Kako rešiti?
Kako rešiti?
handzi ::
Obstaja način rešitve obstoječega problema?!?
Device cannot start.
Cause: A device has a configuration problem that prevents it from starting properly.
Details: The device, CD-ROM Drive, cannot start properly. It may not have the correct driver installed or may be experiencing a hardware failure. The Plug and Play ID for this device is IDE\CDROMMATSHITA_DVD-RAM_UJ-861H________________1.50____\5-35778DAE-0-0.0.0.
Iscem pomoc ljudi, ki se spoznajo na to - tak da bi lepo prosu ce se najde kak uporaben nasvet tudi tukaj :\ (glede na to da zaupam predlogom na totem forumu;)
HVALA!!
handzi ::
sistemska informacija kaže sledeče:
Pogon Ni na voljo
Opis CD-ROM Drive
Naloženi medij Ne
Vrsta medija UNKNOWN
Ime MATSHITA DVD-RAM UJ-861H ATA Device
Izdelovalec (Standard CD-ROM drives)
Stanje Error
Hitrost prenosa -1.00 kbajtov/s
ID za ciljni SCSI Ni na voljo
ID PNP naprave IDE\CDROMMATSHITA_DVD-RAM_UJ-861H________________1.50____\5&35778DAE&0&0.0.0
Gonilnik c:\windows\system32\drivers\cdrom.sys (6.0.6000.16386, 65,50 KB (67.072 B), 2.11.2006 9:51)
El Nino ::
Iz prvega poročila je razvidno, da je 'driver missing'. Torej, poskusi z uradne strani povlečt driverje za to zadevo in jih inštalirat pa poročaj ;)
StratOS ::
V večino primerov gre za probleme z registrom :
Zgleda imaš gor XP ali Visto, mislim, pa da gre za drive prenosnika, če se ne motim.
http://support.microsoft.com/kb/314060
http://www.fixya.com/support/t173457-vista_toshiba_matshita_dvd_ram_problem
http://support.microsoft.com/?scid=kb%3Bde%3B320553&x=9&y=14
"Multitasking - ability to f##k up several things at once."
"It works better if you plug it in."
"The one who is digging the hole for the other to fall in is allready in it."
Problem
191705 (1447) BorutK-73
XP-ji in sfižen certifikat za klik
61585 (1431) Tomas 33
ne najde OS
91610 (1610) solatko
'Legalizacija' Windows XP brez ponovne namestitve
Oddelek: Operacijski sistemi
193732 (3125) Rok Nemec
Detecting IDE...
191288 (1167) Lucifix
