"problem" rami
"problem" rami
gdjv ::
nisem strokovnjak za rame, zato me zanima.
imam 1GB PC5300 DDR2 (667 MHz), ko pa zaženem CPU-Z, kaže da je frekvenca 300 MHz.
SLIKA!
je to normalno, ali treba kaj spremenit?
plato imam:
MSI K9N NEO F V2 nforce520
tip podnožja: AM2 tip procesorja: AMD Sempron/Athlon 64/Athlon 64 X2/Athlon FX AM2 hitrost zunanjega vodila: 1000MHz DDR (2000MHz) vezni nabor: nVidia nForce520 število podnožij za pomnilnik: 4 DDR standard: DDR-II 800/667/533 maksimalna količina podprtega pomnilnika: 4GB podpora dvokanalnega pomnilnika: Da
Hvala.
StratOS ::
DDR 2
In electronic engineering, DDR2 SDRAM or double-data-rate two synchronous dynamic random access memory is a random access memory technology used for high speed storage of the working data of a computer or other digital electronic device.
Torej 2 * 300 (Memory clock) = cca 600 :D
Več na Wiki
"Multitasking - ability to f##k up several things at once."
"It works better if you plug it in."
"The one who is digging the hole for the other to fall in is allready in it."
gdjv ::
ok. hvala!
Slo-tech superpi team: intel core 2, i5, i7 & amd am2, am3 lestvica (strani: 1 2 3 4 5 6 )
Oddelek: Navijanje
264309310 (69903) krneki0001
primerjava med dvema računalnikoma
8967 (874) Spajky
Nov amd proc +plata,kaj bi bilo best buy za... (strani: 1 2 )
525724 (4517) x45
moja konfeguracija!!!
351935 (1935) pozitron
amd alarm?
Oddelek: Navijanje
191351 (1351) x45
