Forum » Programska oprema » LAN driverji
LAN driverji
|sleeper| ::
Rabu bi nujno gonilnike za lan pri prenosniku Solonote 1557, ali pa rip celotnega cd-ja z vsemi programi, ki ga dobiš ob nakupu tega prenosnika.
Lahko mi tudi date link če je možno kje to dol cuknat....
HVALA!
HVALA!
!Die happy & pretty! :)
StratOS ::
"Multitasking - ability to f##k up several things at once."
"It works better if you plug it in."
"The one who is digging the hole for the other to fall in is allready in it."
- spremenila: StratOS ()
| » | Flash BIOSaOddelek: Pomoč in nasveti | 1394 (1322) | Macx95 |
| » | 200GB disk zazna mi ga samo 130Oddelek: Strojna oprema | 5761 (5633) | HeXeD |
