Forum » Programiranje » [PHP]Zajem slike iz direktorija
KernelPanic ::
Spostovani!
V bazi imam tabelo, ki opisuje kategorije izdelkov. V prestashop-u ima vsaka kategorija (lahko, odvisno od uporabnika) svojo sliko, ki jih shranjuje na server v direktorij /httpdocs/img/c. Jaz iz te tabele pobiram imena kategorij, nato nastavim pot in v array probam spravit sliko. Nato vse skupaj zapakiram v json objekt in ga posljem klientu, da ga prikaze. Vendar dobim od php skripte sledece warninge in errorje:
"Warning: file_get_contents(/httpdocs/img/c/199-large.jpg) 'function.file-get-contents'function.file-get-contents: failed to open stream: No such file or directory in /var/www/moja-domena.com/php/getCategories.php on line 54. Tukaj je pa omenjena php skriptka:
[{"name":"Ostale teko?ine","path":"\/httpdocs\/img\/c\/16-large.jpg","image":null},{"name":"KATEGORIJA1","path":"\/httpdocs\/img\/c\/74-large.jpg","image":null},{"name":"KATEOGRIJA2","path":"\/httpdocs\/img\/c\/75-large.jpg","image":null},{"name":"KATEGORIJA3 KATEGORIJA4","path":"\/httpdocs\/img\/c\/87-large.jpg","image":null},{"name":"KATEGORIJA5","path":"\/httpdocs\/img\/c\/159-large.jpg","image":null},{"name":"KATEGORIJA6","path":"\/httpdocs\/img\/c\/199-large.jpg","image":false}]"
<?php
session_start();
if($_SERVER["REQUEST_METHOD"]=="POST")
$hostname_localhost ="localhost";
$database_localhost ="oljedirekt";
$username_localhost ="oljedirekt";
$password_localhost ="oljedirekt";
$path_to_categories_images="/httpdocs/img/c/";
$localhost=mysql_connect($hostname_localhost,
$username_localhost,
$password_localhost) or die(mysql_error());
mysql_select_db($database_localhost) or die(mysql_error());
$query_categories_id_numbers=mysql_query("SELECT id_category
FROM ps_category
WHERE id_parent=1 AND active=1");
// echo mysql_error(); // debug code
$number_of_categories=mysql_num_rows($query_categories_id_numbers);
if($number_of_categories>0)
// CATEGORIES NAMES FETCH
$categories_id_numbers="";
while($category_id_number=mysql_fetch_assoc($query_categories_id_numbers))
$categories_id_numbers.=$category_id_number['id_category'].",";
} // while
$categories_id_numbers = substr($categories_id_numbers,
0,
strlen($categories_id_numbers)-1);
// echo $categories_id_numbers; // debug code
$query_categories_names=mysql_query("SELECT id_category,name
FROM ps_category_lang
WHERE id_category IN ($categories_id_numbers) AND id_lang=1");
// print_r($query_categories_names); // debug code
$number_of_categories_names=mysql_num_rows($query_categories_names);
if($number_of_categories_names>0)
while($categories=mysql_fetch_assoc($query_categories_names))
$path_to_image=$path_to_categories_images.$categories['id_category']."-large.jpg";
$image_content=file_get_contents($path_to_image);
$userdata[]=array("name" => $categories['name'],
"path" => $path_to_image,
"image" => $image_content);
} // while
print(json_encode($userdata));
} // if
// END OF CATEGORIES NAMES FETCH
// CATEGORIES IMAGES FETCH
// END OF CATEGORIES IMAGES FETCH
else
} // if
} // if
?>Od kod se mi prikradejo backslashi? Po moje zaradi teh backslashov ne najde poti do slik. Pravice na nivoju filesystem-a sem nastavil na 777 (testno). - spremenil: KernelPanic ()
KernelPanic ::
Poizkusi z stripslashes()Ahaaaaaa, takoj probam, samo se vedno mi ni jasno, od kod se slashi pojavijo!? Nisem ravno vesca PHPja (se).
Sment, isti rezultat, ne pomaga!
KernelPanic ::
V bazi (tabeli) sploh ni fielda, ki bi dal pot do slike na disku, ampak jo prestashop zgenerira z eno skripto. Jaz ne uporabljam prestashop skript, ceprav so na serverju, ampak pisem svoje in zgornja php skripta se izvede, ko bi klient rad dobil seznam kategorij izdelkov. Kot vidis, mi imena kategorij lepo pobere, samo se tale pot do slik me heca ...
KernelPanic ::
Ok, smo porihtali, zgleda, da se sedaj image prenese do Android aplikacije, vendar imam spet problem. V spodnji kodi:
private boolean getMerhcandiseCategories() throws Exception
InputStream is=null;
String result=null;
boolean bOperationSuccess=false;
try
this.setDataResponse(this.dataClient().execute(this.dataPost()));
this.setDataEntity(this.dataResponse().getEntity());
is=this.dataEntity().getContent();
BufferedReader reader=new BufferedReader(new InputStreamReader(is,
("UTF-8")));
StringBuilder sb=new StringBuilder();
while((result=reader.readLine())!=null)
sb.append(result)/*.append("\n")*/;
} // while
result=sb.toString();
if(!result.isEmpty())
JSONArray jsonUserdata=new JSONArray(result);
this.setMerchandiseCategories(new CItemMerchandiseCategory[jsonUserdata.length()]);
for(int iIndex=0; iIndex<jsonUserdata.length(); iIndex++)
Bitmap bmpCategoryImage=null;
try
Object jsonImage=jsonUserdata.getJSONObject(iIndex).get("image");
byte[] rawImage=jsonImage.toString().getBytes();
bmpCategoryImage=BitmapFactory.decodeByteArray(rawImage,
0,
iIndex);
catch(Exception ex)
String strClassName=ex.getClass().getName().toString();
String strMessage=ex.getMessage().toString();
Log.wtf(CDatabaseManager.m_strLogTag,
strClassName+":"+
strMessage);
ex.printStackTrace();
String strCategoryName=jsonUserdata.getJSONObject(iIndex).getString("name");
this.merchandiseCategories()[iIndex]=new CItemMerchandiseCategory(bmpCategoryImage,
strCategoryName);
} // for
bOperationSuccess=true;
else
throw new Exception(CDatabaseManager.ERROR_NO_MERCHANDISE_CATEGORIES_FOUND);
} // if
catch(Exception ex)
strClassName+":"+
strMessage);
} // try-catch
return bOperationSuccess;
} // getMerhcandiseCategoriesse mi zatakne v vrstici, kjer bi rad kreiral array json objektov. Torej, ta vrstice mi vrze exception. Zakaj?? Vredno ogleda ...
| » | [Java]Listanje slikovnih datotek v izbranem direktorijuOddelek: Programiranje | 1620 (1455) | illion |
| » | [c#] savefiledialog, en sfd a več datotekOddelek: Programiranje | 1072 (1000) | darkkk |
| » | [c#] shrani text, tabele, slikeOddelek: Programiranje | 2008 (1614) | Kemalito |
| » | [android] vstavljanje slikeOddelek: Programiranje | 1673 (1570) | messi |
| » | [PHP]Zajem podatkov iz bazeOddelek: Programiranje | 5512 (5149) | cobrica |
