Problemi z inštalacijo česarkoli
DebjWC ::
Imam kr en velik problem. Vse kar hočem inštalirat na računalnik u bistvu ne morem ker me komp opozori:
Error 1327.Invalid Drive J:\
Ima kdo kakšno idejo???? :(
Spike Edin ::
Nekaj popravkov je glede tega, probaj:
Windows XP Users
1. Click Start, and then click Control Panel.
2. In Control Panel, double-click Administrative Tools, and then double-click Computer Management.
3. In the Computer Management tree, click Disk Management.
4. Right-click the CD-ROM or DVD-ROM drive, or the drive that contains the operating system, and then click Change Drive Letter and Paths.
5. Click Change, and change it to the original drive letter. Click OK, and then click Close.
And:
# Verify that registry entries do not contain invalid drive letters that might be causing this error:
Important: The following steps require you to modify the Windows registry. Modifications to the Windows registry, if not done correctly, can cause serious problems to a Windows system. Before editing the registry, see How Do I Back Up Registry Keys on My Computer?
1. Click Start, and then click Run. The Run dialog box opens.
2. In the Open field, type regedit, and then click OK. The Registry Editor opens.
3. In the Registry Editor, locate the following registry key:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders
4. In the right pane, note the values in the Data column of each entry. If any value contains a drive that is not correct for your computer, right-click the entry and select Modify.
5. Type the correct drive letter in the Value data field, and then click OK. For example, if one of the values is "X:\Documents and Settings\Administrator", the drive letter should be changed to a valid drive on the system, such as “C:\Documents and Settings\Administrator".
6. Repeat steps 4 and 5 for each entry whose Data value contains an incorrect drive.
7. Repeat steps 3 through 6 for each of the following registry keys:
* HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
* HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion
* HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders
* HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
8. Close the Registry Editor and run the installation again.
Edit: g00d luck :)
The PC Doctor
Microsoft Outlook
182560 (2160) Grega_K
Undo za ComboFix
182404 (2169) MrStein
Remote desktop v XP SP3
142893 (1963) neres
Ikona od diska
52070 (2007) Mr_Globus
Trojanc
Oddelek: Omrežja in internet
131914 (1705) BigWhale
