Kateri Uninstaller?
Kateri Uninstaller?
dunda ::
Še eno vprašanje za novi računalnik - kateri Uninstaller predlagate (po možnosti Free)?
Načeloma bi si človek želel, da že namestitev programa izvedem preko tega Uninstallerja. Ta naredi scan pred in po namestitvi ...
kixs ::
Your Uninstaller!
Your Uninstaller! uninstaller software completely takes the place of
Windows Add/Remove program, while offering you many more features.
Your Uninstaller can list "hidden" programs that you can't view using
the Windows Add/Remove program. The standard Add/Remove program often
can't uninstall applications completely-leaving broken registry keys
and unused files on the hard disk. Big registries and large numbers of
unnecessary files make system slow. Your Uninstaller! clears broken
keys and files in seconds using SmartUninstall™!
Fast and User-Friendly
Your Uninstaller! uninstaller software starts 500-1000% times faster
than Windows Add/Remove program. It also appropriately loads all
applications and icons, so you can easily find the programs you wish
to uninstall. Your Uninstaller! also contains a handy search function.
Easy to use
Your Uninstaller! automatically detects broken registry keys from you
Add/Remove list, and clears them entirely with your permission. Your
Uninstaller! can also detect unused files left by previous uninstalls
- it will prompt you before it completely the deletes these files.
Even a single drag-drop performs an uninstall process! All Your
Uninstaller! processes come with step-by-step instructions and can be
performed with a few simple clicks or drag-drops.
Find the spies..
Your Uninstaller! also contains an internal Startup Organizer that
safely removes or hides unwanted auto-run applications. This program
is very useful for finding spy programs. The Startup Organizer can
also search all possible startup locations; it then lists these
applications and their details for you. You can even add your own
auto-runners into startup folders, your registry, etc.
For more information visit :
http://www.ursoftware.com/
jan01 ::
ZSoft Uninstaller zastonj za razliko od prej omenjenega
* Analyze an installation so it can be completely uninstalled (also supports reboots of the computer as the process is split into two: Before and after the installation)
* Find and delete temporary files
* Delete entries from programs that are no longer installed
* Hide Windows Updates
* Hide entries from the list that you are never going to uninstall (drivers etc.) making the list smaller and therefore easier to manage.
* Show more information than available though add/remove
* Automatically find entries from programs that are most likely already uninstalled
* Automatically find entries that are considered "crap-ware"
* (Off course) search the list of installed software
Diagnostično orodje za WD
Oddelek: Programska oprema
145037 (4897) clovk
unistal že zbrisanega
71286 (1286) StratOS
Popolen izbris programov
82047 (1749) Ursus
Kako RES deinštalirati program?
101800 (1589) TitanSLO
Logitech MouseWare bug (?)
272600 (2196) Swiwer
