[c#] multipart-form upload datoteke
Matthew ::
Na strežniku imam PHP skripto s formo, ki sprejme nekaj tekstovnih vnosov in eno datoteko. Z metodo POST se to potem obdela in shrani tako, kot je treba.
Zdaj se pa mučim s C# aplikacijo, ki bi te podatke (par tekstovnih polj in datoteko) poslala v obdelavo tej skripti. Je kdo že počel kaj takega in mi lahko pomaga?
Matthew ::
Znam poslati datoteko, ki je potem v PHP datoteki na strežniku dostopna s $_FILES in pa tekst, ki je dostopen preko $_GET. Rad pa bi tekst prebral it $_POST.
Uporabljam spodnjo kodo:
CookieContainer cookies = new CookieContainer();
NameValueCollection querystring = new NameValueCollection();
querystring["uname"] = "Dodo";
String uploadfile;
uploadfile = "M:\\slike\\slika.jpg";
String outdata = UploadFileEx(uploadfile, "http://www.spletnastran.si/test.php", "filename", "image/jpeg", querystring, cookies);
MessageBox.Show(outdata);
public static string UploadFileEx(string uploadfile, string url, string fileFormName, string contenttype, NameValueCollection querystring, CookieContainer cookies)
            if ((fileFormName == null) ||
                (fileFormName.Length == 0))
                fileFormName = "file";
            if ((contenttype == null) ||
                (contenttype.Length == 0))
                contenttype = "application/octet-stream";
            string postdata;
            postdata = "?";
            if (querystring != null)
                foreach (string key in querystring.Keys)
                    postdata += key + "=" + querystring.Get(key) + "&";
            Uri uri = new Uri(url + postdata);
            string boundary = "----------" + DateTime.Now.Ticks.ToString("x");
            HttpWebRequest webrequest = (HttpWebRequest)WebRequest.Create(uri);
            webrequest.CookieContainer = cookies;
            webrequest.ContentType = "multipart/form-data; boundary=" + boundary;
            webrequest.Method = "POST";
            // Build up the post message header
            StringBuilder sb = new StringBuilder();
            sb.Append("--");
            sb.Append(boundary);
            sb.Append("\r\n");
            sb.Append("Content-Disposition: form-data; name=\"");
            sb.Append(fileFormName);
            sb.Append("\"; filename=\"");
            sb.Append(Path.GetFileName(uploadfile));
            sb.Append("\"");
            sb.Append("\r\n");
            sb.Append("Content-Type: ");
            sb.Append(contenttype);
            sb.Append("\r\n");
            sb.Append("\r\n");
            string postHeader = sb.ToString();
            byte[] postHeaderBytes = Encoding.UTF8.GetBytes(postHeader);
            // Build the trailing boundary string as a byte array
            // ensuring the boundary appears on a line by itself
            byte[] boundaryBytes = Encoding.ASCII.GetBytes("\r\n--" + boundary + "\r\n");
            FileStream fileStream = new FileStream(uploadfile, FileMode.Open, FileAccess.Read);
            long length = postHeaderBytes.Length + fileStream.Length + boundaryBytes.Length;
            webrequest.ContentLength = length;
            Stream requestStream = webrequest.GetRequestStream();
            // Write out our post header
            requestStream.Write(postHeaderBytes, 0, postHeaderBytes.Length);
            // Write out the file contents
            byte[] buffer = new Byte[checked((uint)Math.Min(4096, (int)fileStream.Length))];
            int bytesRead = 0;
            while ((bytesRead = fileStream.Read(buffer, 0, buffer.Length)) != 0)
                requestStream.Write(buffer, 0, bytesRead);
            // Write out the trailing boundary
            requestStream.Write(boundaryBytes, 0, boundaryBytes.Length);
            WebResponse responce = webrequest.GetResponse();
            Stream s = responce.GetResponseStream();
            StreamReader sr = new StreamReader(s);
            return sr.ReadToEnd();
Matthew ::
OK, mi je že uspelo.
Tukaj je spremenjena koda:
NameValueCollection formValues = new NameValueCollection();
formValues["uname"] = "Dodo";
String uploadfile;
String outdata = UploadFileEx(uploadfile, "http://www.spletnastran.si/test.php", "filename", "image/jpeg", formValues, null);
        public static string UploadFileEx(string uploadfile, string url, string fileFormName, string contenttype, NameValueCollection formValues, CookieContainer cookies)
            Uri uri = new Uri(url);
            for (int i = 0; i < formValues.Count; i++)
                sb.Append("--");
                sb.Append("\r\n");
                sb.Append("Content-Disposition: form-data; name=\"" + formValues.GetKey(i) + "\"");
                sb.Append("\r\n");
                sb.Append("\r\n");
                sb.Append(formValues.Get(i));
                sb.Append("\r\n");
            sb.Append("--");
            sb.Append("\r\n");
            sb.Append("Content-Disposition: form-data; name=\"" + fileFormName + "\"; filename=\"" + Path.GetFileName(uploadfile) + "\"");
            sb.Append("\r\n");
            sb.Append("Content-Type: " + contenttype);
            sb.Append("\r\n");
            sb.Append("\r\n");
            MessageBox.Show(postHeader);
            int bytesRead = 0;
  • spremenil: Matthew ()
Visual C# problem
Oddelek: Programiranje
303955 (3127) mladec
[Java] Sortiranje razredov
101927 (1674) Spura
[PHP]Zajem slike iz direktorija
51758 (1675) KernelPanic
Printanje na papir java problem
71549 (1356) javaMaster
[C#] Simobilov Glasnik
134827 (1907) Mrch
