, serijo Riddick ipd. igro kot pa s starimi igrami (ali najnovejših delom) serije Doom.
Klasični igre Doom so bolj kot ne arenske igre (pomisli na Serious Sam serijo, Painkiller ipd. igre, od novejših npr. indie-igra Lichdom: Battlemage).
Če hočeš zgodbo in pustolovske elemente, izberi Half Life, Singularity, Bioshock serijo in ostale FPS-je z zgodbo in raziskovanjem.
Izi, prava uživancija se začne v drugi polovivi, ko Doom marinca že dobro opremiš. Pol pa so to koline taprave. Da si dvigni težavnost, boš rabil kar fino izkoriščat dobrine po tleh in vrstni red klanja zaradi healtha. Morš kar malo premislit v kakšnem vrstnem redu boš spucal sobo. Drugače pe je generalno municije več kot dovolj.
Plus ne pozabit credits-outrota gledat, ker je dbest in zaključi potovanje po peklu tako kot se šika.
MasterTade ::
Najbol je biv mod brutal doom zaa doom 3d :D
Mors omnia aequat
Heavy ::
opeter je izjavil:
Spin off v seriji, ampak še vedno legendarna igra. Vse kar sem si želel, da bi Colonial Marines bili :(
Doom 2016 je odličen špil, mogoče bi si zgolj želel, da bi bil daljši. Imamo snap-map, ampak 99% map je eno sranje, akcija ni tako zvezna kot v kampanji. Multiplayer je v redu, čeprav na čase spominja na TDM iz CoD, kjer vsakdo teka naokoli kot kokoš brez glave.
Doom 1&2 pa mi nikoli nista bila všeč. Preveč pisane pošasti. Quake 1 po drugi strani pa... u-la-la :D
#TeamFelix
Netrunner ::
Heavy je izjavil:
Ti si prvi da je rekel da se mu doom 1 in 2 ni dopadel :D ... no vsak ima svoj okus vendar ne moreš primerjati z quake 1 saj je le ta prišel precej pozneje.
Truga ::
quake 1 je res super ja. 10 miljonov odtenkov rjave. :D
Jerry000 ::
Men sta hude igre...legacy. Sem jih ravno letos obrnil z užitkom :)
Heavy ::
Truga je izjavil:
Pred časom z razvojem. Po komu misliš, da so se pri Battlefield 'blue edition' 3 ozirali :))
#TeamFelix
D3m0r4l1z3d ::
Netrunner je izjavil:
Heavy je izjavil:
Quake 2 pa je bil res super.
Izi ::
Glede municije sem se motil. Ko imaš s seboj enkrat cel arzenal orožij in ko parkrat nadgradiš obleko za nošenje več municije to skoraj ne more več zmanjkati streliva :D
Sedaj problem niso več sovražniki ampak ena zaguljena mapa, kjer nikakor ne najdem poti naprej :))
Saj imaš mapo :)
Izi ::
oo7 je izjavil:
Saj imaš mapo :)
Ja saj vidim tisti sivi del kjer še nisem bil in kamor moram iti, ampak nikakor mi ne uspe priti tja. Je previsoko in predaleč.
A sem kaj spregledal glede skakanja? V nekem videu sem videl kako visoko skačejo igralci in praktično letajo po zraku, moj super duper marinec pa nikakor ne more skočiti višje kot pol metra v višino in tri metre v daljino :D
  • spremenil: Izi ()
Ja enkrat v igri dobiš čevlje, kjer imaš dvojni skok ampak zaradi tega ne skočiš ravno veliko več visoko. Potem imaš pa še portale kjer te vrže visoko v zrak ampak na začetku igre če se prav spomnim jih ni.
V kateri so bi si? Si tam kjer je lava?
Tudi z blastom določenih gunov se da skočiti višje. Torej ob skoku ustreliš ob tla. Ampak to za normalno iganje ni potrebno, se mi zdi da pa za določene skrivnosti to rabiš. Full se uporablja tudi pri spped runu, predvsem za izkorišnaje glitchev na sami mapi in posledično mnogo krajšo pot čez stopnjo.
Mogoče si res spregledal kje leteče škornje, ki ob dvojnem pritisku jumpa povišajo skok.
  • spremenil: Machete ()
Meni pa Quake serija ni bila nikoli posebej všeč. Prva je precej satanistična, "štimung" te je sicer okej, drugi pa je šel v neko sci-fi smer, pojavili so se Stroggi. Arena pa je spet neka ločena veja. Štirka je pa nadaljevanje dvojke (sp način ni slab, to priznam).
dolenc ::
Ko je doom pršu vn, je bil gaming(pri nas pa sploh) še mal v povojih, win95 še ni bila uveljavljena zadeva(oz ga nit ni blo :D) in računalnik za domačo rabo je bila dost redkost. Tud quake 1 je bil še malo zgoden.
