Novi dvd pekač mi povzroča težave (buffer too large)
Sp|kE ::
Zdravo. Pred kratkim sem kupil dvd pekač NEC DVD RW AD-7191A. Pojavlja pa se mi naslednja težava ... ko začnem peči dvd, mi napiše BUFFER TOO LARGE, enostavno vrže ven dvd in ga sploh ne začne peči. Imam nero 8, firmware za pekač sem posodobil na najnovejši, pa nič ne pomaga.
LOG:
Windows XP 5.1
IA32
WinAspi: -
NT-SPTI used
Nero Version: 8.2.8.0
Internal Version: 8, 2, 8, 0
(Nero Express)
Recorder: DVD RW AD-7191A> Version: 1.05 - HA 1 TA 0 - 8.2.8.0
Adapter driver: < IDE > HA 1
Drive buffer : 2048kB
Bus Type : default
CD-ROM: < Optiarc DVD RW AD-7191A >Version: 1.05 - HA 1 TA 0 - 8.2.8.0
=== Scsi-Device-Map ===
DiskPeripheral : HDS722580VLAT20 V32O viadsk Port 0 ID 0 DMA: Off
DiskPeripheral : Maxtor 6Y080L0 YAR4 viadsk Port 0 ID 1 DMA: Off
CdRomPeripheral : Optiarc DVD RW AD-7191A 1.05 viadsk Port 1 ID 0 DMA: Off
=== CDRom-Device-Map ===
Optiarc DVD RW AD-7191A F: CdRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 1023MB (1048048kB)
Free physical memory: 682MB (698984kB)
Memory in use : 33 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
17.3.2008
UDF/ISO compilation
8:54:13 #1 Text 0 File SCSIPTICommands.cpp, Line 450
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
8:54:14 #2 Phase 112 File dlgbrnst.cpp, Line 1767
DVD-Video files reallocation started
8:54:14 #3 Phase 114 File dlgbrnst.cpp, Line 1767
DVD-Video files reallocation completed (no file modified)
8:54:14 #4 Text 0 File Isodoc.cpp, Line 6655
UDF document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
UDF Mode : UDF/ISO bridge
UDF Options : automatic
UDF Revision : 1.02
UDF Partition Type : physical
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : FALSE
Allow pathdepth more than 8 directories : FALSE
Allow more than 255 characters in path : FALSE
Write ISO9660 ;1 file extensions : TRUE
8:54:14 #5 Phase 111 File dlgbrnst.cpp, Line 1767
DVD-Video files sorted
8:54:14 #6 ISO9660GEN -11 File Geniso.cpp, Line 3349
First writeable address = 0 (0x00000000)
8:54:14 #7 ISO9660GEN -11 File Geniso.cpp, Line 3349
8:54:15 #8 Text 0 File Burncd.cpp, Line 3502
Turn on Disc-At-Once, using DVD media
8:54:15 #9 Text 0 File FilesystemSettingsValidator.cpp, Line 142
FS Settings: using validator 'CUDFSettingsValidatorDVD'
ParamMode = 'automatic', changing UDF partition type from 'physical' to 'physical'
Changing UDF revision from '1.02' to '1.02'
8:54:17 #10 Text 0 File DlgWaitCD.cpp, Line 307
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 2035535 (452:20.35, 3975MB)
8:54:17 #11 Text 0 File DlgWaitCD.cpp, Line 319
Write in overburning mode: NO (enabled: CD)
8:54:17 #12 Text 0 File DlgWaitCD.cpp, Line 2957
Recorder: Optiarc DVD RW AD-7191A, Media type: DVD-RW
Disc Manufacturer ID: < MKM 01> < RW6X01>
Disc Application Code: 2, Disc Physical Code: 214
8:54:17 #13 Text 0 File DlgWaitCD.cpp, Line 493
>>> Protocol of DlgWaitCD activities:
8:54:17 #14 Text 0 File ThreadedTransferInterface.cpp, Line 762
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2035536 (2035536) = #2035536/452:20.36
relocatable, disc pos for caching/writing not required/ required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2035536 blocks [F: Optiarc DVD RW AD-7191A]
8:54:18 #15 Text 0 File ThreadedTransferInterface.cpp, Line 964
Prepare [F: Optiarc DVD RW AD-7191A] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4168777728, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 2035536 | 0 | 0x00
2035536 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
8:54:18 #16 Text 0 File SCSIPTICommands.cpp, Line 240
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
8:54:18 #17 Text 0 File Burncd.cpp, Line 4288
Caching options: cache CDRom or Network-Yes, small files-No < 64KB)
8:54:18 #18 Phase 24 File dlgbrnst.cpp, Line 1767
Caching of files started
8:54:18 #19 Text 0 File Burncd.cpp, Line 4407
Cache writing successful.
