Forum » Pomoč in nasveti » Kako rešiti?
Kako rešiti?
handzi ::
Obstaja način rešitve obstoječega problema?!?
Device cannot start.
Cause: A device has a configuration problem that prevents it from starting properly.
Details: The device, CD-ROM Drive, cannot start properly. It may not have the correct driver installed or may be experiencing a hardware failure. The Plug and Play ID for this device is IDE\CDROMMATSHITA_DVD-RAM_UJ-861H________________1.50____\5-35778DAE-0-0.0.0.
Iscem pomoc ljudi, ki se spoznajo na to - tak da bi lepo prosu ce se najde kak uporaben nasvet tudi tukaj
(glede na to da zaupam predlogom na totem forumu;)
HVALA!!
HVALA!!
handzi ::
sistemska informacija kaže sledeče:
Pogon Ni na voljo
Opis CD-ROM Drive
Naloženi medij Ne
Vrsta medija UNKNOWN
Ime MATSHITA DVD-RAM UJ-861H ATA Device
Izdelovalec (Standard CD-ROM drives)
Stanje Error
Hitrost prenosa -1.00 kbajtov/s
ID za ciljni SCSI Ni na voljo
ID PNP naprave IDE\CDROMMATSHITA_DVD-RAM_UJ-861H________________1.50____\5&35778DAE&0&0.0.0
Gonilnik c:\windows\system32\drivers\cdrom.sys (6.0.6000.16386, 65,50 KB (67.072 B), 2.11.2006 9:51)
Pogon Ni na voljo
Opis CD-ROM Drive
Naloženi medij Ne
Stanje Error
El Nino ::
Iz prvega poročila je razvidno, da je 'driver missing'. Torej, poskusi z uradne strani povlečt driverje za to zadevo in jih inštalirat pa poročaj
StratOS ::
V večino primerov gre za probleme z registrom :
Zgleda imaš gor XP ali Visto, mislim, pa da gre za drive prenosnika, če se ne motim.
http://support.microsoft.com/kb/314060
http://www.fixya.com/support/t173457-vista_toshiba_matshita_dvd_ram_problem
http://support.microsoft.com/?scid=kb%3Bde%3B320553&x=9&y=14
"Multitasking - ability to f##k up several things at once."
"It works better if you plug it in."
"The one who is digging the hole for the other to fall in is allready in it."
| » | ProblemOddelek: Pomoč in nasveti | 1706 (1448) | BorutK-73 |
| » | XP-ji in sfižen certifikat za klikOddelek: Pomoč in nasveti | 1585 (1431) | Tomas 33 |
| » | ne najde OSOddelek: Pomoč in nasveti | 1610 (1610) | solatko |
| » | 'Legalizacija' Windows XP brez ponovne namestitveOddelek: Operacijski sistemi | 3732 (3125) | Rok Nemec |
| » | Detecting IDE...Oddelek: Pomoč in nasveti | 1288 (1167) | Lucifix |