Leta 98 ko je pa quake 2 kraljeval, je bla pa scena že razvita, folk je že mel pentiume, pcgamer in podobne revije so pumpale folk z opisi in demoti... Vsem so se sline cedile nad grafiko, FPS žanr je bil nekak na vrhu prehranjevalne verige gejminga in quake 2 je bil na najvišji stopnički :)
Evo preigral rabil slabih 12 ur. Igra je odlična gameplay hiter glasba zelo dobra zgodbe pa ravno prav :) Upam, da naredijo nadaljevanje.
DOOM zgodba SPOILER!!!!
SPOILER!!!!!
Torej Doom Slayer, ki ga mi igramo ni človek glede na to, da je rekel robot na koncu, da ga ne morejo ubiti samo je pa demon rekel, da je edini z mesa, ki lahko hodi med dimenzijami?. Torej ubiti ga ne morejo ampak ga lahko samo zaprejo v tisto kamnito skrinjo kjer se je na začetku zbudil? :)
Truga ::
Dr_M je izjavil:
Quake > Doom.
Nah. Doom ljudje dandanes precej bolj redno igrajo kot quake (pa precej tudi novih igralcev, ne sam stari). Gameplay je bolj zabaven in zadeva ne zgleda prevec grozno, kljub temu da je stara ze krepko preko 20 let. Texture in sprajti so sicer pixel art, ampak so zelo dober pixel art.
Quake se je staral neprimerno slabse. Orozja so dolgocasna za popizdit, level design je od zacetka se malo zanimiv, pol pa pade na nivoje kjer najslabsi doom2 leveli ne morejo niti priblizno konkurirat, modeli zgledajo kot da je en bruhnil in sestavil koscke pa to importal v game, skini pa so navadni zmazki. Texture in ambient nasploh je experiment, koliko procentov palete lahko naredis rjave, preden folk opazi da bi mel s crno-rjavim ekranom isto izkusnjo.
Quake multiplayer se je njega dni sicer igralo vec, ker je qworld delal preko interneta, doom pa ne. Ampak tud ta problem je pri doomu resen ze zelo dolgo. Ce zdajle pozenem zandronum imam server s 40 pinga kjer lahko igram z ljudmi tudi ob teli nenormalni uri. Qworld? Mogoce 15 let nazaj. Stevilo in kvaliteta user map in modov za oba se tud precej razlikujeta, in za doom se vedno vsako leto ali 2 pride kak noro dobr wad.
Quake je sicer dodal par reci ki jih v doomu ni bilo (mouselook je zelo nice nice zadeva), ampak rect da je quake neki blazno groundbreaking, ker naj bi poudarek na movementu je pa malo hecno, ko je doom hitrejsi game. Sploh ko so ljudje nahekali skakanje v doom, in se je strejfjumpalo cez mape 1 leto preden je quake sploh izsel (ja, ze doom engine ima ta glitch :P).
Pa ne recem, quake je prisel dalec, in s q3a so res zrihtali multiplayer na top nivo, in se doom ne more vec primerjat. Jasno, pri q3a je bil multiplayer glavni in edini cilj. Ampak se v q3a se krepko cuti, da je doomov naslednjik. Mogoce celo bolj, kot v q1.
D3m0r4l1z3d ::
Občutek streljanja in učinek v q2 je bil revolucija. Super igra v 1998, dolenc je dobro povzel dogajanje takrat, jaz sem sicer z nakupov pcja pri Jerovšku dobil Joker revijo s cdjem kjer je bil demo q2 in sem potem to ne vem kolikokrat obrnil. Zdaj je teh iger kot dreka in ni več isto za mladino.
D3m0r4l1z3d ::
Seveda so bili wolfenstein, doom, shadow warrior, duke nukem 3d prej, vse sem tudi že igral, ampak q2 je bil prelomnica. Sta pa Unreal in Half life poskrbela, da q2 izpade že takrat obsoleten po grafiki, sama dinamika premikanja in streljanja pa je praktično še zdaj enaka.
D3m0r4l1z3d je izjavil:
To pa. Mouse look.
Jerry000 ::
This! Ko smo demote preigral in obračal kot nori. Demoti so bili za tisti čas sveti :)
Tr0n ::
DOOM 3 part dokumentarec by noclip (Danny O'Dwyer).
Nisem rekel, da Quake 1 v tehnološkem smislu ni bil nadmočen. Že zaradi tega, ker je popularizial svobodni pogled z miško in tipkovnico (kot je to D3m že napisal); čeprav ni bila prva igro, ki je to naredila, prva se mi zdi, da je bila Cyclone od SSI iz leta 1994 oz. morda še pred tem Originov/Ravenov Shadow Caster (1993).
Ampak za grafični del bi lahko isto rekli za Doom 3, katerega je pozneje prehitel kakšen Prey, Quake 4 morda Wolfenstein (2009) - vsi ti so uporabljali isti grafični pogon. No, potem so prišli še drugi grafični pogoni (Crytekov, Unreal v tretji iteraciji itn.) ...