8:54:18 #20 Phase 25 File dlgbrnst.cpp, Line 1767
Caching of files completed
8:54:18 #21 Phase 36 File dlgbrnst.cpp, Line 1767
Burn process started at 6x (8.310 KB/s)
8:55:28 #22 Text 0 File ThreadedTransferInterface.cpp, Line 2681
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
8:55:28 #23 Text 0 File DVDR.cpp, Line 3273
Recording mode: Sequential Recording Mode
8:55:28 #24 Text 0 File DVDR.cpp, Line 3427
Start write address at LBA 0
DVD high compatibility mode: Yes
8:55:29 #25 Text 0 File Cdrdrv.cpp, Line 10140
---- Disc Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-RW (3), Extended Part Version: 0.0 (0)
Disc Size: 120 mm, Maximum Transfer Rate: < not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
Outer Limit of Data Recordable Area: 0 h
Data in Burst Cutting Area (BCA) does not exist
Revision number of maximum recording speed: -
Revision number of minimum recording speed: -
Revision number table of recording speed: - - - - - - -
Class: 0, Extended part version: 0
Start PSN of the Extra Border Zone: 0 h
Start PSN of Physical format information blocks in Extra Border Zone: 0 h
Media Specific [16..783]:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
11 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
01 02 D6 FD 9E D8 31 00 - 02 00 00 00 00 00 00 00 ......1.........
03 4D 4B 4D 20 30 31 00 - 04 52 57 36 58 30 31 00 .MKM.01..RW6X01.
05 00 00 00 00 00 00 00 - 06 15 08 06 30 14 10 00 ............0...
07 1E 05 02 88 20 16 00 - 08 24 10 04 40 0D 00 00 .........$..@...
09 25 09 05 88 40 0A 00 - 0A 00 00 00 00 00 00 00 .%...@..........
0B 00 00 00 00 00 00 00 - 0C 00 00 00 00 00 00 00 ................
0D 00 00 00 00 00 00 00 - 0E 1E 11 13 08 01 11 00 ................
0F 10 0C 01 15 15 01 00 - 10 25 0F 08 88 60 01 00 .........%...`..
8:55:29 #26 Text 0 File DVDR.cpp, Line 3565
Reserved Track size: 2035536 (1F0F50h, 3975MB) -> return code 0
8:55:29 #27 Text 0 File ThreadedTransfer.cpp, Line 269
Pipe memory size 83836800
8:55:32 #28 SPTI -31 File SCSIPassThrough.cpp, Line 197
CdRom0: SCSIStatus(x00) WinError(87) NeroError(-31)
CDB Data: 0x2A 00 00 00 00 00 00 00 20 00 00 00
Sense Key: 0x00 (KEY_NO_SENSE)
Sense Code: 0x00
Sense Qual: 0x00
Sense Area: 0x00 00 00 00 00 00 00 00 00 00 00 00 00
Buffer x0a160040: Len x10000
0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
8:55:32 #29 SPTI -31 File SCSIPassThrough.cpp, Line 197
Sense Code: 0x00
Sense Qual: 0x00
Buffer x09d21040: Len x10000
8:55:32 #30 Text 0 File MMC.cpp, Line 20238
Writer-Buffer for 㩆传瑰慩捲䐠䑖删⁗䑁㜭㤱䄱 reduced to 32768Bytes
8:55:32 #31 SPTI -31 File SCSIPassThrough.cpp, Line 197
CDB Data: 0x2A 00 00 00 00 00 00 00 10 00 00 00
Sense Code: 0x00
Sense Qual: 0x00
Buffer x09c8f5c0: Len x8000
8:55:32 #32 CDR -31 File Writer.cpp, Line 306
Buffer too large
8:55:32 #33 Phase 181 File dlgbrnst.cpp, Line 1767
Writing lead-out...
8:55:33 #34 Text 0 File DVDR.cpp, Line 3833
EndDAO: Last written address was -1 (FFFFFFFFh)Estimated time for 30mm Borders: 12min 29sec
8:55:33 #35 Phase 38 File dlgbrnst.cpp, Line 1767
Burn process failed at 6x (8.310 KB/s)
8:55:33 #36 Text 0 File SCSIPTICommands.cpp, Line 287
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
8:55:36 #37 Text 0 File Cdrdrv.cpp, Line 11391
DriveLocker: UnLockVolume completed
8:55:36 #38 Text 0 File SCSIPTICommands.cpp, Line 450
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Če je kdo imel podobno težavo ali če ve, kako jo odpraviti, bi ga lepo prosil za pomoč. Hvala.
jan01 ::
Predlagam, da vrneš(ne ukvarjaj se z garancijo) in vzemi samsunga, liteona, ....
ZA vse, ki še ne veste: odkar je nec prodal izdelavo optičnih pogonov, je vse kar je ostalo le ime!
Nero 7 Premium
Oddelek: Programska oprema
121923 (1677) kriko1
NEC DVD ND-4550
91958 (1794) jernejk90
LG GSA-4120B dela probleme pri pečenju DL DVD+Rjev
442166 (1975) mtosev
Kateri DVD+/-RW? (strani: 1 2 3 )
10011529 (9153) AtaStrumf
PLEXTOR BurfProof unicuje cdje - prosim pomagajte!
92133 (1887) krho
