Forum » Programska oprema » DirectX August 2007 & Vista Compatibility & Reliability Patch
Tr0n ::
Je ze kdo probal omenjene popravke? Baje, da popravijo in zoptimizirajo precej zadev. DirectX package vsebuje tudi popravke za DX10.
Microsoft DirectX 9 & 10 August 2007
http://downloads.guru3d.com/downloadget.php?id=1321&file=1&evp=190c3f9b352365586dbf0d6cbe985769
Vista Compatibility & Reliability Patch (Vista 32-bit)
http://downloads.guru3d.com/downloadget.php?id=1686&file=4&evp=0825474a6af60e843ab07353f8380111
938194 Vista Compatibility and Reliability Pack
This update resolves a number of individual issues which may be affecting some computers running Windows Vista. These issues have been reported by customers using the Error Reporting service, product support, or other means. Installing this update will improve the reliability and hardware compatibility of Windows Vista in a variety of scenarios. Some examples of the improvements contained in this update are:
* Improved reliability and compatibility of Vista when used with newer graphics cards in several specific scenarios and configurations.
* Improved reliability when working with external displays on a laptop.
* Increased compatibility with many video drivers.
* Improved visual appearance of games with high intensity graphics.
* Improved quality of playback for HD-DVD and Blue-Ray disks on large monitors.
* Improved reliability for Internet Explorer when some third party toolbars are installed on Vista.
* Improved Vista reliability in networking configuration scenarios.
* Improved the reliability of Windows Calendar in Vista.
* Improved reliability of systems that were upgraded from XP to Vista.
* Increased compatibility with many printer drivers.
* Increased reliability and performance of Vista when entering sleep and resuming from sleep.
938979 Vista Performance and Reliability Pack
This update resolves a number of individual issues which may be affecting some computers running Windows Vista. These issues have been reported by customers using the Error Reporting service, product support, or other means. Installing this update will improve the performance and responsiveness for some scenarios and improves reliability of Windows Vista in a variety of scenarios. Some examples of the improvements contained in this update are:
* Improves performance in resuming back to the desktop from the Photo and Windows Energy screensaver.
* Resolves an issue where some secured web pages using advanced security technologies may not get displayed in Internet Explorer on Windows Vista.
* Resolves an issue where a shared printer may not get installed if the printer is connected to a Windows XP or Windows Server 2003 system and User Access Control is disabled on the Vista client.
* Resolves an issue where creating AVI files on Vista may get corrupted.
* Improves the performance in calculating the ‘estimated time remaining’ when copying/moving large files.
* Improves performance in bringing up Login Screen after resuming from Hibernate.
* Resolves an issue where synchronization of offline files to a server can get corrupted.
* Resolves a compatibility issue with RAW images created by Canon EOS 1D/1DS Digital SLR Camera which can lead to data loss. This only affects RAW images created by these two specific camera models.
* Resolves an issue where a computer can lose its default Gateway address when resuming from sleep mode.
* Improves the performance when copying or moving entire directories containing large amounts of data or files.
* Improves the performance of Vista’s Memory Manager in specific customer scenarios and prevents some issues which may lead to memory corruption.
- spremenilo: Tr0n ()
Daliborg ::
treba probat, smo da se domov spravm :)
Format life:
Warning all life will be erased!
Do you want to continue?(y/n) Y_
Zheegec ::
Performance pri kopiranju so znatno boljše, samo pazite - to je BETA, jaz sem že moral narediti repair Viste zaradi teh patchev :)
Janez Janša, 29.04.2014
Tr0n ::
Jup.
Baje, da so ti popravki tudi v SP1 beta, tako da se po mojem se splaca pocakat na retail Vista SP1.
Mavrik ::
SP1 za Visto še ne bo tak hitro izšel, medtem ko bi naj final verzijo teh popravkov videli že drugi teden.
| » | Navijanje FX5700-keOddelek: Navijanje | 1278 (1168) | muzičar |
| » | ATI 9600pro utrgalo?Oddelek: Strojna oprema | 1644 (1464) | Eddy |
| » | Varno navijanjeOddelek: Navijanje | 1301 (1239) | Shark-357 |
| » | metanje iz igerOddelek: Pomoč in nasveti | 1237 (1206) | Darth Vader |
| » | NVIDIA golnilnikiOddelek: Programska oprema | 1207 (1181) | Dr_M |