Pri Quake-u so mene motile predvsem "male" sobe in preveč rjavkaste barve. Da ne bo nesporazuma, govorim o prvem delu.
Drugi del je bil že malenkost boljši, ampak nima več nobene povezave s prvim. Prvi je imel meni zanimivejše sovražnike.
Je kdo od vas igral Chasm: The Rift? Igra je izšla kmalu po prvem delu Quake-a.
dolenc ::
Prvič vidm :)
Pc Gamer
Best Comeback 2016: Doom
http://www.pcgamer.com/best-comeback-20...
Če ima kdo Poršeja :))
How to mod your Porsche 911 or other car to run Doom in 3 easy steps
vostok_1 ::
Rich geeks, damn. How apparent.
There will be chutes!
It came from the lab.
Bolj očitno ne gre.
Isti fant/moški:
vostok_1 ::
To be honest...funny as hell! (pardon the pun)
Diablo Empire1 year ago
Need help, got my penis stuck in the toaster :(
108
Agustin Pérez Burgos
Agustin Pérez Burgos1 year ago
+Diablo Empire on cmd, "write toast_disable_penis on". That should work
Komentarji. ahahaha
  • spremenil: vostok_1 ()
Tr0n ::
dolenc ::
S patchom 6.66, so se vsi online dlcji odklenili za tiste, ki jih niso imeli.
r3dkv1c4 ::
dolenc je izjavil:
hvala za info
Niti nisem šel za tem...bom preveril.
Vsaka stvar ima svojo mejo.
You can ban me, but you can't shut me down!
Doom na steamu 15€.
Ijus ::
a je doom (4) v fpp izvedbi (škatla pa to) na dvdjih al bdju?
al nemara ključku?
  • spremenil: Ijus ()
Ijus je izjavil:
al nemara ključku?
Če sprašuješ za PC verzijo, je ta na dvoslojnem DVD-ju.
Pri namestitvi ti prvo namesti cca. 7 GB podatkov, ostalo (okoli 40-45 GB) pa ti povleče preko Steama.
Ijus ::
aha. cool. uber cool.
evo, da po pravic povem. dol potegnu skrekano verzijo. zdaj jo bom deinštaliral.
pa prec kupil fpp pc box ko dobim next denar.
cene vidm, da so padle. kolega rekel, da zgleda da ni več tolk popularna pa net multiplayer pa to.
ja. sorry fo unspecifiness. pc verzijo, ja.
tolk sem gor dal, da sem sprobal špil pa kolk je kej dober na nov kuplen laptop. pr telekomu sem kupil asus rog strix gl753vd. dela uber smooth na vse na ultra pa max. edino uno eno stopnjo več mi ne potegne ker špil prav da rabm grafo z 5gb. tle not v laptopu mam gtx 1050 z 4gb.
fak. uber zakon špil.
že enko pa dvojko sem nažigal po cele dneve. pa pred tem spear of destiny pa wolfenstein. lol 20 let nazaj.
gore... haha.
fireX88 ::
Ijus je izjavil:
gore... haha.
Mislim, da ti potrebuješ učno uro ali dve slovenščine, ne pa igranje.
Ijus ::
Ijus je izjavil:
gore... haha.
Poznaš igro Gore: Ultimate Soldier?
D3m0r4l1z3d ::
Kaj je to mod za SOF2 ali kaj
Ne, ločena igra, ki je leta 2008 postala freeware. Samo sem se je spomnil, ko je zgoraj omenjena beseda GORE.
Več pa tukaj in tukaj.
Več pa ne bom smetil teme, da ne bom Off-topic.
Ali kdo ve, kje bi se dalo dobiti v dobri ločljivosti grafiko Dooma 4 (ki je podobna klasičnemu Doomu), da bi si pri znancu dal naprintat poster v A2 formatu? Sem našel neke slike, a večina je okoli 2000 pikslov.
petrus ::
To je najboljše kar sem našel, 1920x1080:
stati inu obstati
Najlepša hvala! :)
Vazelin ::
Jaz spet obračam prejšnji DOOM.
Igra je še vedno svinjsko dobra.
Res nora zmes vzdušja, streljanja, odlična zvočna podlaga.
Mislim da ga bom obrnil v par dnevih.
Mljask!
Ijus ::
ku**a moj kolega ga je na mojem kompu obrnil v cca 6 urah
13 / 14
Kaj trenutno igrate? (strani: 1 2 3 4 … 61 62 63 64 )
Oddelek: Igre
3190616464 (2157) razor1911
DOOM Eternal (strani: 1 2 3 4 5 6 7 8 )
Oddelek: Igre
37762039 (21746) oo7
Rage 2 (strani: 1 2 3 )
Oddelek: Igre
10818851 (12022) yoco
Wolfenstein: Youngblood (strani: 1 2 3 )
Oddelek: Igre
11322728 (18399) PH03N1X
Quake Champions (Quake 5) (strani: 1 2 3 )
Oddelek: Igre
13922434 (12875) scipascapa
