administrator password
Neon87 ::
Pozdravljeni!
Na kompu mam naložena dva operacijska sistema(LINUX in WinXP). Rad bi odstranil LINUX, ker ga ne potrebujem.
Na zadnje ko sem to delal je bila praksa takšna, da se mi je sesu potem BOOT. Namreč z LINUXom sem odstranil tud GRUB.
Sedaj sem zasledil, da obstajata dve komandi v Win, ki spet postavita stvari na svoje mesto in normalno zaženeta Windowse. In sicer: fixboot in fixmbr, do njiju se da dostopat preko Recovery console in sicer na takšen način, da pač zbootam CD od Windowsov in potem zaženem RC.
V delovanje fixboota in pa fixmbr sem se želel prepričati, saj imam na kompu nekatere podatke, ki jih ne bi rad izgubil.
Stvar pa se ustavi, ko hočem zagnat recovery console zahteva administrativno geslo! To je geslo, ki sem ga uporabil takrat ko sem nalagal windowse in nikoli več, saj imam account z vsemi pravicami in administrativnega ne potrebujem. Poskusil sem vse, tudi prazno kar se mi zdi, da sem imel.
Pa ne gre...
Poskusil sem naredit tud to:
9. During the reboot, do not make the mistake of “pressing any key” to boot from the CD again! Setup will resume automatically with the standard billboard screens and you will notice Installing Windows is highlighted.
10. Keep your eye on the lower left hand side of the screen and when you see the Installing Devices progress bar, press SHIFT + F10. This is the security hole! A command console will now open up giving you the potential for wide access to your system.
11. At the prompt, type NUSRMGR.CPL and press Enter. Voila! You have just gained graphical access to your User Accounts in the Control Panel.
12. Now simply pick the account you need to change and remove or change your password as you prefer. If you want to log on without having to enter your new password, you can type control userpasswords2 at the prompt and choose to log on without being asked for password. After you’ve made your changes close the windows, exit the command box and continue on with the Repair (have your Product key handy).
13. Once the Repair is done, you will be able to log on with your new password (or without a password if you chose not to use one or if you chose not to be asked for a password). Your programs and personalized settings should remain intact.
Vendar pri 11. kjer se mi pokaže plošča z USER ACCOUNTI, nima ADMINISTRATORJA.
Kaj bi še lahko naredil.
Hvala za odgovore.
bluefish ::
tako ko se ti zažene recovery console izberi slovenian layout za tipkovnico. Geslo vnesti točno tisto, ki si ga izbral ob namestitvi. Pazi tudi na velike in male črke.
Neon87 ::
Am fora je, da ne vem gesla :O katerega sem izbral 2 leti nazaj pa še to imam občutek, da ga nisem, ali pa vsaj takšnega, ki ga uporabljam drugače. Vendar ne štima. Invalid password, pa se zmotim 3krat pa se reboota. 8-O
Ch4N93 ::
poskusi najti geslo z ophcrack.
Ni nam lahko...
kockish ::
Ne kompliciraj, ce imas dostop z vsemi pravicami, lahko resetiras katerokoli geslo, tudi administratorsko.
Administrative Tools -> Computer Management -> Local Users and Groups, desni klik na Administratorja, Set Password.
kako odkleniti LG G5?
Oddelek: Mobilne tehnologije
303505 (2893) louser
Šifrirana mapa
Oddelek: Operacijski sistemi
92845 (2316) amigo_no1
Ikone v win XP izginile po uporabi programa Spybot Search & Destroy. Kako dobiti ikon
52702 (2658) riba43
Izginil standardni zagon? !!
51564 (1456) CaqKa
WIN 2000 BOOT ?
Oddelek: Programska oprema
131859 (1724) rookie
